I seem to be having an issue with flashing my own u-boot onto the TK1. I have cloned git://nv-tegra.nvidia.com/3rdparty/u-boot.git and am working with the latest branch l4t/l4t-r27.1
I run the default config script “make jetson-tk1_defconfig” and run the cmd:
make CROSS_COMPILE=arm-none-eabi- DTC=../usr/src/kernel-source/scripts/dtc/dtc
Where the DTC path is the path to a dtc binary that I have compiled from the kernel source located at git://github.com/madisongh/linux-tegra.git using the branch patches-l4t-r21.5. The kernel is using the configuration script arch/arm/configs/tegra12_defconfig.
I understand that I am using r27.1 for u-boot whereas I am using r21.5 for the kernel release which could be leading to potential issues, but I did a checkout on u-boot l4t-r21.5 as well (same release as kernel) and it still didn’t work. I am using a later release of u-boot because I need some of the features within the u-boot r27.1 release that the u-boot r21.5 release doesn’t have.
It may also be worth noting that the dtc that I built with the kernel image produced a dtc at version 1.2.0 whereas the minimum dtc version required when building u-boot r27.1 is version 1.4 as indicated by the error message in the Makefile “Your dtc is too old, please upgrade to dtc 1.4 or newer”. In order to get things to compile, I commented out this check in the Makefile for u-boot r27.1. I also tried using the dtc binary that came with the Tegra_Linux_Driver R21.5 package for the DTC path. Although both approaches produced a u-boot-dtb-tegra.bin file that I copied over to <L4T_driver_package>/bootloader/ardbeg, u-boot was still unsuccessful in booting.
The flash script seems to show me all partitions successfully flashed. The tk1 side seems to show everything going smoothly too, except it just hangs on a the line that comes right before u-boot takes over: “WriterThread: Exiting”
This is the response out of serial using minicom when using the sudo ./flash.sh jetson-tk1 mmcblk0p1 cmd:
[0000.000] [TegraBoot] (version UNDEF_BUILD)
[0000.004] Reset reason: power on reset
[0000.007] Processing in recovery mode
[0000.011] Established communication link with host
[0001.096] Downloaded bct successfully
[0001.100] No Battery Present
[0001.104] Sdram initialization is successful
[0001.134] Downloaded DTB successfully
[0001.162] No Battery Present
[0001.280] Downloaded bootloader successfully
[0001.285] CPU-bootloader entry address: 0x83d88000
[0001.289] BoardId: 375
[0001.291] Vpr Carveout Base=0x0f4600000 Size=0x00ba00000
[0001.296] Tsec Carveout Base=0x0f2600000 Size=0x002000000
[0001.302] Lp0 Carveout Base=0x0f25ff000 Size=0x000001000
[0001.307] Xusb Carveout Base=0x0f2300000 Size=0x000200000
[0001.312] Platform-DebugCarveout: 0
[0001.339] CPU power rail is up
[0001.342] Performing RAM repair
[0001.345] CPU clock init successful
[0001.348] Starting CPU & Halting co-processor
NVRM Initialized shmoo database
NVRM CLOCKS: PLLX0: 696000 Khz
NVRM CLOCKS: PLLM0: 924000 Khz
NVRM CLOCKS: PLLC0: 0 Khz
NVRM CLOCKS: PLLP0: 408000 Khz
NVRM CLOCKS: PLLA0: 11289 Khz
NVRM CLOCKS: CPU: 696000 Khz
NVRM CLOCKS: AVP: 48000 Khz
NVRM CLOCKS: System Bus: 48000 Khz
NVRM CLOCKS: Memory Controller: 924000
NVRM CLOCKS: External Memory Controller: 924000
EEPROM instance-5: No slave at this instance.
EEPROM instance-0: No slave at this instance.
EEPROM instance-0: Querying board info from BCT.
EEPROM instance-0: No board info available for this instance in BCT.
EEPROM instance-1: No slave at this instance.
EEPROM instance-1: Querying board info from BCT.
EEPROM instance-1: Board info present in BCT is invalid.
EEPROM instance-2: No slave at this instance.
