Exciting! I’ll stick with vllm for now, but I’m keeping an eye on this too now.
5f37bd1 (HEAD -> main, origin/main, origin/HEAD) Clarify project status.
diff --git a/README.md b/README.md
index 4137c20..c61fe7d 100644
--- a/README.md
+++ b/README.md
@@ -9,6 +9,9 @@ long conversations, coding agents, and repeated tool use. Its goal is to make
the memory, bandwidth, and compute in workstations and compact systems such
as DGX Spark go further, while keeping generation responsive.
+This is a research prototype, and is made available via open-source to enable
+technical collaboration and collect early feedback.
That explains that there was no announcement which I would have expected.
I like the approach of developing it so openly, under the watchful eyes of the community. There have been other, opposite approaches in the past…
I’m curious to see how it develops from here.
Tested Flare (flare-local-inference) on DGX Spark with Qwen3.8-Flash-Next-FP4-Local: notes and numbers
Setup
- Flare 5f37bd1 (main as of 2026-10-21), built from source: uv sync --locked --extra prepare --extra test + cargo build --release. Clean build on both nodes once protobuf-compiler and liburing-dev were installed.
- Model: nvidia/Qwen3.8-Flash-Next-FP4-Local @ b9ce18a6 (the recipe’s pin), TP1 on a single Spark.
- Export: ignition export qwen3.8-flash --gpus 0 --mtp-draft-tokens 5 --max-concurrency 4.
- [memory] reserve = “4G”, GPU clock capped at 1700 MHz.
What went well
- Export ran end to end with no intervention: ~33 min cold, 61 graphs, ~1,900 kernels.
- Boot to healthy in 20 seconds. That’s a big quality-of-life win over the stacks I usually run.
- KV pool of 2.04M tokens at 262K context per request on one Spark.
Decode throughput (tok/s, thinking off, 200-token replies, median of 3 runs, warmed)
The comparison is another Spark serving stack on the same checkpoint and the same benchmark script:
Thanks for the nice summary and a very promising start from Flare!
What is the model in the other stack you are running? Latelry I have been running the nvidia local quant of the model but I dont get your speeds. I hsed to get closer to your speeds using azampatti’s quant but at the cost of lower free RAM on the box (and BF16 KV, their quant with FP8 KV was slower for me), I need slightly more free RAM for other services so nvidia local gives me slightly more breathing space.
Also, what prompt processing speeds do you see on this early Flare inference engine?
⚡ DeepSeek-V4.1-Flash-1017 loaded in just 20 seconds! 🔥🚀
Flare is very new and not mature enough. So i’m using TensorFold to run model locally now.
Thanks for this. Enjoying using Flare.
Loads DeepSeek-V4.1-Flash-1017 TP4 in 28 seconds - brilliant for jumping between models on the fly using llama-swap. Speed is good too 60-80tps average on a mix of coding and agentic. It feels clean: to run, only single binary needed, no docker containers required anywhere. also only 1 or 2 seconds to stop model.
I only have 3 cables with 4 sparks (suppliers out of stock in my country for a few weeks), and many other recipes only support rings, but this supports --roce-chain so its the first recipe I was able to get working with minimal fuss on 4 nodes
The model build process was a bit more involved than I would have liked, needs a number of params upfront, takes quite a bit of time to build the model file, and uses a lot of disk space for large models, so thats something to look out for. Had 1 or 2 crashes when first started using, so it may be user error, but its being going well last 2 days no crashes. There is a hash verification on every load which took 400+ seconds but after commenting out package.verify_stored_data().map_err(|e| e.to_string())?; it loads in 28 seconds.
Being a new project, I look forward to the improvements! Baseline is good so hopefully can only get better from here.
Im making some more improvements to Flare, i worked on the prefix cache improvement, now im trying to save time in the process of tuning and compiling for the first time, some promising advances
What this fork adds over upstream
| Change | Effect on a 3x GB10 DeepSeek V4.1 Flash TP3 export | Upstream status |
[preparation] compile_headroom / --compile-headroom (default 8G) |
“Compile model forwards” 906 s → 508 s with 6G | #122, see #73 |
| Payload sources hashed on parallel readers; missing shared payloads inserted concurrently | “Verify and publish shared data” 864 s → 427 s | Not yet proposed |
| Received payload objects linked into the package cache instead of copied | “Receive rank export payloads” 458-477 s → 281 s | Not yet proposed |
ignition join --local-checkpoint [require|prefer]: peers read their own checkpoint copy through b12x’s batch reader |
Peer weight load 252 s → 45-50 s; rank zero’s “Allocate model state” 190 s → 2-5 s | Not yet proposed |
Just updated my fork with my last improvements that are pending prs on the official one GitHub - javieratomic/flare-local-inference: Community fork of NVIDIA Flare: DeepSeek V4.1 Flash on three DGX Sparks (TP3). Not an official NVIDIA release. · GitHub
so, Nvidia, I’ve come to you with my spin-wait issue.
