Port SSD caffemodel to Deepstream 5.0
I have a ssd.caffemodel and its corresponding test.prototxt. Here I referred the config file and source4_1080p_dec_infer resnet_tracker_sgie_tiled_display_int8.txt (example for resnet.caffemodel) to port it on deepstream, but it doesn’t work. Kindly give me steps on how to port it on Deepstream SDK. So that I can test it using a sample pipeline in NVINFER plugin. Here sharing the test.prototxt for the same.
input:“data”
input_shape{
dim:1
dim:3
dim:360
dim:480
layer {
type: “Convolution”
bottom: “data”
top: “conv1_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 14
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv1_1”
top: “conv1_1”
layer {
type: “Convolution”
bottom: “conv1_1”
top: “conv1_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 30
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv1_2”
top: “conv1_2”
layer {
type: “Pooling”
bottom: “conv1_2”
top: “pool1”
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
type: “Convolution”
bottom: “pool1”
top: “conv2_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 44
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv2_1”
top: “conv2_1”
layer {
type: “Convolution”
bottom: “conv2_1”
top: “conv2_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 50
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv2_2”
top: “conv2_2”
layer {
type: “Pooling”
bottom: “conv2_2”
top: “pool2”
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
type: “Convolution”
bottom: “pool2”
top: “conv3_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 68
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv3_1”
top: “conv3_1”
layer {
type: “Convolution”
bottom: “conv3_1”
top: “conv3_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 54
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv3_2”
top: “conv3_2”
layer {
type: “Convolution”
bottom: “conv3_2”
top: “conv3_3”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 108
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv3_3”
top: “conv3_3”
layer {
type: “Pooling”
bottom: “conv3_3”
top: “pool3”
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
type: “Convolution”
bottom: “pool3”
top: “conv4_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 248
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv4_1”
top: “conv4_1”
layer {
type: “Convolution”
bottom: “conv4_1”
top: “conv4_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 190
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv4_2”
top: “conv4_2”
layer {
type: “Convolution”
bottom: “conv4_2”
top: “conv4_3”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 110
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “BatchNorm”
bottom: “conv4_3”
top: “conv4_3”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 1
decay_mult: 0
param {
lr_mult: 1
decay_mult: 0
param {
lr_mult: 0
decay_mult: 0
param {
lr_mult: 0
decay_mult: 0
batch_norm_param {
scale_filler {
type: “constant”
value: 1
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv4_3”
top: “conv4_3”
layer {
type: “Pooling”
bottom: “conv4_3”
top: “pool4”
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
type: “Convolution”
bottom: “pool4”
top: “conv5_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 2
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv5_1”
top: “conv5_1”
layer {
type: “Convolution”
bottom: “conv5_1”
top: “conv5_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 2
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv5_2”
top: “conv5_2”
layer {
type: “Convolution”
bottom: “conv5_2”
top: “conv5_3”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 2
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv5_3”
top: “conv5_3”
layer {
type: “Pooling”
bottom: “conv5_3”
top: “pool5”
pooling_param {
pool: MAX
kernel_size: 3
stride: 1
pad: 1
layer {
type: “Convolution”
bottom: “pool5”
top: “fc6”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 2
pad: 1
kernel_size: 3
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “fc6”
top: “fc6”
layer {
type: “Convolution”
bottom: “fc6”
top: “fc7”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 32
kernel_size: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “fc7”
top: “fc7”
layer {
type: “Convolution”
bottom: “fc7”
top: “conv6_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 6
pad: 0
kernel_size: 1
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv6_1”
top: “conv6_1”
layer {
type: “Convolution”
bottom: “conv6_1”
top: “conv6_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 84
pad: 1
kernel_size: 3
stride: 2
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv6_2”
top: “conv6_2”
layer {
type: “Convolution”
bottom: “conv6_2”
top: “conv7_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 8
pad: 0
kernel_size: 1
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv7_1”
top: “conv7_1”
layer {