EEPROM instance-2: Querying board info from BCT.
EEPROM instance-2: No board info available for this instance in BCT.
EEPROM instance-3: No slave at this instance.
EEPROM instance-3: Querying board info from BCT.
EEPROM instance-3: No board info available for this instance in BCT.
EEPROM instance-4: No slave at this instance.
EEPROM instance-4: Querying board info from BCT.
EEPROM instance-4: Board info present in BCT is invalid.
EEPROM instance-5: Querying board info from BCT.
EEPROM instance-5: Board info present in BCT is invalid.
EEPROM instance-6: BoardInfo: 0x0001:0x0007:0375:0000:03:B:00:0xff:0xff:0xff:0xff:0xff:0xff
EEPROM instance-7: No slave at this instance.
EEPROM instance-7: Querying board info from BCT.
EEPROM instance-7: No board info available for this instance in BCT.
Final BoardID: proc: 375 and pmu 375
ADJUSTED CLOCKS:
MC clock is set to 924000 KHz
EMC clock is set to 924000 KHz (DDR clock is at 924000 KHz)
PLLX0 clock is set to 696000 KHz
PLLC0 clock is set to 0 KHz
CPU clock is set to 696000 KHz
System and AVP clock is set to 48000 KHz
GraphicsHost clock is set to 163200 KHz
MSENC clock is set to 92400 KHz
Vde clock is set to 204000 KHz
Bootloader-Cpu Init at (time stamp): 81014255 us
Pinmux changes applied in kernel way
[bootloader] (version UNDEF_BUILD)
Platform Pre Boot configuration...
NvDdkUsbhBlockDevInit..
Initializing Display
The proc BoardInfo: 0x0177:0x0000:0x03:0x42:0x00
This Pmu Module is not present.
The best display mode is 2560x1600/60Hz, pclk: 268627Khz
DSI PAD calibration done
Entering NvFlash recovery mode / Nv3p Server
Nv3pServer Version 4.13.0000
***: DecodeCSD:
: readBlkBits=9, readBlkSize=512 Bytes
: nSectors=(CSIZE+1)*(2**(CSizeMult+2))=4096 * 512 = 2097152 Sectors
: writeBlkBits=9, writeBlkSize=512 Bytes
: ERASE_GRP_SIZE=31, ERASE_GRP_MULT=31
: EraseGrpSize=(31+1)*(31+1)=1024 Sectors (524288 Bytes)
: WPGrpSize=31744 Sectors (16252928 Bytes)
***: ReadExtCSD:
: overriding USER Sectors = 30777344 Sectors
: keep CSD EraseGrpSize = 1024 Sectors (524288 Bytes)
: keep CSD WPGrpSize = 31744 wBlks (16252928 Bytes)
: BootPartSize = 4194304 Bytes (8192 Sectors)
