I have a Drive AGX Orin device which has these versions of cuda, trt and cudnn installed:
libnvinfer-bin 8.6.11.4-1+cuda11.4 arm64 TensorRT binaries
libnvinfer-dispatch8 8.6.11.4-1+cuda11.4 arm64 TensorRT dispatch runtime library
libnvinfer-lean8 8.6.11.4-1+cuda11.4 arm64 TensorRT lean runtime library
libnvinfer-plugin8 8.6.11.4-1+cuda11.4 arm64 TensorRT plugin libraries
libnvinfer-vc-plugin8 8.6.11.4-1+cuda11.4 arm64 TensorRT vc-plugin library
libnvinfer8 8.6.11.4-1+cuda11.4 arm64 TensorRT runtime libraries
python3-libnvinfer 8.6.11.4-1+cuda11.4 arm64 Python 3 bindings for TensorRT standard time
libcudnn8 8.9.2.19-1+cuda11.4 arm64 cuDNN runtime libraries
I want to install the same packages on my ARM PC to have an environment as similar as possible to the Orin device. But I can’t find the same version of these packages among NVIDIA’s package lists. So far I’ve checked the entire list here and here but none of the debian packages exactly match the ones I have on my Drive AGX Orin device which has been flashed with DriveOS 8.0.6.