type: “Convolution”
bottom: “conv7_1”
top: “conv7_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 8
pad: 1
kernel_size: 3
stride: 2
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv7_2”
top: “conv7_2”
layer {
type: “Convolution”
bottom: “conv7_2”
top: “conv8_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 2
pad: 0
kernel_size: 1
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv8_1”
top: “conv8_1”
layer {
type: “Convolution”
bottom: “conv8_1”
top: “conv8_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 32
pad: 0
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv8_2”
top: “conv8_2”
layer {
type: “Convolution”
bottom: “conv8_2”
top: “conv9_1”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 2
pad: 0
kernel_size: 1
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv9_1”
top: “conv9_1”
layer {
type: “Convolution”
bottom: “conv9_1”
top: “conv9_2”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 6
pad: 0
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “ReLU”
bottom: “conv9_2”
top: “conv9_2”
layer {
type: “Convolution”
bottom: “conv4_3”
top: “conv4_3_norm_mbox_loc”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 32
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “conv4_3_norm_mbox_loc”
top: “conv4_3_norm_mbox_loc_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Flatten”
bottom: “conv4_3_norm_mbox_loc_perm”
top: “conv4_3_norm_mbox_loc_flat”
flatten_param {
axis: 1
layer {
type: “Convolution”
bottom: “conv4_3”
top: “conv4_3_norm_mbox_conf”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 32
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “conv4_3_norm_mbox_conf”
top: “conv4_3_norm_mbox_conf_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Flatten”
bottom: “conv4_3_norm_mbox_conf_perm”
top: “conv4_3_norm_mbox_conf_flat”
flatten_param {
axis: 1
layer {
type: “PriorBox”
bottom: “conv4_3”
bottom: “data”
top: “conv4_3_norm_mbox_priorbox”
prior_box_param {
min_size: 15
min_size: 30
max_size: 33
max_size: 66
aspect_ratio: 2
flip: true
clip: false
variance: 0.1
variance: 0.1
variance: 0.2
variance: 0.2
step: 8
offset: 0.5
layer {
type: “Convolution”
bottom: “fc7”
top: “fc7_mbox_loc”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 24
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “fc7_mbox_loc”
top: “fc7_mbox_loc_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Flatten”
bottom: “fc7_mbox_loc_perm”
top: “fc7_mbox_loc_flat”
flatten_param {
axis: 1
layer {
type: “Convolution”
bottom: “fc7”
top: “fc7_mbox_conf”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 24
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “fc7_mbox_conf”
top: “fc7_mbox_conf_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Flatten”
bottom: “fc7_mbox_conf_perm”
top: “fc7_mbox_conf_flat”
flatten_param {
axis: 1
layer {
type: “PriorBox”
bottom: “fc7”
bottom: “data”
top: “fc7_mbox_priorbox”
prior_box_param {
min_size: 66
max_size: 127
aspect_ratio: 2
aspect_ratio: 3
flip: true
clip: false
variance: 0.1
variance: 0.1
variance: 0.2
variance: 0.2
step: 16
offset: 0.5
layer {
type: “Convolution”
bottom: “conv6_2”
top: “conv6_2_mbox_loc”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 24
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “conv6_2_mbox_loc”
top: “conv6_2_mbox_loc_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Flatten”
bottom: “conv6_2_mbox_loc_perm”
top: “conv6_2_mbox_loc_flat”
flatten_param {
axis: 1
layer {
type: “Convolution”
bottom: “conv6_2”
top: “conv6_2_mbox_conf”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 24
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “conv6_2_mbox_conf”
top: “conv6_2_mbox_conf_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Flatten”
bottom: “conv6_2_mbox_conf_perm”
top: “conv6_2_mbox_conf_flat”
flatten_param {
axis: 1
layer {
type: “PriorBox”
bottom: “conv6_2”
bottom: “data”
top: “conv6_2_mbox_priorbox”
prior_box_param {
min_size: 127
max_size: 188
aspect_ratio: 2
aspect_ratio: 3
flip: true
clip: false
variance: 0.1
variance: 0.1
variance: 0.2
variance: 0.2
step: 32
offset: 0.5
layer {
type: “Convolution”
bottom: “conv7_2”
top: “conv7_2_mbox_loc”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 24
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “conv7_2_mbox_loc”
top: “conv7_2_mbox_loc_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Flatten”
bottom: “conv7_2_mbox_loc_perm”
top: “conv7_2_mbox_loc_flat”
flatten_param {
axis: 1
layer {
type: “Convolution”
bottom: “conv7_2”
top: “conv7_2_mbox_conf”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 24
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “conv7_2_mbox_conf”
top: “conv7_2_mbox_conf_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Flatten”
bottom: “conv7_2_mbox_conf_perm”
top: “conv7_2_mbox_conf_flat”
flatten_param {
axis: 1
layer {
type: “PriorBox”