***: SetBlockSize to 512 Bytes SKIPPED because CMD16 is illegal for DDR50...
***: SdGetDevInfo: PagesPerBlock = 32 pages (256 Sectors)
***: SdGetDevInfo: TotSecs=TotBlk(120288)*PgPerBlk(32)*SecsPerPg(8)=30793728
Region=1 SD Erase start 512B-sector=0,512B-sector-num=8192
Region=2 SD Erase start 512B-sector=0,512B-sector-num=8192
Region=0 SD Erase start 512B-sector=0,512B-sector-num=30777344
SD Alloc Partid=2, start sector=0,num=2048
SD Alloc Partid=3, start sector=2048,num=512
SD Alloc Partid=4, start sector=2560,num=512
SD Alloc Partid=5, start sector=3072,num=1024
SD Alloc Partid=6, start sector=4096,num=4096
SD Alloc Partid=7, start sector=8192,num=1536
SD Alloc Partid=8, start sector=9728,num=512
SD Alloc Partid=9, start sector=10240,num=1536
SD Alloc Partid=10, start sector=11776,num=1536
SD Alloc Partid=11, start sector=13312,num=512
SD Alloc Partid=12, start sector=13824,num=3670016
SD Alloc Partid=13, start sector=3683840,num=1024
SD Alloc Partid=14, start sector=3684864,num=16384
SD Alloc Partid=15, start sector=3701248,num=1024
SD Alloc Partid=16, start sector=3702272,num=1024
SD Alloc Partid=17, start sector=3703296,num=1024
SD Alloc Partid=18, start sector=3704320,num=1024
SD Alloc Partid=19, start sector=3705344,num=512
SD Alloc Partid=20, start sector=3705856,num=142848
SD Alloc Partid=21, start sector=3848704,num=512
Region=0 SD Erase start 512B-sector=4096,512B-sector-num=4096
Start Downloading PPT
Parallel write enabled
End Downloading PPT
Time taken to download partition: 245 ms
Start Downloading EBT
End Downloading EBT
Time taken to download partition: 247 ms
Start Downloading APP
End Downloading APP
Time taken to download partition: 121124 ms
Start Downloading DTB
End Downloading DTB
Time taken to download partition: 19 ms
Start Downloading GPT
End Downloading GPT
Time taken to download partition: 235 ms
Here is what I see on the host side:
kernel_image=/home/austin/Desktop/Tegra_Yocto/Linux_for_Tegra/kernel/zImage
copying bctfile(/home/austin/Desktop/Tegra_Yocto/Linux_for_Tegra/bootloader/ardbeg/BCT/PM375_Hynix_2GB_H5TC4G63AFR_H5TC4G63CFR_RDA_924MHz.cfg)... done.
copying bootloader(/home/austin/Desktop/Tegra_Yocto/Linux_for_Tegra/bootloader/ardbeg/u-boot.bin)... done.
populating kernel to rootfs... done.
populating jetson-tk1_extlinux.conf.emmc to rootfs... done.
done.
Making system.img...
populating rootfs from /home/austin/Desktop/Tegra_Yocto/Linux_for_Tegra/rootfs ... done.
Sync'ing system.img ... done.
Converting RAW image to Sparse image...
---- Raw to Sparse Image Converter v1.0 ----------------------------
0: RAW: 3706880( 905 blks) ==> 28:3706892
1: SKP: 32768( 8 blks) ==> 3706920:32780
2: RAW: 4096( 1 blks) ==> 3706932:4108
3: SKP: 61440( 15 blks) ==> 3711040:61452
4: RAW: 1048576( 256 blks) ==> 3711052:1048588
5: SKP: 32505856( 7936 blks) ==> 4759640:32505868
6: RAW: 1630208( 398 blks) ==> 4759652:1630220
