Hi to all this is my first install of cuda on my new laptop with the gt 635m chip.
I,m running backtrack 5 r3 ive installed my drivers from the nvidia web site and installed cuda toolkit but when i test cuda with the nvcc -v command i get the following error nvcc fatal : No input files specified can anyone tel me what is the error and how to solve it. I,m very new to backtrack and cuda so please be gentle with me thanks.
P.S I,m not useing optirun i just want the gt635m for pyrit use thanks for any help given.
It is exactly what it says.The -v flag is not correct. here is a list with all the flags:
$ nvcc -v
nvcc fatal : No input files specified; use option --help for more information
cva@Tractor:/Remorca_W/NewWork/YukawaFinalCorrelationsVerletCriteria/newderiv/ERY/524288/lolo/RYfirst/NGlambda09.0$ nvcc --help
Usage : nvcc [options] <inputfile>
Options for specifying the compilation phase
More exactly, this option specifies up to which stage the input files must be
compiled, according to the following compilation trajectories for different
input file types:
.c/.cc/.cpp/.cxx : preprocess, compile, link
.o : link
.i/.ii : compile, link
.cu : preprocess, cuda frontend, ptxassemble,
merge with host C code, compile, link
.gpu : cicc compile into cubin
.ptx : ptxassemble into cubin.
--cuda (-cuda)
Compile all .cu input files to .cu.cpp.ii output.
--cubin (-cubin)
Compile all .cu/.ptx/.gpu input files to device- only .cubin files.
This step discards the host code for each .cu input file.
--fatbin(-fatbin)
Compile all .cu/.ptx/.gpu input files to ptx or device- only .cubin
files (depending on the values specified for options '-arch' and/or
'-code') and place the result into the fat binary file specified with
option -o.
--ptx (-ptx)
Compile all .cu/.gpu input files to device- only .ptx files. This step
discards the host code for each of these input file.
--gpu (-gpu)
Compile all .cu input files to device-only .gpu files. This step
--preprocess (-E)
Preprocess all .c/.cc/.cpp/.cxx/.cu input files.
--generate-dependencies (-M)
Generate for the one .c/.cc/.cpp/.cxx/.cu input file (more than one
input file is not allowed in this mode) a dependency file that can be
included in a make file.
--compile (-c)
Compile each .c/.cc/.cpp/.cxx/.cu input file into an object file.
--device-c (-dc)
Compile each .c/.cc/.cpp/.cxx/.cu input file into an object file that
contains relocatable device code. It is equivalent to
'--relocatable-device-code=true --compile'.
--device-w (-dw)
contains executable device code. It is equivalent to
'--relocatable-device-code=false --compile'.
--device-link (-dlink)
Link object files with relocatable device code and .ptx/.cubin/.fatbin
files into an object file with executable device code, which can be
passed to the host linker.
--link (-link)
This option specifies the default behavior: compile and link all inputs
--lib (-lib)
Compile all inputs into object files (if necessary) and add the results
to the specified output library file.
--x (-x)
Explicitly specify the language for the input files, rather than
letting the compiler choose a default based on the file name suffix.
Allowed values for this option: 'c','c++','cu'.
--run (-run)
This option compiles and links all inputs into an executable, and
executes it. Or, when the input is a single executable, it is executed
without any compilation or linking. This step is intended for
developers who do not want to be bothered with setting the necessary
cuda dll search paths (these will be set temporarily by nvcc).
File and path specifications
--output-file <file> (-o)
Specify name and location of the output file. Only a single input file
is allowed when this option is present in nvcc non- linking/archiving
mode.
--pre-include <include-file>,... (-include)
Specify header files that must be preincluded during preprocessing.
--library <library>,... (-l)
Specify libraries to be used in the linking stage without the library
file extension. The libraries are searched for on the library search
paths that have been specified using option '-L'.
--define-macro <macrodef>,... (-D)
Specify macro definitions to define for use during preprocessing or
compilation.
--undefine-macro <macrodef>,... (-U)
Specify macro definitions to undefine for use during preprocessing or
compilation.
--include-path <include-path>,... (-I)
Specify include search paths.
--system-include <include-path>,... (-isystem)
Specify system include search paths.
--library-path <library-path>,... (-L)
Specify library search paths.
--output-directory <directory> (-odir)
Specify the directory of the output file. This option is intended for
letting the dependency generation step (option
'--generate-dependencies') generate a rule that defines the target
object file in the proper directory.
