Financial Fraud Detection Blueprint on ARM64?
System Configuration
  • Hardware: NVIDIA DGX Spark with GB10 GPU
  • Architecture: ARM64 (aarch64)
  • OS: Ubuntu 24.04
  • CUDA: 13.0
  • Driver: 580.95.05
  • Docker: 28.5.1
Issue Summary
Successfully running the Financial Fraud Detection Blueprint on ARM64, but encountering data format incompatibility between preprocessing output and container v2.0.0 expectations.
What’s Working ✅
  1. Environment Setup (ARM64):
    • RAPIDS cuDF 25.10 installed and working perfectly on ARM64
    • Conda environment with CUDA 13.0 support
    • GPU acceleration confirmed
  2. Data Preprocessing:
    • Successfully downloaded IBM TabFormer dataset (2.2GB)
    • Preprocessing completed using the blueprint’s preprocess_TabFormer script
    • Generated graph structure with fraud correlations identified
    • Created files in /data/TabFormer/gnn/ directory structure:
    • gnn/├── edges/│   └── node_to_node.csv├── nodes/│   ├── node.csv│   ├── node_label.csv│   └── offset_range_of_training_node.json└── test_gnn/    ├── edges/    │   └── node_to_node.csv    └── nodes/        ├── node.csv        └── node_label.csv
  3. Container v2.0.0 ARM64:
    • Successfully pulled nvcr.io/nvidia/cugraph/financial-fraud-training:2.0.0
    • Confirmed ARM64 architecture in manifest
    • Container starts without platform mismatch warnings
The Problem ❌
Error Message:
ERROR: Invalid Dataset: No label file found.
Exactly one '<A_rel_B>_label.<ext>' must exist across all edges.
Root Cause: The preprocessing script (from the v1.0.1 blueprint) generates edge files named node_to_node.csv, but container v2.0.0 expects edge files following the pattern <A_rel_B>_label.<ext> (e.g., user_transacts_merchant_label.csv).
Configuration Used:
  "paths": {
    "data_dir": "/data",
    "output_dir": "/trained_models"
  "models": [
      "kind": "GNN_XGBoost",
      "gpu": "single",
      "hyperparameters": {
        "gnn": {
          "hidden_channels": 16,
          "n_hops": 2,
          "layer": "TransformerConv",
          "dropout_prob": 0.3,
          "batch_size": 2048,
          "fan_out": 8,
          "num_epochs": 8
        "xgb": {
          "max_depth": 6,
          "learning_rate": 0.2,
          "num_parallel_tree": 3,
          "num_boost_round": 512,
          "gamma": 0.0
Questions for NVIDIA
  1. Data Format for v2.0.0:
    • What is the expected directory structure and file naming convention for v2.0.0?
    • Has the data format changed between v1.0.1 and v2.0.0?
    • Is there updated preprocessing code for v2.0.0?
  2. ARM64 Support:
    • Is there (or will there be) an ARM64 build of v1.0.1 that matches the existing preprocessing output?
    • What is the recommended approach for ARM64 users?
  3. Documentation:
    • Where can I find v2.0.0-specific documentation for the data format requirements?
    • Are there example datasets formatted correctly for v2.0.0?
Attempted Solutions
  • ✅ Used example config from container (example_training_config_gnn_xgboost.json)
  • ✅ Verified config validation passes
  • ✅ Confirmed all volume mounts are correct
  • ✅ Preprocessing completed without errors
  • ❌ Data format mismatch prevents training from starting
Additional Context
  • The GitHub blueprint repository (NVIDIA-AI-Blueprints/financial-fraud-detection) contains preprocessing code that appears designed for v1.0.1
  • No ARM64-specific documentation found
  • Successfully used v2.0.0 ARM64 container (no emulation warnings)
Request
Either:
  1. ARM64 build of v1.0.1 (compatible with existing preprocessing), OR
  2. Updated preprocessing code for v2.0.0 data format, OR
  3. Documentation on v2.0.0’s expected data structure