7: SKP: 95227904( 23249 blks) ==> 6389872:95227916
8: RAW: 8192( 2 blks) ==> 6389884:8204
9: SKP: 3665920( 895 blks) ==> 6398088:3665932
10: RAW: 17625088( 4303 blks) ==> 6398100:17625100
11: SKP: 4096( 1 blks) ==> 24023200:4108
12: RAW: 18690048( 4563 blks) ==> 24023212:18690060
13: SKP: 8192( 2 blks) ==> 42713272:8204
14: RAW: 2609152( 637 blks) ==> 42713284:2609164
15: SKP: 8192( 2 blks) ==> 45322448:8204
16: RAW: 15773696( 3851 blks) ==> 45322460:15773708
17: SKP: 12288( 3 blks) ==> 61096168:12300
18: RAW: 90112( 22 blks) ==> 61096180:90124
19: SKP: 12288( 3 blks) ==> 61186304:12300
20: RAW: 94208( 23 blks) ==> 61186316:94220
21: SKP: 12288( 3 blks) ==> 61280536:12300
22: RAW: 90112( 22 blks) ==> 61280548:90124
23: SKP: 12288( 3 blks) ==> 61370672:12300
24: RAW: 4096( 1 blks) ==> 61370684:4108
25: SKP: 4096( 1 blks) ==> 61374792:4108
26: RAW: 81920( 20 blks) ==> 61374804:81932
27: SKP: 12288( 3 blks) ==> 61456736:12300
28: RAW: 90112( 22 blks) ==> 61456748:90124
29: SKP: 12288( 3 blks) ==> 61546872:12300
30: RAW: 94208( 23 blks) ==> 61546884:94220
31: SKP: 12288( 3 blks) ==> 61641104:12300
32: RAW: 90112( 22 blks) ==> 61641116:90124
33: SKP: 12288( 3 blks) ==> 61731240:12300
34: RAW: 4096( 1 blks) ==> 61731252:4108
35: SKP: 4096( 1 blks) ==> 61735360:4108
36: RAW: 81920( 20 blks) ==> 61735372:81932
37: SKP: 12288( 3 blks) ==> 61817304:12300
38: RAW: 90112( 22 blks) ==> 61817316:90124
39: SKP: 12288( 3 blks) ==> 61907440:12300
40: RAW: 53538816( 13071 blks) ==> 61907452:53538828
41: SKP: 4096( 1 blks) ==> 115446280:4108
42: RAW: 27512832( 6717 blks) ==> 115446292:27512844
43: SKP: 8192( 2 blks) ==> 142959136:8204
44: RAW: 425984( 104 blks) ==> 142959148:425996
45: SKP: 4096( 1 blks) ==> 143385144:4108
46: RAW: 2224128( 543 blks) ==> 143385156:2224140
47: SKP: 8192( 2 blks) ==> 145609296:8204
48: RAW: 26075136( 6366 blks) ==> 145609308:26075148
49: SKP: 4096( 1 blks) ==> 171684456:4108
50: RAW: 44445696( 10851 blks) ==> 171684468:44445708
51: SKP: 61440( 15 blks) ==> 216130176:61452
52: RAW: 114688( 28 blks) ==> 216130188:114700
53: SKP: 16384( 4 blks) ==> 216244888:16396
54: RAW: 1474560( 360 blks) ==> 216244900:1474572
55: SKP: 4096( 1 blks) ==> 217719472:4108
56: RAW: 536576( 131 blks) ==> 217719484:536588
57: SKP: 61440( 15 blks) ==> 218256072:61452
58: RAW: 114688( 28 blks) ==> 218256084:114700
59: SKP: 16384( 4 blks) ==> 218370784:16396
60: RAW: 5181440( 1265 blks) ==> 218370796:5181452
61: SKP: 61440( 15 blks) ==> 223552248:61452
62: RAW: 114688( 28 blks) ==> 223552260:114700
63: SKP: 16384( 4 blks) ==> 223666960:16396
64: RAW: 8196096( 2001 blks) ==> 223666972:8196108
65: SKP: 61440( 15 blks) ==> 231863080:61452
66: RAW: 114688( 28 blks) ==> 231863092:114700
67: SKP: 16384( 4 blks) ==> 231977792:16396
68: RAW: 20340736( 4966 blks) ==> 231977804:20340748
69: SKP: 126976( 31 blks) ==> 252318552:126988
70: RAW: 528384( 129 blks) ==> 252318564:528396