--compiler-bindir <path> (-ccbin)
Specify the directory in which the compiler executable (Microsoft
Visual Studio cl, or a gcc derivative) resides. By default, this
executable is expected in the current executable search path. For a
different compiler, or to specify these compilers with a different
executable name, specify the path to the compiler including the
executable name.
--cl-version <cl-version-number> --cl-version <cl-version-number>
Specify the version of Microsoft Visual Studio Installation.
Allowed values for this option: 2005,2008,2010.
Default value: 2005.
--use-local-env --use-local-env
Specify whether the environment is already set up for the host compiler
Options for specifying behaviour of compiler/linker
--profile (-pg)
Instrument generated code/executable for use by gprof (Linux only).
--debug (-g)
Generate debug information for host code.
--device-debug (-G)
Generate debug information for device code.
--generate-line-info (-lineinfo)
Generate line-number information for device code.
--optimize <level> (-O)
Specify optimization level for host code.
--shared(-shared)
Generate a shared library during linking. Note: when other linker
options are required for controlling dll generation, use option
-Xlinker.
--machine <bits> (-m)
Specify 32 vs 64 bit architecture.
Allowed values for this option: 32,64.
Default value: 64.
Options for passing specific phase options
These allow for passing options directly to the intended compilation phase.
Using these, users have the ability to pass options to the lower level
compilation tools, without the need for nvcc to know about each and every such
option.
--compiler-options <options>,... (-Xcompiler)
Specify options directly to the compiler/preprocessor.
--linker-options <options>,... (-Xlinker)
Specify options directly to the linker.
--archive-options <options>,... (-Xarchive)
Specify options directly to library manager.
--cudafe-options <options>,... (-Xcudafe)
Specify options directly to cudafe.
--ptxas-options <options>,... (-Xptxas)
Specify options directly to the ptx optimizing assembler.
Miscellaneous options for guiding the compiler driver
--dont-use-profile (-noprof)
Nvcc uses the nvcc.profiles file for compilation. When specifying this
option, the profile file is not used.
--dryrun(-dryrun)
Do not execute the compilation commands generated by nvcc. Instead,
list them.
--verbose (-v)
List the compilation commands generated by this compiler driver, but do
not suppress their execution.
--keep (-keep)
Keep all intermediate files that are generated during internal
compilation steps.
--keep-dir (-keep-dir)
compilation steps in this directory.
--save-temps (-save-temps)
This option is an alias of '--keep'.
--clean-targets (-clean)
This option reverses the behaviour of nvcc. When specified, none of the
compilation phases will be executed. Instead, all of the non- temporary
files that nvcc would otherwise create will be deleted.
--run-args <arguments>,... (-run-args)
Used in combination with option -R, to specify command line arguments
for the executable.
--input-drive-prefix <prefix> (-idp)
On Windows platforms, all command line arguments that refer to file
names must be converted to Windows native format before they are passed
to pure Windows executables. This option specifies how the 'current'
development environment represents absolute paths. Use '-idp /cygwin/'
for CygWin build environments, and '-idp /' for Mingw.
--dependency-drive-prefix <prefix> (-ddp)
On Windows platforms, when generating dependency files (option -M), all
file names must be converted to whatever the used instance of 'make'
will recognize. Some instances of 'make' have trouble with the colon in
absolute paths in native Windows format, which depends on the
environment in which this 'make' instance has been compiled. Use '-ddp
/cygwin/' for a CygWin make, and '-ddp /' for Mingw. Or leave these
file names in native Windows format by specifying nothing.
--drive-prefix <prefix> (-dp)
Specifies <prefix> as both input-drive-prefix and
dependency-drive-prefix.
--no-align-double --no-align-double
Specifies that -malign-double should not be passed as a compiler
argument on 32-bit platforms. WARNING: this makes the ABI incompatible
with the cuda's kernel ABI for certain 64-bit types.
Options for steering GPU code generation
--gpu-architecture <gpu architecture name> (-arch)
Specify the name of the class of nVidia GPU architectures for which the
cuda input files must be compiled.
With the exception as described for the shorthand below, the
architecture specified with this option must be a virtual architecture
(such as compute_10), and it will be the assumed architecture during
the cicc compilation stage.
This option will cause no code to be generated (that is the role of
nvcc option '--gpu-code', see below); rather, its purpose is to steer
the cicc stage, influencing the architecture of the generated ptx
intermediate.
For convenience in case of simple nvcc compilations the following
shorthand is supported: if no value for option '--gpu-code' is
specified, then the value of this option defaults to the value of
'--gpu-architecture'. In this situation, as only exception to the
description above, the value specified for '--gpu-architecture' may be
a 'real' architecture (such as a sm_13), in which case nvcc uses the
closest virtual architecture as effective architecture value. For
example, 'nvcc -arch=sm_13' is equivalent to 'nvcc -arch=compute_13
-code=sm_13'.
