Hang with Sparse Textures on Linux Driver
Creating a storage for a sparse texture 2D Array enough large, cause the driver stall for half a minute. Windows driver seems not having this behaviour.
Tested with 352.x and 355.x drivers series on GTX 750m.
This is the code i’ve used:
#include <GL/glut.h>
void
init(void)
    glPixelStorei(GL_UNPACK_ALIGNMENT, 1);
    GLuint TextureName;
    glGenTextures(1, &TextureName);
    glActiveTexture(GL_TEXTURE0);
    glBindTexture(GL_TEXTURE_2D_ARRAY, TextureName);
    glTexParameteri(GL_TEXTURE_2D_ARRAY, GL_TEXTURE_SWIZZLE_R, GL_RED);
    glTexParameteri(GL_TEXTURE_2D_ARRAY, GL_TEXTURE_SWIZZLE_G, GL_GREEN);
    glTexParameteri(GL_TEXTURE_2D_ARRAY, GL_TEXTURE_SWIZZLE_B, GL_BLUE);
    glTexParameteri(GL_TEXTURE_2D_ARRAY, GL_TEXTURE_SWIZZLE_A, GL_ALPHA);
    glTexParameteri(GL_TEXTURE_2D_ARRAY, GL_TEXTURE_MIN_FILTER, GL_LINEAR);
    glTexParameteri(GL_TEXTURE_2D_ARRAY, GL_TEXTURE_MAG_FILTER, GL_LINEAR);
    glTexParameteri(GL_TEXTURE_2D_ARRAY, GL_TEXTURE_SPARSE_ARB, GL_TRUE);
    glTexStorage3D(GL_TEXTURE_2D_ARRAY, 1, GL_RGBA8, 1024, 1024, 1024); // This instruction stalls the driver
int
main(int argc, char **argv)
  glutInit(&argc, argv);
  glutInitDisplayMode(GLUT_DOUBLE | GLUT_RGB | GLUT_DEPTH);
  glutCreateWindow("sparse Text example");
  init();
  return 0;