71: SKP: 131072( 32 blks) ==> 252846960:131084
72: RAW: 159744( 39 blks) ==> 252846972:159756
73: SKP: 126976( 31 blks) ==> 253006728:126988
74: RAW: 528384( 129 blks) ==> 253006740:528396
75: SKP: 131072( 32 blks) ==> 253535136:131084
76: RAW: 12214272( 2982 blks) ==> 253535148:12214284
77: SKP: 290816( 71 blks) ==> 265749432:290828
78: RAW: 319488( 78 blks) ==> 265749444:319500
79: SKP: 176128( 43 blks) ==> 266068944:176140
80: RAW: 3371008( 823 blks) ==> 266068956:3371020
81: SKP: 4096( 1 blks) ==> 269439976:4108
82: RAW: 245760( 60 blks) ==> 269439988:245772
83: SKP: 3665920( 895 blks) ==> 269685760:3665932
84: RAW: 1830912( 447 blks) ==> 269685772:1830924
85: SKP: 61440( 15 blks) ==> 271516696:61452
86: RAW: 114688( 28 blks) ==> 271516708:114700
87: SKP: 16384( 4 blks) ==> 271631408:16396
88: RAW: 2777088( 678 blks) ==> 271631420:2777100
89: SKP: 61440( 15 blks) ==> 274408520:61452
90: RAW: 114688( 28 blks) ==> 274408532:114700
91: SKP: 16384( 4 blks) ==> 274523232:16396
92: RAW: 1310720( 320 blks) ==> 274523244:1310732
93: SKP: 61440( 15 blks) ==> 275833976:61452
94: RAW: 114688( 28 blks) ==> 275833988:114700
95: SKP: 16384( 4 blks) ==> 275948688:16396
96: RAW: 3899392( 952 blks) ==> 275948700:3899404
97: SKP: 61440( 15 blks) ==> 279848104:61452
98: RAW: 114688( 28 blks) ==> 279848116:114700
99: SKP: 16384( 4 blks) ==> 279962816:16396
100: RAW: 2777088( 678 blks) ==> 279962828:2777100
101: SKP: 61440( 15 blks) ==> 282739928:61452
102: RAW: 114688( 28 blks) ==> 282739940:114700
103: SKP: 16384( 4 blks) ==> 282854640:16396
104: RAW: 1314816( 321 blks) ==> 282854652:1314828
105: SKP: 61440( 15 blks) ==> 284169480:61452
106: RAW: 114688( 28 blks) ==> 284169492:114700
107: SKP: 16384( 4 blks) ==> 284284192:16396
108: RAW: 9490432( 2317 blks) ==> 284284204:9490444
109: SKP: 61440( 15 blks) ==> 293774648:61452
110: RAW: 114688( 28 blks) ==> 293774660:114700
111: SKP: 16384( 4 blks) ==> 293889360:16396
112: RAW: 7184384( 1754 blks) ==> 293889372:7184396
113: SKP: 61440( 15 blks) ==> 301073768:61452
114: RAW: 114688( 28 blks) ==> 301073780:114700
115: SKP: 16384( 4 blks) ==> 301188480:16396
116: RAW: 2985984( 729 blks) ==> 301188492:2985996
117: SKP: 61440( 15 blks) ==> 304174488:61452
118: RAW: 114688( 28 blks) ==> 304174500:114700
119: SKP: 16384( 4 blks) ==> 304289200:16396
120: RAW: 136912896( 33426 blks) ==> 304289212:136912908
121: SKP: 8192( 2 blks) ==> 441202120:8204
122: RAW: 90112( 22 blks) ==> 441202132:90124
123: SKP: 172032( 42 blks) ==> 441292256:172044
124: RAW: 47767552( 11662 blks) ==> 441292268:47767564
125: SKP: 4096( 1 blks) ==> 489059832:4108
126: RAW: 4509696( 1101 blks) ==> 489059844:4509708
127: SKP: 4096( 1 blks) ==> 493569552:4108
128: RAW: 208896( 51 blks) ==> 493569564:208908
129: SKP: 4096( 1 blks) ==> 493778472:4108
130: RAW: 39784448( 9713 blks) ==> 493778484:39784460
131: SKP: 3665920( 895 blks) ==> 533562944:3665932