bottom: “conv7_2”
bottom: “data”
top: “conv7_2_mbox_priorbox”
prior_box_param {
min_size: 188
max_size: 249
aspect_ratio: 2
aspect_ratio: 3
flip: true
clip: false
variance: 0.1
variance: 0.1
variance: 0.2
variance: 0.2
step: 64
offset: 0.5
layer {
type: “Convolution”
bottom: “conv8_2”
top: “conv8_2_mbox_loc”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 16
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “conv8_2_mbox_loc”
top: “conv8_2_mbox_loc_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Flatten”
bottom: “conv8_2_mbox_loc_perm”
top: “conv8_2_mbox_loc_flat”
flatten_param {
axis: 1
layer {
type: “Convolution”
bottom: “conv8_2”
top: “conv8_2_mbox_conf”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 16
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “conv8_2_mbox_conf”
top: “conv8_2_mbox_conf_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Flatten”
bottom: “conv8_2_mbox_conf_perm”
top: “conv8_2_mbox_conf_flat”
flatten_param {
axis: 1
layer {
type: “PriorBox”
bottom: “conv8_2”
bottom: “data”
top: “conv8_2_mbox_priorbox”
prior_box_param {
min_size: 249
max_size: 310
aspect_ratio: 2
flip: true
clip: false
variance: 0.1
variance: 0.1
variance: 0.2
variance: 0.2
step: 100
offset: 0.5
layer {
type: “Convolution”
bottom: “conv9_2”
top: “conv9_2_mbox_loc”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 16
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “conv9_2_mbox_loc”
top: “conv9_2_mbox_loc_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Flatten”
bottom: “conv9_2_mbox_loc_perm”
top: “conv9_2_mbox_loc_flat”
flatten_param {
axis: 1
layer {
type: “Convolution”
bottom: “conv9_2”
top: “conv9_2_mbox_conf”
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 16
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: “xavier”
bias_filler {
type: “constant”
value: 0
layer {
type: “Permute”
bottom: “conv9_2_mbox_conf”
top: “conv9_2_mbox_conf_perm”
permute_param {
order: 0
order: 2
order: 3
order: 1
layer {
type: “Flatten”
bottom: “conv9_2_mbox_conf_perm”
top: “conv9_2_mbox_conf_flat”
flatten_param {
axis: 1
layer {
type: “PriorBox”
bottom: “conv9_2”
bottom: “data”
top: “conv9_2_mbox_priorbox”
prior_box_param {
min_size: 310
max_size: 372
aspect_ratio: 2
flip: true
clip: false
variance: 0.1
variance: 0.1
variance: 0.2
variance: 0.2
step: 300
offset: 0.5
layer {
type: “Concat”
bottom: “conv4_3_norm_mbox_loc_flat”
bottom: “fc7_mbox_loc_flat”
bottom: “conv6_2_mbox_loc_flat”
bottom: “conv7_2_mbox_loc_flat”
bottom: “conv8_2_mbox_loc_flat”
bottom: “conv9_2_mbox_loc_flat”
top: “mbox_loc”
concat_param {
axis: 1
layer {
type: “Concat”
bottom: “conv4_3_norm_mbox_conf_flat”
bottom: “fc7_mbox_conf_flat”
bottom: “conv6_2_mbox_conf_flat”
bottom: “conv7_2_mbox_conf_flat”
bottom: “conv8_2_mbox_conf_flat”
bottom: “conv9_2_mbox_conf_flat”
top: “mbox_conf”
concat_param {
axis: 1
layer {
type: “Concat”
bottom: “conv4_3_norm_mbox_priorbox”
bottom: “fc7_mbox_priorbox”
bottom: “conv6_2_mbox_priorbox”
bottom: “conv7_2_mbox_priorbox”
bottom: “conv8_2_mbox_priorbox”
bottom: “conv9_2_mbox_priorbox”
top: “mbox_priorbox”
concat_param {
axis: 2
layer {
type: “Reshape”
bottom: “mbox_conf”
top: “mbox_conf_reshape”
reshape_param {
shape {
dim: 0
dim: -1
dim: 4
layer {
type: “Softmax”
bottom: “mbox_conf_reshape”
top: “mbox_conf_softmax”
softmax_param {
axis: 2
layer {
type: “Flatten”
bottom: “mbox_conf_softmax”
top: “mbox_conf_flatten”
flatten_param {
axis: 1
layer {
type: “DetectionOutput”
bottom: “mbox_loc”
bottom: “mbox_conf_flatten”
bottom: “mbox_priorbox”
top: “detection_out”
include {
phase: TEST
detection_output_param {
num_classes: 4
share_location: true
background_label_id: 0
nms_param {
nms_threshold: 0.45
top_k: 400
code_type: CENTER_SIZE
keep_top_k: 200
confidence_threshold: 0.01
**• Hardware Platform (Jetson / GPU)**T4
• DeepStream Version5.0
• TensorRT Version7.0
**• NVIDIA GPU Driver Version (valid for GPU only)**450.36.06
@george_na
Have you successfully compiled and run this sample here?
/where_deepstream_installed/sources/objectDetector_SSD
I find there are flatten layers in your model.
The manuals in README tells you how to replace flatten layers into reshape layers.
Hi ersheng,
I have done that can you please try in your end.
@george_na
Sorry for late response.
There is another SSD caffe sample in TensorRT-7.x.x.x/samples/sampleSSD which is an independent TensorRT program without DeepStream pipeline. You can try to run it by reading README carefully.
And then you can try to deploy the same caffe model to DeepStream 5.0 to run the pipeline again if you can successfully run TensorRT-7.x.x.x/samples/sampleSSD independently.
I don’t know if there is much difference between your caffe model and the sample caffe model for TensorRT-7.x.x.x/samples/sampleSSD. But I think these suggestions step by step should be helpful for you.