But wait, why my issue? It’s not only mine — it’s actually ours, comrades! :)
Did you know you could save 12–15 watts of heat per node just by programming your GPU wait loop properly?
- local-inference-lab/flashinfer#105 — proxy WFET for proxy ABI 14: b12x RoCE proxy: wait for the doorbell in WFET on aarch64 cores with FEAT_WFxT by jetnet · Pull Request #105 · local-inference-lab/flashinfer · GitHub
- NVIDIA/hyperflare-inference#279 — sync of the vendored RoCE proxy to ABI 14, fixing #271: Match native RoCE transport to the pinned FlashInfer proxy ABI 14 by jetnet · Pull Request #279 · NVIDIA/hyperflare-inference · GitHub
- NVIDIA/hyperflare-inference#280 — executor WFET: the serving loops park on a frame-completion word written by the GPU instead of yielding in a loop:
Park the serving loops on a frame-completion word in WFET on GB10 instead of yielding in a loop by jetnet · Pull Request #280 · NVIDIA/hyperflare-inference · GitHub - Comment on flashinfer-ai/flashinfer#9352 — points to #105 and gives the Hyperflare numbers: [Feature]: b12x RoCE proxy: wait for the doorbell in WFET instead of spinning (aarch64 FEAT_WFxT) · Issue #9352 · flashinfer-ai/flashinfer · GitHub
I made some more improvements to Flare, now with more KV and faster prefill
Thanks for #279: it closed #271 for us. A DeepSeek V4.1 Flash core exported at tensor parallelism 3 from main at 6b68b9b4 (which includes #279) with my open PR #122 applied connects over direct RoCE rails (three GB10 hosts, one rank per host, two rails per peer) and has been serving since Nov 16, with #280 active (the frame completion wait: WFET line is printed).
Since flashinfer #105 says it was not tried beyond two ranks, I applied it to the vendored proxy on a build of main at f9aec99c that also carries my own unmerged changes (hyperflare-inference #122, #124, #125, #157, #323 and two unpublished branches; none of them touches the vendored proxy), and ran that build against the same build without it, A/B/A/B, on the three-rank direct mesh. Both starts with the patch served without errors. Decode and prefill show no difference beyond run-to-run noise across the four starts: per-start means of 43.7 to 47.1 tok/s for one prose stream and 91.7 to 97.6 summed over four (three 512-token repeats each), and 32.2 to 32.5 s for a cold 120,000-token prompt.
I can’t confirm the power figure directly. These hosts have no wall-power meter; GPU power was the same (about 31 to 32 W average) in every start; and the rank process’s CPU time doesn’t change: about 3.4 cores averaged over a start, with and without the patch, in the second A/B pair (I did not record it in the first), as expected for a thread that waits in WFET in user space.
Temperatures are suggestive but not conclusive. The hottest of each host’s seven thermal zones (ACPI zones that the system does not label by component), averaged over each start, was the same within 1 °C in the first A/B pair and 2.5 to 10.5 °C lower with the patch in the second, with thermal drift between starts that I did not control. One pattern did repeat on all three hosts and in both pairs: that zone ran 5.5 to 7.6 °C above the average of four cooler zones without the patch and 2.5 to 3.4 °C with it, which would fit a core that stopped spinning, though I can’t say what each zone measures. The X925 cores here are capped at 3.0 GHz (3.9 GHz unthrottled), which probably narrows the gain too. I can rerun with a steadier thermal protocol if that would be useful.
@jlopez11 thanks a lot for testing this on three ranks! Great to hear it served cleanly and decode/prefill stayed within noise.
Your CPU cap could be narrowing the gain. In my Hyperflare runs (GLM-5.3 Flash, TP2, two Sparks), the proxy patch saved 2–3 W per node at the wall with X925 capped at 3.0 GHz, vs. about 8 W uncapped, with the GPU capped at 1800 MHz throughout.
If you’re up for another A/B - try lifting just the CPU cap. Without a wall meter, repeating your temperature comparison under steadier conditions would still be useful, though it won’t establish watts saved.
NOTE: Unchanged CPU time is expected: WFET waits remain scheduled, so top can still show 100%.
P.S. back-of-the-napkin math: a few watts x every Spark on Earth x 24/7 = I’m practically a climate activist with a profiler! I’d accept a medal… but, actually, one 128GB Spark would be far more useful. The World Government can wire the CO2 bonus to the same address :)
I’d like also to share a couple of charts how different engines consume energy while serving Qwen 3.8 FN during the same TEB test:
