Segmentation fault occurs while running jetson-inference example application
I am very new to this platform so I started from here and flashed the image in the SD card.
For the application development I started from here and trying to run the sample application after building the project from the source. Here is my environment setup:
• Hardware Platform (Jetson / GPU) = Jetson Nano 4GB Dev Kit
• DeepStream Version = 5.1
• JetPack Version = R32(release), REVISION: 6.1
• TensorRT Version = 8.0
• CUDA = 10.2.300
• CUDNN = 8.2.1
• Issue Type = Question
When I am trying to run my-detection application, getting this error:
spectross@spectross-desktop:~/jetson-inference/python/examples$ python3 my-detection.py /dev/video0
jetson.inference -- detectNet loading build-in network 'ssd-mobilenet-v2'
detectNet -- loading detection network model from:
          -- model        networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff
          -- input_blob   'Input'
          -- output_blob  'NMS'
          -- output_count 'NMS_1'
          -- class_labels networks/SSD-Mobilenet-v2/ssd_coco_labels.txt
          -- threshold    0.500000
          -- batch_size   1
[TRT]    TensorRT version 8.0.1
[TRT]    loading NVIDIA plugins...
[TRT]    Registered plugin creator - ::GridAnchor_TRT version 1
[TRT]    Registered plugin creator - ::GridAnchorRect_TRT version 1
[TRT]    Registered plugin creator - ::NMS_TRT version 1
[TRT]    Registered plugin creator - ::Reorg_TRT version 1
[TRT]    Registered plugin creator - ::Region_TRT version 1
[TRT]    Registered plugin creator - ::Clip_TRT version 1
[TRT]    Registered plugin creator - ::LReLU_TRT version 1
[TRT]    Registered plugin creator - ::PriorBox_TRT version 1
[TRT]    Registered plugin creator - ::Normalize_TRT version 1
[TRT]    Registered plugin creator - ::ScatterND version 1
[TRT]    Registered plugin creator - ::RPROI_TRT version 1
[TRT]    Registered plugin creator - ::BatchedNMS_TRT version 1
[TRT]    Registered plugin creator - ::BatchedNMSDynamic_TRT version 1
[TRT]    Could not register plugin creator -  ::FlattenConcat_TRT version 1
[TRT]    Registered plugin creator - ::CropAndResize version 1
[TRT]    Registered plugin creator - ::DetectionLayer_TRT version 1
[TRT]    Registered plugin creator - ::EfficientNMS_ONNX_TRT version 1
[TRT]    Registered plugin creator - ::EfficientNMS_TRT version 1
[TRT]    Registered plugin creator - ::Proposal version 1
[TRT]    Registered plugin creator - ::ProposalLayer_TRT version 1
[TRT]    Registered plugin creator - ::PyramidROIAlign_TRT version 1
[TRT]    Registered plugin creator - ::ResizeNearest_TRT version 1
[TRT]    Registered plugin creator - ::Split version 1
[TRT]    Registered plugin creator - ::SpecialSlice_TRT version 1
[TRT]    Registered plugin creator - ::InstanceNormalization_TRT version 1
[TRT]    detected model format - UFF  (extension '.uff')
[TRT]    desired precision specified for GPU: FASTEST
[TRT]    requested fasted precision for device GPU without providing valid calibrator, disabling INT8
[TRT]    [MemUsageChange] Init CUDA: CPU +203, GPU +0, now: CPU 226, GPU 3811 (MiB)
[TRT]    native precisions detected for GPU:  FP32, FP16
[TRT]    selecting fastest native precision for GPU:  FP16
[TRT]    attempting to open engine cache file /usr/local/bin/networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff.1.1.8001.GPU.FP16.engine
[TRT]    cache file not found, profiling network model on device GPU
[TRT]    [MemUsageChange] Init CUDA: CPU +0, GPU +0, now: CPU 226, GPU 3812 (MiB)
[TRT]    device GPU, loading /usr/bin/ /usr/local/bin/networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff
[TRT]    UFFParser: Parsing Input[Op: Input].