Allowed values for this option: 'compute_10','compute_11','compute_12',
'compute_13','compute_20','compute_30','compute_35','sm_10','sm_11',
'sm_12','sm_13','sm_20','sm_21','sm_30','sm_35'.
--gpu-code <gpu architecture name>,... (-code)
Specify the names of nVidia gpus to generate code for.
nvcc will embed a compiled code image in the resulting executable for
each specified 'code' architecture. This code image will be a true
binary load image for each 'real' architecture (such as a sm_13), and
ptx intermediate code for each virtual architecture (such as
compute_10). During runtime, in case no better binary load image is
found, and provided that the ptx architecture is compatible with the
'current' GPU, such embedded ptx code will be dynamically translated
for this current GPU by the cuda runtime system.
Architectures specified for this option can be virtual as well as real,
but each of these 'code' architectures must be compatible with the
architecture specified with option '--gpu-architecture'.
For instance, 'arch'=compute_13 is not compatible with 'code'=sm_10,
because the generated ptx code will assume the availability of
compute_13 features that are not present on sm_10.
--generate-code (-gencode)
This option provides a generalization of the '--gpu-architecture=<arch>
--gpu-code=code,...' option combination for specifying nvcc behavior
with respect to code generation. Where use of the previous options
generates different code for a fixed virtual architecture, option
'--generate-code' allows multiple cicc invocations, iterating over
different virtual architectures. In fact,
'--gpu-architecture=<arch> --gpu-code=<code>,...'
is equivalent to
'--generate-code arch=<arch>,code=<code>,...'.
'--generate-code' options may be repeated for different virtual
architectures.
Allowed keywords for this option: 'arch','code'.
--maxrregcount <N> (-maxrregcount)
Specify the maximum amount of registers that GPU functions can use.
Until a function- specific limit, a higher value will generally
increase the performance of individual GPU threads that execute this
function. However, because thread registers are allocated from a global
register pool on each GPU, a higher value of this option will also
reduce the maximum thread block size, thereby reducing the amount of
thread parallelism. Hence, a good maxrregcount value is the result of a
trade-off.
If this option is not specified, then no maximum is assumed.
--ftz [true,false] (-ftz)
When performing single-precision floating-point operations, flush
denormal values to zero or preserve denormal values. -use_fast_math
implies --ftz=true.
Default value: 0.
--prec-div [true,false] (-prec-div)
For single-precision floating-point division and reciprocals, use IEEE
round-to-nearest mode or use a faster approximation. -use_fast_math
implies --prec-div=false.
Default value: 1.
--prec-sqrt [true,false] (-prec-sqrt)
For single-precision floating-point square root, use IEEE
implies --prec-sqrt=false.
Default value: 1.
--fmad [true,false] (-fmad)
Enables (disables) the contraction of floating-point multiplies and
adds/subtracts into floating-point multiply-add operations (FMAD, FFMA,
or DFMA). This option is supported only when '--gpu-architecture' is
set with compute_20, sm_20, or higher. For other architecture classes,
the contraction is always enabled. -use_fast_math implies --fmad=true.
Default value: 1.
--relocatable-device-code [true,false] (-rdc)
Enable (disable) the generation of relocatable device code. If
disabled, executable device code is generated.
Default value: 0.
Options for steering cuda compilation
--use_fast_math (-use_fast_math)
Make use of fast math library. -use_fast_math implies -ftz=true
-prec-div=false -prec-sqrt=false.
--entries entry,... (-e)
In case of compilation of ptx or gpu files to cubin: specify the global
entry functions for which code must be generated. By default, code will
be generated for all entry functions.
Generic tool options
--disable-warnings (-w)
Inhibit all warning messages.
--source-in-ptx (-src-in-ptx)
Interleave source in ptx.
--restrict (-restrict)
Programmer assertion that all kernel pointer parameters are restrict
pointers.
--help (-h)
Print this help information on this tool.
--version (-V)
Print version information on this tool.
--options-file <file>,... (-optf)
Include command line options from specified file.
$ nvcc --version
Copyright (c) 2005-2012 NVIDIA Corporation
Built on Fri_Sep_21_17:28:58_PDT_2012
Cuda compilation tools, release 5.0, V0.2.1221
wow i feel stupid thanks.
Do not beat yourself. Myself, I tried the same way. I am just lucky I had experience with different compilers.
thank you so much everything is working great now been trying for a week.
Also works: $ nvcc -V