132: RAW: 4587520( 1120 blks) ==> 533562956:4587532
133: SKP: 126976( 31 blks) ==> 538150488:126988
134: RAW: 58630144( 14314 blks) ==> 538150500:58630156
135: SKP: 90112( 22 blks) ==> 596780656:90124
136: RAW: 6250496( 1526 blks) ==> 596780668:6250508
137: SKP: 2138112( 522 blks) ==> 603031176:2138124
138: RAW: 323584( 79 blks) ==> 603031188:323596
139: SKP: 24576( 6 blks) ==> 603354784:24588
140: RAW: 45641728( 11143 blks) ==> 603354796:45641740
141: SKP: 4096( 1 blks) ==> 648996536:4108
142: RAW: 4096( 1 blks) ==> 648996548:4108
143: SKP: 28672( 7 blks) ==> 649000656:28684
144: RAW: 241664( 59 blks) ==> 649000668:241676
145: SKP: 4063232( 992 blks) ==> 649242344:4063244
146: RAW: 27054080( 6605 blks) ==> 649242356:27054092
147: SKP: 6500352( 1587 blks) ==> 676296448:6500364
148: RAW: 33046528( 8068 blks) ==> 676296460:33046540
149: SKP: 507904( 124 blks) ==> 709343000:507916
150: RAW: 57245696( 13976 blks) ==> 709343012:57245708
151: SKP: 1474560( 360 blks) ==> 766588720:1474572
152: RAW: 16785408( 4098 blks) ==> 766588732:16785420
153: SKP: 3665920( 895 blks) ==> 783374152:3665932
154: RAW: 11628544( 2839 blks) ==> 783374164:11628556
155: SKP: 1474560( 360 blks) ==> 795002720:1474572
156: RAW: 16400384( 4004 blks) ==> 795002732:16400396
157: SKP: 235257856( 57436 blks) ==> 811403128:235257868
158: RAW: 8192( 2 blks) ==> 811403140:8204
159: SKP: 939515904( 229374 blks) ==> 811411344:939515916
160: RAW: 8192( 2 blks) ==> 811411356:8204
161: SKP: 57344( 14 blks) ==> 811419560:57356
162: RAW: 4096( 1 blks) ==> 811419572:4108
163: SKP: 61440( 15 blks) ==> 811423680:61452
164: RAW: 671744( 164 blks) ==> 811423692:671756
165: SKP: 32882688( 8028 blks) ==> 812095448:32882700
166: RAW: 618496( 151 blks) ==> 812095460:618508
167: SKP: 99913728( 24393 blks) ==> 812713968:99913740
168: RAW: 41992192( 10252 blks) ==> 812713980:41992204
169: SKP: 1031749632( 251892 blks) ==> 854706184:1031749644
170: RAW: 8192( 2 blks) ==> 854706196:8204
171: SKP: 268427264( 65534 blks) ==> 854714400:268427276
172: RAW: 8192( 2 blks) ==> 854714412:8204
173: SKP: 671080448( 163838 blks) ==> 854722616:671080460
174: RAW: 8192( 2 blks) ==> 854722628:8204
175: SKP: 57344( 14 blks) ==> 854730832:57356
176: RAW: 4096( 1 blks) ==> 854730844:4108
177: SKP: 61440( 15 blks) ==> 854734952:61452
178: RAW: 53248( 13 blks) ==> 854734964:53260
179: SKP: 33501184( 8179 blks) ==> 854788224:33501196
180: RAW: 143360( 35 blks) ==> 854788236:143372
181: SKP: 100388864( 24509 blks) ==> 854931608:100388876
182: RAW: 413696( 101 blks) ==> 854931620:413708
183: SKP: 2012852224( 491419 blks) ==> 855345328:2012852236
184: RAW: 12288( 3 blks) ==> 855345340:12300
185: SKP: 53248( 13 blks) ==> 855357640:53260
186: RAW: 4096( 1 blks) ==> 855357652:4108
187: SKP: 61440( 15 blks) ==> 855361760:61452
188: RAW: 4096( 1 blks) ==> 855361772:4108
189: SKP: 33550336( 8191 blks) ==> 855365880:33550348