[TRT]    UFFParser: Input -> [3,300,300]
[TRT]    UFFParser: Applying order forwarding to: Input
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/Conv/weights[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/Conv/weights -> [3,3,3,32]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/Conv/weights
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/Conv/Conv2D[Op: Conv]. Inputs: Input, FeatureExtractor/MobilenetV2/Conv/weights
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/Conv/Conv2D -> [32,150,150]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/Conv/Conv2D
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/Conv/BatchNorm/moving_variance[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/Conv/BatchNorm/moving_variance -> [32]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/Conv/BatchNorm/moving_variance
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/Conv/BatchNorm/batchnorm/add/y[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/Conv/BatchNorm/batchnorm/add/y -> []
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/Conv/BatchNorm/batchnorm/add/y
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/Conv/BatchNorm/batchnorm/add[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/Conv/BatchNorm/moving_variance, FeatureExtractor/MobilenetV2/Conv/BatchNorm/batchnorm/add/y
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/Conv/BatchNorm/batchnorm/Rsqrt[Op: Unary]. Inputs: FeatureExtractor/MobilenetV2/Conv/BatchNorm/batchnorm/add
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/Conv/BatchNorm/batchnorm/Rsqrt
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/Conv/BatchNorm/gamma[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/Conv/BatchNorm/gamma -> [32]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/Conv/BatchNorm/gamma
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/Conv/BatchNorm/batchnorm/mul[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/Conv/BatchNorm/batchnorm/Rsqrt, FeatureExtractor/MobilenetV2/Conv/BatchNorm/gamma
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/Conv/BatchNorm/batchnorm/mul
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/Conv/BatchNorm/batchnorm/mul_1[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/Conv/Conv2D, FeatureExtractor/MobilenetV2/Conv/BatchNorm/batchnorm/mul
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/Conv/BatchNorm/batchnorm/mul_1 -> [32,150,150]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/Conv/BatchNorm/batchnorm/mul_1
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/Conv/BatchNorm/beta[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/Conv/BatchNorm/beta -> [32]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/Conv/BatchNorm/beta
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/Conv/BatchNorm/moving_mean[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/Conv/BatchNorm/moving_mean -> [32]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/Conv/BatchNorm/moving_mean
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/Conv/BatchNorm/batchnorm/mul_2[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/Conv/BatchNorm/moving_mean, FeatureExtractor/MobilenetV2/Conv/BatchNorm/batchnorm/mul
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/Conv/BatchNorm/batchnorm/mul_2
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/Conv/BatchNorm/batchnorm/sub[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/Conv/BatchNorm/beta, FeatureExtractor/MobilenetV2/Conv/BatchNorm/batchnorm/mul_2
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/Conv/BatchNorm/batchnorm/sub
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/Conv/BatchNorm/batchnorm/add_1[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/Conv/BatchNorm/batchnorm/mul_1, FeatureExtractor/MobilenetV2/Conv/BatchNorm/batchnorm/sub
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/Conv/BatchNorm/batchnorm/add_1 -> [32,150,150]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/Conv/BatchNorm/batchnorm/add_1
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/Conv/Relu6[Op: Activation]. Inputs: FeatureExtractor/MobilenetV2/Conv/BatchNorm/batchnorm/add_1
[TRT]    Setting dynamic range for (Unnamed Layer* 9) [Activation]_output to [0,6]
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/Conv/Relu6 -> [32,150,150]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/Conv/Relu6
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv/depthwise/depthwise_weights[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv/depthwise/depthwise_weights -> [3,3,32,1]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv/depthwise/depthwise_weights
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv/depthwise/depthwise[Op: Conv]. Inputs: FeatureExtractor/MobilenetV2/Conv/Relu6, FeatureExtractor/MobilenetV2/expanded_conv/depthwise/depthwise_weights
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv/depthwise/depthwise -> [32,150,150]
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/moving_variance[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/moving_variance -> [32]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/moving_variance
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/batchnorm/add/y[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/batchnorm/add/y -> []
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/batchnorm/add/y
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/batchnorm/add[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/moving_variance, FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/batchnorm/add/y
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/batchnorm/Rsqrt[Op: Unary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/batchnorm/add
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/batchnorm/Rsqrt
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/gamma[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/gamma -> [32]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/gamma
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/batchnorm/mul[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/batchnorm/Rsqrt, FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/gamma
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/batchnorm/mul
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/batchnorm/mul_1[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv/depthwise/depthwise, FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/batchnorm/mul
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/batchnorm/mul_1 -> [32,150,150]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/batchnorm/mul_1
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/beta[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/beta -> [32]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/beta
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/moving_mean[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/moving_mean -> [32]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/moving_mean
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/batchnorm/mul_2[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/moving_mean, FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/batchnorm/mul
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/batchnorm/mul_2
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/batchnorm/sub[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/beta, FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/batchnorm/mul_2
