Finding / Updating Device Tree
I’m new to using the Jetsons and am trying to edit the device tree to keep the pcie controller from powering down. I’ve seen it mentioned in several articles, but I can’t figure out how to edit / update the device tree. I’m not even sure where to find it tbh.
For example, it’s mentioned here:
I’m just not sure where to find it / update it on my Orin. Thanks for any help
Hello @adams2,
You coud check the following 2 files:
kernel/nvidia/drivers/pci/dwc/pcie-tegra.c
and
hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-pcie.dtsi
I was not able to find nvidia,enable-power-down anywhere, but you could find something useful in there.
regards,
Andrew
Embedded Software Engineer
Where are those “kernel” and “hardware” folders found? Are they located in the “Linux_for_Tegra” directory? Are they somewhere on the orin after it is flashed?
I downloaded the files shown in the screenshot below for Jetson Linux 36.3:
In the files that I got there, I don’t have the hardware folder in my main “Linux_for_Tegra” folder.
Hello @adams2,
That is a great question!
Those files are part of the NVIDIA Jetpack sources.
You can download them by running the source_sync.sh script inside Linux_For_Tegra. You need to provide the -t tag parameter for the script to sync your sources to a specific Jetpack release, in your case you can run the following:
./source_sync.sh -k -t rel-36_eng_2023-10-04
That will download the sources file, inside you should find the directories I mentioned.
Please let us know if you require further assistance with modifying and building the sources.
regards,
Andrew
Hello adams2
You can donwload the sources from “Driver Package (BSP) Sources” or get the kernel source, running the source_sync.sh script
Please see here the instructions of how to build the kernel and device tree.
https://docs.nvidia.com/jetson/archives/r36.3/DeveloperGuide/SD/Kernel/KernelCustomization.html#building-the-dtbs
Manuel Leiva
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com
Website: www.ridgerun.com
Hello @adams2,
Manuel is right, you can also get the sources from “Driver Package (BSP) Sources”.
Here is the link in case you might be wondering where to find that:
Please keep us posted, we would love to help if you have further questions.
If this is your first time doing kernel customization and building, it might seem overwhelming, however, you will see it gets easier with practice.
regards,
Andrew
Andrew / Manuel,
It does feel a little overwhelming lol.
I had already pulled the sources manually by following the instructions here :
https://docs.nvidia.com/jetson/archives/r36.3/DeveloperGuide/SD/Kernel/KernelCustomization.html#to-manually-download-and-expand-the-kernel-sources
But my file system doesn’t have what you described earlier:
the source/hardware/nvidia folder contains the “t23x” directly, and it contains a “nv-public” folder. When I run “ls -R | grep pci” in the /source/hardware folder, it returns nothing.
@adams2,
No worries, we will try to get you through this.
Can you please try downloading the sources using the sources_sync script?
I usually rather use the script than downloading everything by hand.
regards,
Andrew
when I run the script, I get this output:
Directory for kernel/kernel-jammy-src, /home/orin_flasher/Documents/Linux_for_Tegra/source/kernel/kernel-jammy-src, already exists!
fatal: not a git repository (or any of the parent directories): .git
But the directory is not a git repository – clean it up first
Directory for nvgpu, /home/orin_flasher/Documents/Linux_for_Tegra/source/nvgpu, already exists!
Directory for nvidia-oot, /home/orin_flasher/Documents/Linux_for_Tegra/source/nvidia-oot, already exists!
Directory for hwpm, /home/orin_flasher/Documents/Linux_for_Tegra/source/hwpm, already exists!
Directory for nvethernetrm, /home/orin_flasher/Documents/Linux_for_Tegra/source/nvethernetrm, already exists!
Directory for hardware/nvidia/t23x/nv-public, /home/orin_flasher/Documents/Linux_for_Tegra/source/hardware/nvidia/t23x/nv-public, already exists!
Directory for hardware/nvidia/tegra/nv-public, /home/orin_flasher/Documents/Linux_for_Tegra/source/hardware/nvidia/tegra/nv-public, already exists!
Directory for nvdisplay, /home/orin_flasher/Documents/Linux_for_Tegra/source/nvdisplay, already exists!
Downloading default dtc-src/1.4.5 source…
Cloning into ‘/home/orin_flasher/Documents/Linux_for_Tegra/source/dtc-src/1.4.5’…
fatal: unable to connect to nv-tegra.nvidia.com:
nv-tegra.nvidia.com[0: 34.216.216.36]: errno=Connection timed out
nv-tegra.nvidia.com[1: 35.82.181.43]: errno=Connection timed out
/home/orin_flasher/Documents/Linux_for_Tegra/source/dtc-src/1.4.5 source sync failed!
@kayccc ,
I ran out of time at my company to research this, so I am needing to move on to other things. My original issue was that I wanted to use the wifi-card slot to insert a different device, but the device tree is set up to read 2 different devices on that port. This is because it considers the wifi card and the Bluetooth radio as different devices. For me to change that to only read it as 1 device would take more time than I can allot to this project.
To directly answer your question, yes I was able to find and edit the device tree, but it would have been more work to change than was worth it. I also had to re-flash my computer that I had the source files on so I don’t have them available anymore to reference (sorry). Thank you for the assistance :)
