FFMpeg h264_cuvid failed
DGPU: T4
NVIDIA GPU Driver Version: 450.80.02
Docker: nvcr.io/nvidia/deepstream:5.0-dp-20.04-triton
FFMpeg h264_cuvid decoding failed.
# ffmpeg -y  -c:v h264_cuvid -i /opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4 out.yuv
ffmpeg version 4.3.1 Copyright (c) 2000-2020 the FFmpeg developers
  built with gcc 7 (Ubuntu 7.5.0-3ubuntu1~18.04)
  configuration: --enable-cuda-nvcc --enable-cuvid --enable-nvenc --enable-nonfree --enable-libnpp --extra-cflags=-I/usr/local/cuda/include --extra-ldflags=-L/usr/local/cuda/lib64
  libavutil      56. 51.100 / 56. 51.100
  libavcodec     58. 91.100 / 58. 91.100
  libavformat    58. 45.100 / 58. 45.100
  libavdevice    58. 10.100 / 58. 10.100
  libavfilter     7. 85.100 /  7. 85.100
  libswscale      5.  7.100 /  5.  7.100
  libswresample   3.  7.100 /  3.  7.100
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4':
  Metadata:
    major_brand     : isom
    minor_version   : 512
    compatible_brands: isomiso2avc1mp41
    encoder         : Lavf56.40.101
  Duration: 00:00:48.10, start: 0.000000, bitrate: 5813 kb/s
    Stream #0:0(eng): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 1920x1080, 5675 kb/s, 30 fps, 30 tbr, 15360 tbn, 60 tbc (default)
    Metadata:
      handler_name    : VideoHandler
    Stream #0:1(eng): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 128 kb/s (default)
    Metadata:
      handler_name    : SoundHandler
[h264_cuvid @ 0x5616cad60940] ctx->cvdl->cuvidGetDecoderCaps(&ctx->caps8) failed
[h264_cuvid @ 0x5616cad60940] ctx->cvdl->cuvidGetDecoderCaps(&ctx->caps10) failed
[h264_cuvid @ 0x5616cad60940] ctx->cvdl->cuvidGetDecoderCaps(&ctx->caps12) failed
Stream mapping:
  Stream #0:0 -> #0:0 (h264 (h264_cuvid) -> rawvideo (native))
Error while opening decoder for input stream #0:0 : Generic error in an external library
any help?