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/batchnorm/sub
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/batchnorm/add_1[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/batchnorm/mul_1, FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/batchnorm/sub
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/batchnorm/add_1 -> [32,150,150]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/batchnorm/add_1
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv/depthwise/Relu6[Op: Activation]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/batchnorm/add_1
[TRT]    Setting dynamic range for (Unnamed Layer* 19) [Activation]_output to [0,6]
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv/depthwise/Relu6 -> [32,150,150]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv/depthwise/Relu6
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv/project/weights[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv/project/weights -> [1,1,32,16]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv/project/weights
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv/project/Conv2D[Op: Conv]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv/depthwise/Relu6, FeatureExtractor/MobilenetV2/expanded_conv/project/weights
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv/project/Conv2D -> [16,150,150]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv/project/Conv2D
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/moving_variance[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/moving_variance -> [16]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/moving_variance
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/batchnorm/add/y[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/batchnorm/add/y -> []
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/batchnorm/add/y
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/batchnorm/add[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/moving_variance, FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/batchnorm/add/y
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/batchnorm/Rsqrt[Op: Unary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/batchnorm/add
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/batchnorm/Rsqrt
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/gamma[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/gamma -> [16]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/gamma
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/batchnorm/mul[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/batchnorm/Rsqrt, FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/gamma
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/batchnorm/mul
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/batchnorm/mul_1[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv/project/Conv2D, FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/batchnorm/mul
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/batchnorm/mul_1 -> [16,150,150]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/batchnorm/mul_1
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/beta[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/beta -> [16]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/beta
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/moving_mean[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/moving_mean -> [16]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/moving_mean
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/batchnorm/mul_2[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/moving_mean, FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/batchnorm/mul
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/batchnorm/mul_2
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/batchnorm/sub[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/beta, FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/batchnorm/mul_2
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/batchnorm/sub
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/batchnorm/add_1[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/batchnorm/mul_1, FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/batchnorm/sub
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/batchnorm/add_1 -> [16,150,150]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/batchnorm/add_1
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/expand/weights[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_1/expand/weights -> [1,1,16,96]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/expand/weights
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/expand/Conv2D[Op: Conv]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv/project/BatchNorm/batchnorm/add_1, FeatureExtractor/MobilenetV2/expanded_conv_1/expand/weights
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_1/expand/Conv2D -> [96,150,150]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/expand/Conv2D
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/moving_variance[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/moving_variance -> [96]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/moving_variance
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/batchnorm/add/y[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/batchnorm/add/y -> []
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/batchnorm/add/y
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/batchnorm/add[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/moving_variance, FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/batchnorm/add/y
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/batchnorm/Rsqrt[Op: Unary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/batchnorm/add
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/batchnorm/Rsqrt
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/gamma[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/gamma -> [96]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/gamma
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/batchnorm/mul[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/batchnorm/Rsqrt, FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/gamma
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/batchnorm/mul
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/batchnorm/mul_1[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_1/expand/Conv2D, FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/batchnorm/mul
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/batchnorm/mul_1 -> [96,150,150]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/batchnorm/mul_1
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/beta[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/beta -> [96]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/beta
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/moving_mean[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/moving_mean -> [96]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/moving_mean
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/batchnorm/mul_2[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/moving_mean, FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/batchnorm/mul
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/batchnorm/mul_2
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/batchnorm/sub[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/beta, FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/batchnorm/mul_2
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/batchnorm/sub
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/batchnorm/add_1[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/batchnorm/mul_1, FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/batchnorm/sub
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/batchnorm/add_1 -> [96,150,150]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/batchnorm/add_1
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/expand/Relu6[Op: Activation]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_1/expand/BatchNorm/batchnorm/add_1
[TRT]    Setting dynamic range for (Unnamed Layer* 38) [Activation]_output to [0,6]
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_1/expand/Relu6 -> [96,150,150]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/expand/Relu6
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/depthwise_weights[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/depthwise_weights -> [3,3,96,1]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/depthwise_weights
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/depthwise[Op: Conv]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_1/expand/Relu6, FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/depthwise_weights
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/depthwise -> [96,75,75]
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/moving_variance[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/moving_variance -> [96]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/moving_variance
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/batchnorm/add/y[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/batchnorm/add/y -> []
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/batchnorm/add/y
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/batchnorm/add[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/moving_variance, FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/batchnorm/add/y
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/batchnorm/Rsqrt[Op: Unary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/batchnorm/add
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/batchnorm/Rsqrt
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/gamma[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/gamma -> [96]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/gamma
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/batchnorm/mul[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/batchnorm/Rsqrt, FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/gamma
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/batchnorm/mul
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/batchnorm/mul_1[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/depthwise, FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/batchnorm/mul
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/batchnorm/mul_1 -> [96,75,75]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/batchnorm/mul_1
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/beta[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/beta -> [96]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/beta
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/moving_mean[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/moving_mean -> [96]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/moving_mean
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/batchnorm/mul_2[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/moving_mean, FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/batchnorm/mul
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/batchnorm/mul_2
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/batchnorm/sub[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/beta, FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/batchnorm/mul_2
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/batchnorm/sub
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/batchnorm/add_1[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/batchnorm/mul_1, FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/batchnorm/sub
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/batchnorm/add_1 -> [96,75,75]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/batchnorm/add_1
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/Relu6[Op: Activation]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/BatchNorm/batchnorm/add_1
[TRT]    Setting dynamic range for (Unnamed Layer* 48) [Activation]_output to [0,6]
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/Relu6 -> [96,75,75]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/Relu6
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/project/weights[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_1/project/weights -> [1,1,96,24]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/project/weights
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/project/Conv2D[Op: Conv]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_1/depthwise/Relu6, FeatureExtractor/MobilenetV2/expanded_conv_1/project/weights
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_1/project/Conv2D -> [24,75,75]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/project/Conv2D
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/moving_variance[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/moving_variance -> [24]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/moving_variance
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/batchnorm/add/y[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/batchnorm/add/y -> []
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/batchnorm/add/y
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/batchnorm/add[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/moving_variance, FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/batchnorm/add/y
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/batchnorm/Rsqrt[Op: Unary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/batchnorm/add
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/batchnorm/Rsqrt
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/gamma[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/gamma -> [24]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/gamma
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/batchnorm/mul[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/batchnorm/Rsqrt, FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/gamma
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/batchnorm/mul
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/batchnorm/mul_1[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_1/project/Conv2D, FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/batchnorm/mul
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/batchnorm/mul_1 -> [24,75,75]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/batchnorm/mul_1
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/beta[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/beta -> [24]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/beta
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/moving_mean[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/moving_mean -> [24]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/moving_mean
