I have a problem with new SDK 3.1 and the new driver 256.35.
My code compiles and runs perfectly on Fedora 10.
However, when I compile and run the code on Fedora 12, the following happens:
The first time after the boot, the code runs, with no errors or signs of trouble.
The second time, the code fails to find GPU with the followng error:
NVIDIA: could not open the device file /dev/nvidia0 (Input/output error)
After the error, the only way to bring to the working state is to reboot.
Anyone knows why this happens and how to overcome this problem ?
I have seen something similar happen on my laptop as well.
Got frustrated, moved to archlinux.
256.35 and 256.44 both work nicely on OpenSuSE 11.3. gcc is 4.5.0. Tested both on a laptop with one GT 330M (Samsung R580) and a desktop with two GTX 460.
MFago
August 15, 2010, 6:13am
#6
How well does CUDA 3.1 (SDK etc) work with OpenSuSE 11.3? Any issues due to official support only for 11.2?
MFago
#7
annkok
August 19, 2010, 4:04am
#8
add
vmalloc=256M
to you grub boot command,like:
/boot/vmlinuz-2.6.32-24-generic-pae ro quiet splash vmalloc=256M
maybe help you!
annkok
#9
add
vmalloc=256M
maybe help you!
pavanky
August 19, 2010, 9:31pm
#10
Do you have kmod-nvidia installed on your machine ? If so, try disabling it and reinstall the 256.35 driver again.
pavanky
#11
