Feature extraction via SGIE
Hi there!
I am trying to do a recognition-based task on the Jetson Xavier for a project using the DS Python bindings.
I figured I could use the pgie for detection, and the sgie for feature extraction.
So far, the pgie works well for detection (courtesy of this repo - GitHub - NVIDIA-AI-IOT/redaction_with_deepstream: An example of using DeepStream SDK for redaction), but the sgie fails to feature extraction (I’m using an ONNX model).
Here’s my sgie config file:
[property]
gpu-id=0
onnx-file=…/arcfaceresnet100.onnx
batch-size=1
process-mode=1
model-color-format=0
network-mode=1
interval=0
gie-unique-id=2
output-blob-names=id
#parse-bbox-func-name=NvDsInferParseCustomResnet
#custom-lib-path=/path/to/libnvdsparsebbox.so
#enable-dbscan=1
operate-on-gie-id=1
operate-on-class-ids=0
Is this in the realm of using parse-bbox-bounding-box or just setting up the sgie config file appropriately to output feature vectors?
I’m running on Jetson AGX Xavier with DS 5.0 / Jetson 4.3 Developer Preview / TensorRT version 7.1.0-1+cuda10.2.
Thanks in advance for the help!
May I know the model of your sgie? Can it use curent DeepStream post-processing?
I was trying to use ArcFace after extracting the bounding box…
As far as I know, it cannot use DeepStream post-processing, but I don’t know too much about that.
I found a TensorRT solution here: https://medium.com/@penolove15/face-recognition-with-arcface-with-tensorrt-abb544738e39
The same model (as implemented in ONNX) can be found here:
https://github.com/onnx/models/tree/master/vision/body_analysis/arcface
And the original original ArcFace can be found here:
Hi @patrick.g.tinsley,
Sorry for delay!
If you can’t use current post-processing DeepStream provided, you could refer to nvdsinfer_custombboxparser_ssd_tlt.cpp to register a post-processor to parse the inference output
Hi @mchi – thank you for your response!
I looked at the example you suggested with clipping/NMS, but I’m looking for a way for the parser to actually deal with the frame data itself in the context of feature extraction. Any ideas?
PT
sorry, I don’t get the point, could you make it more clear?
It seems that the custom-bbox-parser-function doesn’t interact with the frame pixel data itself, since it relies on either detect or classify output. However, the pixel data itself would be needed for extracting facial features for a given model. I suppose I could maybe add another parameter to the parser function itself (that being the raw data), but I was wondering if there is an existing pipeline for doing this type of detect-and-process-on-a-bbox task.
Sorry for long delay! Not sure if you have found out the solution. for your question, if you can acceess the corresponding frame, can it meet your requirement?
were you able to solve that issue?
Nope, but have been revisiting this recently…
I think this might be helpful: Deepstream for face recognition
Lmk if you find anything helpful as well – thanks!
Do you actually have a solution to this? The .cpp file you suggested doesn’t look to do the same thing. Even so, it would be nice to keep consistency with the rest of the deepstream-python-apps. If I find anything, I’ll let you know. Thank you!
I got ya. Makes sense – thanks for the pointer/help!
Hi @patrick.g.tinsley !
I hope you are doing well.
Can you please let me know if this was solved?
Thank you
@ahsanmuhammadakram1996 You can submit a new topic with your enviornment and issues in details to start the discussion, it’s difficult to trace back the discussion happened more than one year ago, thanks.