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/batchnorm/mul_2[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/moving_mean, FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/batchnorm/mul
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/batchnorm/mul_2
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/batchnorm/sub[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/beta, FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/batchnorm/mul_2
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/batchnorm/sub
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/batchnorm/add_1[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/batchnorm/mul_1, FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/batchnorm/sub
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/batchnorm/add_1 -> [24,75,75]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/batchnorm/add_1
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/expand/weights[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_2/expand/weights -> [1,1,24,144]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/expand/weights
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/expand/Conv2D[Op: Conv]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/batchnorm/add_1, FeatureExtractor/MobilenetV2/expanded_conv_2/expand/weights
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_2/expand/Conv2D -> [144,75,75]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/expand/Conv2D
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/moving_variance[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/moving_variance -> [144]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/moving_variance
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/batchnorm/add/y[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/batchnorm/add/y -> []
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/batchnorm/add/y
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/batchnorm/add[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/moving_variance, FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/batchnorm/add/y
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/batchnorm/Rsqrt[Op: Unary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/batchnorm/add
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/batchnorm/Rsqrt
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/gamma[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/gamma -> [144]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/gamma
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/batchnorm/mul[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/batchnorm/Rsqrt, FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/gamma
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/batchnorm/mul
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/batchnorm/mul_1[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_2/expand/Conv2D, FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/batchnorm/mul
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/batchnorm/mul_1 -> [144,75,75]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/batchnorm/mul_1
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/beta[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/beta -> [144]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/beta
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/moving_mean[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/moving_mean -> [144]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/moving_mean
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/batchnorm/mul_2[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/moving_mean, FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/batchnorm/mul
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/batchnorm/mul_2
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/batchnorm/sub[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/beta, FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/batchnorm/mul_2
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/batchnorm/sub
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/batchnorm/add_1[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/batchnorm/mul_1, FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/batchnorm/sub
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/batchnorm/add_1 -> [144,75,75]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/batchnorm/add_1
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/expand/Relu6[Op: Activation]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_2/expand/BatchNorm/batchnorm/add_1
[TRT]    Setting dynamic range for (Unnamed Layer* 67) [Activation]_output to [0,6]
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_2/expand/Relu6 -> [144,75,75]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/expand/Relu6
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/depthwise_weights[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/depthwise_weights -> [3,3,144,1]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/depthwise_weights
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/depthwise[Op: Conv]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_2/expand/Relu6, FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/depthwise_weights
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/depthwise -> [144,75,75]
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/moving_variance[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/moving_variance -> [144]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/moving_variance
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/batchnorm/add/y[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/batchnorm/add/y -> []
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/batchnorm/add/y
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/batchnorm/add[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/moving_variance, FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/batchnorm/add/y
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/batchnorm/Rsqrt[Op: Unary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/batchnorm/add
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/batchnorm/Rsqrt
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/gamma[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/gamma -> [144]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/gamma
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/batchnorm/mul[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/batchnorm/Rsqrt, FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/gamma
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/batchnorm/mul
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/batchnorm/mul_1[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/depthwise, FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/batchnorm/mul
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/batchnorm/mul_1 -> [144,75,75]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/batchnorm/mul_1
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/beta[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/beta -> [144]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/beta
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/moving_mean[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/moving_mean -> [144]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/moving_mean