190: RAW: 32768( 8 blks) ==> 855365892:32780
191: SKP: 100499456( 24536 blks) ==> 855398672:100499468
192: RAW: 8192( 2 blks) ==> 855398684:8204
193: SKP: 3665920( 895 blks) ==> 855406888:3665932
194: RAW: 10407936( 2541 blks) ==> 855406900:10407948
195: SKP: 1999183872( 488082 blks) ==> 865814848:1999183884
196: RAW: 8192( 2 blks) ==> 865814860:8204
197: SKP: 57344( 14 blks) ==> 865823064:57356
198: RAW: 4096( 1 blks) ==> 865823076:4108
199: SKP: 61440( 15 blks) ==> 865827184:61452
200: RAW: 32768( 8 blks) ==> 865827196:32780
201: SKP: 33521664( 8184 blks) ==> 865859976:33521676
202: RAW: 20480( 5 blks) ==> 865859988:20492
203: SKP: 100511744( 24539 blks) ==> 865880480:100511756
204: RAW: 10952704( 2674 blks) ==> 865880492:10952716
205: SKP: 8192( 2 blks) ==> 876833208:8204
206: RAW: 49152( 12 blks) ==> 876833220:49164
207: SKP: 2002255872( 488832 blks) ==> 876882384:2002255884
208: RAW: 8192( 2 blks) ==> 876882396:8204
209: SKP: 57344( 14 blks) ==> 876890600:57356
210: RAW: 4096( 1 blks) ==> 876890612:4108
211: SKP: 61440( 15 blks) ==> 876894720:61452
212: RAW: 1867776( 456 blks) ==> 876894732:1867788
213: SKP: 31686656( 7736 blks) ==> 878762520:31686668
214: RAW: 2379776( 581 blks) ==> 878762532:2379788
215: SKP: 98152448( 23963 blks) ==> 881142320:98152460
216: RAW: 8192( 2 blks) ==> 881142332:8204
217: SKP: 3665920( 895 blks) ==> 881150536:3665932
218: RAW: 107188224( 26169 blks) ==> 881150548:107188236
219: SKP: 1902403584( 464454 blks) ==> 988338784:1902403596
220: RAW: 8192( 2 blks) ==> 988338796:8204
221: SKP: 57344( 14 blks) ==> 988347000:57356
222: RAW: 4096( 1 blks) ==> 988347012:4108
223: SKP: 61440( 15 blks) ==> 988351120:61452
224: RAW: 45056( 11 blks) ==> 988351132:45068
225: SKP: 33509376( 8181 blks) ==> 988396200:33509388
226: RAW: 24576( 6 blks) ==> 988396212:24588
227: SKP: 100507648( 24538 blks) ==> 988420800:100507660
228: RAW: 3694592( 902 blks) ==> 988420812:3694604
229: SKP: 8192( 2 blks) ==> 992115416:8204
230: RAW: 172032( 42 blks) ==> 992115428:172044
231: SKP: 8192( 2 blks) ==> 992287472:8204
232: RAW: 126976( 31 blks) ==> 992287484:126988
233: SKP: 8192( 2 blks) ==> 992414472:8204
234: RAW: 49152( 12 blks) ==> 992414484:49164
235: SKP: 8192( 2 blks) ==> 992463648:8204
236: RAW: 110592( 27 blks) ==> 992463660:110604
237: SKP: 8192( 2 blks) ==> 992574264:8204
238: RAW: 1802240( 440 blks) ==> 992574276:1802252
239: SKP: 2007269376( 490056 blks) ==> 994376528:2007269388
-- Total: -----------------------------------------------------------
240 CHUNK 15032385536(3670016 blks) ==> 994376540(242767 blks)
done.
system.img built successfully.
copying dtbfile(/home/austin/Desktop/Tegra_Yocto/Linux_for_Tegra/kernel/dtb/tegra124-jetson_tk1-pm375-000-c00-00.dtb)... done.
copying cfgfile(/home/austin/Desktop/Tegra_Yocto/Linux_for_Tegra/bootloader/ardbeg/cfg/gnu_linux_fastboot_emmc_full.cfg) to flash.cfg... done.
creating gpt(ppt.img)...
