NVIDIA Open GPU Kernel Modules Version
530.41.03
Operating System and Version
Fedora 38 - Gnome 44
Kernel Release
6.2.8-300.fc38.x86_64
Hardware: GPU
NVIDIA GeForce GTX 1650 SUPER (UUID: GPU-1b82f730-b99a-4e6a-32b8-a1f703cb5034)
Describe the bug
Nvidia on wayland is working really fine right now, but I insist, we really need g-sync (vrr) to work on wayland, mostly on low end cards that can’t keep high frame rates always, the experience in games is horrible when you get lower fps that your monitor hz.
(option to enable vrr is showing on gnome or kde control center but is not working properly, the monitor just lower randomly and inacurrate the hz on some moments, nothing that help, atleast we are somehow close)
To Reproduce
-Have a g-sync (or g-sync compatible) monitor, with a nvidia card, use the drivers for linux
-Install any GNU/LINUX distro, with a desktop that have wayland working (example:gnome, kde)
-Patch gnome with vrr if is necessary, on kde is enabled by default, go to monitor settings and enable vrr.
-Test vrr on a game or on a special test for it
Results: g-sync still not working on wayland, we really need this.