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/batchnorm/mul_2[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/moving_mean, FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/batchnorm/mul
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/batchnorm/mul_2
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/batchnorm/sub[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/beta, FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/batchnorm/mul_2
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/batchnorm/sub
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/batchnorm/add_1[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/batchnorm/mul_1, FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/batchnorm/sub
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/batchnorm/add_1 -> [144,75,75]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/batchnorm/add_1
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/Relu6[Op: Activation]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/BatchNorm/batchnorm/add_1
[TRT]    Setting dynamic range for (Unnamed Layer* 77) [Activation]_output to [0,6]
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/Relu6 -> [144,75,75]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/Relu6
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/project/weights[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_2/project/weights -> [1,1,144,24]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/project/weights
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/project/Conv2D[Op: Conv]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_2/depthwise/Relu6, FeatureExtractor/MobilenetV2/expanded_conv_2/project/weights
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_2/project/Conv2D -> [24,75,75]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/project/Conv2D
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/moving_variance[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/moving_variance -> [24]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/moving_variance
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/batchnorm/add/y[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/batchnorm/add/y -> []
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/batchnorm/add/y
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/batchnorm/add[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/moving_variance, FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/batchnorm/add/y
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/batchnorm/Rsqrt[Op: Unary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/batchnorm/add
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/batchnorm/Rsqrt
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/gamma[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/gamma -> [24]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/gamma
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/batchnorm/mul[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/batchnorm/Rsqrt, FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/gamma
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/batchnorm/mul
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/batchnorm/mul_1[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_2/project/Conv2D, FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/batchnorm/mul
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/batchnorm/mul_1 -> [24,75,75]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/batchnorm/mul_1
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/beta[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/beta -> [24]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/beta
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/moving_mean[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/moving_mean -> [24]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/moving_mean
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/batchnorm/mul_2[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/moving_mean, FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/batchnorm/mul
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/batchnorm/mul_2
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/batchnorm/sub[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/beta, FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/batchnorm/mul_2
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/batchnorm/sub
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/batchnorm/add_1[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/batchnorm/mul_1, FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/batchnorm/sub
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/batchnorm/add_1 -> [24,75,75]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/batchnorm/add_1
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_2/add[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_2/project/BatchNorm/batchnorm/add_1, FeatureExtractor/MobilenetV2/expanded_conv_1/project/BatchNorm/batchnorm/add_1
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_2/add -> [24,75,75]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_2/add
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_3/expand/weights[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_3/expand/weights -> [1,1,24,144]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_3/expand/weights
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_3/expand/Conv2D[Op: Conv]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_2/add, FeatureExtractor/MobilenetV2/expanded_conv_3/expand/weights
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_3/expand/Conv2D -> [144,75,75]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_3/expand/Conv2D
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_3/expand/BatchNorm/moving_variance[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_3/expand/BatchNorm/moving_variance -> [144]
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_3/expand/BatchNorm/moving_variance
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_3/expand/BatchNorm/batchnorm/add/y[Op: Const].
[TRT]    UFFParser: FeatureExtractor/MobilenetV2/expanded_conv_3/expand/BatchNorm/batchnorm/add/y -> []
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_3/expand/BatchNorm/batchnorm/add/y
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_3/expand/BatchNorm/batchnorm/add[Op: Binary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_3/expand/BatchNorm/moving_variance, FeatureExtractor/MobilenetV2/expanded_conv_3/expand/BatchNorm/batchnorm/add/y
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_3/expand/BatchNorm/batchnorm/Rsqrt[Op: Unary]. Inputs: FeatureExtractor/MobilenetV2/expanded_conv_3/expand/BatchNorm/batchnorm/add
[TRT]    UFFParser: Applying order forwarding to: FeatureExtractor/MobilenetV2/expanded_conv_3/expand/BatchNorm/batchnorm/Rsqrt
[TRT]    UFFParser: Parsing FeatureExtractor/MobilenetV2/expanded_conv_3/expand/BatchNorm/gamma[Op: Const].
Somehow it is not able to find the layer blobs from the network model.
I tried many things to resolve this problem like reflashing the SD card then manually downloaded DNN models mirror but still no luck.
Can you help me to resolve this problem?
Regards,
Vikas Dwivedi
hi @vikas.wfh, is there additional log output? I don’t see any error in the log. Maybe it just needs to keep running?
