I was asked to set up a headless machine using a GTX 1080 for video transcoding acceleration, and under load I get “Cannot init CUDA” error from ffmpeg, nvidia-smi reports “No devices were found”, and all of this is accompanied by “rm_init_adapter failed” kernel messages.
bug-report: nvidia-bug-report.log.gz
FFmpeg reports it cannot init CUDA (using verbose logging here):
[graph_1_in_0_1 @ 0x55ed1b4980c0] tb:1/48000 samplefmt:fltp samplerate:48000 chlayout:0x60f
[format_out_0_1 @ 0x55ed1b498c80] auto-inserting filter 'auto_resampler_0' between the filter 'Parsed_anull_0' and the filter 'format_out_0_1'
[auto_resampler_0 @ 0x55ed1b498a80] ch:6 chl:5.1(side) fmt:fltp r:48000Hz -> ch:2 chl:stereo fmt:fltp r:48000Hz
[graph 0 input from stream 0:0 @ 0x55ed1d2e2b40] w:1920 h:1080 pixfmt:yuv420p10le tb:1/1000 fr:24000/1001 sar:1/1 sws_param:flags=2
[scaler_out_0_0 @ 0x55ed1d2e3800] w:1280 h:720 flags:'bicubic' interl:0
[scaler_out_0_0 @ 0x55ed1d2e3800] w:1920 h:1080 fmt:yuv420p10le sar:1/1 -> w:1280 h:720 fmt:yuv420p sar:1/1 flags:0x4
[h264_nvenc @ 0x55ed1b42da40] Loaded Nvenc version 9.0
[h264_nvenc @ 0x55ed1b42da40] Nvenc initialized successfully
[h264_nvenc @ 0x55ed1b42da40] Cannot init CUDA
[h264_nvenc @ 0x55ed1b42da40] Nvenc unloaded
Error initializing output stream 0:0 -- Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height
dmesg is basically flooded by these messages
[608628.794213] NVRM: RmInitAdapter failed! (0x25:0x51:1084)
[608628.801279] NVRM: rm_init_adapter failed for device bearing minor number 0
Calling nvidia-smi in a loop does make it through, eventually, but most of the time I get “No devices were found”.
This happens within a day of starting encoding tasks and lasts even after the load is gone. Resetting GPU (using “nvidia-smi -r”) doesn’t really help. The only way to fix this is to reboot.
I didn’t have any issues during test-runs (ran transcoding a single video in a loop over weekend).
Machine is running Ubuntu 16.04 (upgraded from 14.04), 4.16.3 mainline kernel, nvidia-418 drivers and FFmpeg 4.1.3 (from this PPA, rebuilt with “–enable-nvenc --enable-cuda”, mostly following this guide).
gendalph@d5528:~$ ffmpeg -version
ffmpeg version 4.1.3-0local~16.04 Copyright (c) 2000-2019 the FFmpeg developers
built with gcc 5.4.0 (Ubuntu 5.4.0-6ubuntu1~16.04.11) 20160609
configuration: --prefix=/usr --extra-version='0local~16.04' --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-nonfree --enable-libfdk-aac --enable-nvenc --enable-cuda --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
libavutil 56. 22.100 / 56. 22.100
libavcodec 58. 35.100 / 58. 35.100
libavformat 58. 20.100 / 58. 20.100
libavdevice 58. 5.100 / 58. 5.100
libavfilter 7. 40.101 / 7. 40.101<a target='_blank' rel='noopener noreferrer' href=''></a>
libavresample 4. 0. 0 / 4. 0. 0
libswscale 5. 3.100 / 5. 3.100
libswresample 3. 3.100 / 3. 3.100
libpostproc 55. 3.100 / 55. 3.100
FFmpeg command line:
ffmpeg -y -i video.mkv -vcodec h264_nvenc -acodec aac -b:v 3000k -g 25 -threads 16 -vsync 2 -s 1920x1080 -movflags +faststart -map 0:0 -map 0:1 -b:a 192k -ac 2 video.mp4
Ubuntu 14.04 had the same issue, but much more severe. It had CUDA 8.0 installed, with 384.111 drivers, 4.4.0-121-generic kernel and ffmpeg 3.3.2.
