[FIXED] Suspend / Resume issues with the driver version 470
Good news for affected users! I found a fix!
A LITTLE BACKGROUND
You may already know that NVIDIA drivers on Linux rely on either of two different methods for power management ( as described here ), which include:
  1. Kernel Driver Callback: Works out of the box with no configuration required, but lacks advanced power management features and preserves only a portion of the video memory.
  2. systemd (/proc/driver/nvidia/suspend): Provides advanced power management features and preserves complete video memory, but requires configuration and setup.
THE CAUSE
Having mentioned the above, upon further inspection I found out the 470 driver migrated to systemd method while previous versions relied on Kernel Driver Callback. Apparently this is broken on some setups and kernels.
THE WORKAROUND
Now it’s obvious we have to revert back to Kernel Driver Callback method for now that the systemd method is broken, and here’s how you can do that:
  • Disable NVIDIA systemd services
sudo systemctl stop nvidia-suspend.service
sudo systemctl stop nvidia-hibernate.service
sudo systemctl stop nvidia-resume.service
sudo systemctl disable nvidia-suspend.service
sudo systemctl disable nvidia-hibernate.service
sudo systemctl disable nvidia-resume.service
  • Remove NVIDIA systemd script
sudo rm /lib/systemd/system-sleep/nvidia
Reboot and you should be able to suspend and resume properly with driver version 470.xx.
NOTE: Backup your configuration just in case, or downgrade the driver if this does not work on your setup. This was tested on Kubuntu 21.04 with GeForce GT 710.
