Hi NVidia Team,
I would like to correct fisheye effect for a wide angel video camera (e.g. FOV 120 degree) to get a “normal” image, is it possible to use the example code “deepstream-dewapper-test” for it? Some documents say Deepstream only supports 360D RBGA input, I’d like to know whether it can be used for a 120D camera?
Thanks,
Andrew
Yes. We have not tested 120D camera. Can you try it firstly and give the result here?
Hi ChrisDing,
After studying the current solution, I realized it is used for observing the fixed field of view for watching the same geo-region. My application is to use the cameras on moving object (3 wheeler). Any possibility to use DS to calibrate the fish-eye with the cameras on a moving object?
Thanks,
Andrew
