I found a strange behavior of glTexStorage3D
I use glTexStrage3D to create a texture 2d array object.
Up to 255 layers, glTexStorage3D works fine.
But with 256+ layers, the number of allocated layers seems to be masked with 0xff.
For example, with 256 layers, glGetTextureParamter(GL_TEXTURE_VIEW_NUM_LAYERS) says
the number of layers is zero.
Because of this behavior, I’m troubled with creating texture view for texture_2d_array.
I wrote a testcase and tested with GTX 650 Ti with 325.15 driver on linux-3.10.
Would you please check the attached testcase?
Is this correct behavior?
#include <stdio.h>
#include<GL/glew.h>
#include<GL/gl.h>
#include<GL/glu.h>
#include<GL/glut.h>
#define CHECK_GL() do { GLenum e; while ( (e = glGetError()) != GL_NO_ERROR ) { fprintf(stderr, __FILE__ ":%d glGetError() returns '%d'\n", __LINE__, e ); } } while(0)
void test_texturestorage()
for (int num_layers = 250; num_layers<=260; ++num_layers) {
// Creates GL_TEXTURE_2D_ARRAY with num_layers
GLuint texture;
glGenTextures(1, &texture);
glBindTexture( GL_TEXTURE_2D_ARRAY, texture );
glTexStorage3D( GL_TEXTURE_2D_ARRAY,
1,
GL_RGB8,
64, 64, num_layers);
CHECK_GL();
// Retrieves number of layers
GLint value;
glGetTexParameterIiv(GL_TEXTURE_2D_ARRAY,
GL_TEXTURE_VIEW_NUM_LAYERS,
&value);
printf("GL_TEXTURE_VIEW_NUM_LAYERS: %d num_layers: %d\n",
value, num_layers);
glBindTexture( GL_TEXTURE_2D_ARRAY,0);
glDeleteTextures(1, &texture);
void test_textureview(int num_layers)
// Creates texture 2d array
GLuint originaltexture;
glGenTextures(1, &originaltexture);
glBindTexture( GL_TEXTURE_2D_ARRAY, originaltexture );
1,
GL_RGB8,
CHECK_GL();
// Creates an texture view for the last slice of originaltexture
GLuint textureview;
glGenTextures(1, &textureview);
glTextureView(textureview, GL_TEXTURE_2D,
originaltexture,
GL_RGB8,
0,1,
(num_layers-1),1);
CHECK_GL();
glDeleteTextures(1, &originaltexture);
glDeleteTextures(1, &textureview);
int
main(int argc, char *argv[])
// Initialize GLUT stuff
glutInit(&argc, argv);
glutInitDisplayMode( GLUT_RGBA );
glutInitWindowSize( 100,100 );
glutCreateWindow( argv[ 0 ] );
// Initialize glew stuff
glewInit();
glActiveTexture(GL_TEXTURE1);
test_texturestorage();
// This works fine.
test_textureview(255);
// This doesn't work in my environment.
test_textureview(256);
return 0;
testcase.cpp (2.03 KB)