*** GPT Parameters ***
Device Sector Size ------- 512
device size -------------- 15766388736
bootpart size ------------ 8388608
userpart size ------------ 15758000128
Erase Block Size --------- 2097152
FS Buffer size ----------- 4096
Partition Config file ---- flash.cfg
Visible partition flag --- GP1
Primary GPT output ------- PPT->ppt.img
Secondary GPT output ----- GPT->gpt.img
Target device name ------- none
*** PARTITION LAYOUT(20 partitions) ***
[ BCT] BH 0 16383 8.0MiB
[ PPT] UH 0 4095 2.0MiB ppt.img
[ PT] UH 4096 8191 2.0MiB
[ EBT] UH 8192 16383 4.0MiB u-boot.bin
[ LNX] UH 16384 49151 16.0MiB
[ SOS] UH 49152 61439 6.0MiB
[ NVC] UH 61440 65535 2.0MiB
[ MPB] UH 65536 77823 6.0MiB
[ MBP] UH 77824 90111 6.0MiB
[ GP1] UH 90112 94207 2.0MiB
[ APP] UV 94208 29454335 14336.0MiB system.img
[ DTB] UV 29454336 29462527 4.0MiB tegra124-jetson_tk1-pm375-000-c00-00.dtb
[ EFI] UV 29462528 29593599 64.0MiB
[ USP] UV 29593600 29601791 4.0MiB
[ TP1] UV 29601792 29609983 4.0MiB
[ TP2] UV 29609984 29618175 4.0MiB
[ TP3] UV 29618176 29626367 4.0MiB
[ WB0] UV 29626368 29630463 2.0MiB
[ UDA] UV 29630464 30773247 558.0MiB
[ GPT] UH 30773248 30777343 2.0MiB gpt.img
copying flasher(/home/austin/Desktop/Tegra_Yocto/Linux_for_Tegra/bootloader/ardbeg/fastboot.bin)... done.
Existing flashapp(/home/austin/Desktop/Tegra_Yocto/Linux_for_Tegra/bootloader/nvflash) reused.
*** Flashing target device started. ***
./nvflash --bct PM375_Hynix_2GB_H5TC4G63AFR_H5TC4G63CFR_RDA_924MHz.cfg --setbct --configfile flash.cfg --create --bl fastboot.bin --odmdata 0x6009C000 --go
Nvflash 4.13.0000 started
BR_CID: 0x34001001741141021c00000015fc8400
rcm version 0X400001
Skipping BoardID read at miniloader level
System Information:
chip name: unknown
chip id: 0x40 major: 1 minor: 1
chip sku: 0x0
chip uid: 0x00000001741141021c00000015fc8400
macrovision: disabled
hdcp: disabled
jtag: disabled
sbk burned: false
board id: 0
warranty fuse: 0
dk burned: false
boot device: emmc
operating mode: 3
device config strap: 0
device config fuse: 0
sdram config strap: 0
RCM communication completed
BCT sent successfully
sending file: tegra124-jetson_tk1-pm375-000-c00-00.dtb
- 59661/59661 bytes sent
tegra124-jetson_tk1-pm375-000-c00-00.dtb sent successfully
odm data: 0x6009c000
downloading bootloader -- load address: 0x83d88000 entry point: 0x83d88000
sending file: fastboot.bin
- 594363/594363 bytes sent
fastboot.bin sent successfully
waiting for bootloader to initialize
bootloader downloaded successfully
ML execution and Cpu Handover took 1 Secs
Partition backup took 0 Secs
setting device: 2 3
deleting device partitions
creating partition: BCT
creating partition: PPT
creating partition: PT
creating partition: EBT
creating partition: LNX
creating partition: SOS
creating partition: NVC
creating partition: MPB
creating partition: MBP
creating partition: GP1
creating partition: APP
creating partition: DTB
creating partition: EFI
creating partition: USP
creating partition: TP1
creating partition: TP2
creating partition: TP3
creating partition: WB0
creating partition: UDA
creating partition: GPT
sending file: ppt.img
\ 2097152/2097152 bytes sent
ppt.img sent successfully
padded 15 bytes to bootloader
sending file: u-boot.bin
- 507712/507712 bytes sent
u-boot.bin sent successfully
sending file: system.img
- 994376540/994376540 bytes sent
system.img sent successfully
sending file: gpt.img
gpt.img sent successfully
Create, format and download took 131 Secs
Time taken for flashing 134 Secs
*** The target ardbeg has been flashed successfully. ***
Reset the board to boot from internal eMMC.
I am already aware of these somewhat similar threads, but they don’t seem to help me in my situation:
https://devtalk.nvidia.com/default/topic/802953/jetson-tk1/how-to-compile-amp-install-mainline-u-boot-/
https://devtalk.nvidia.com/default/topic/935452/jetson-tk1/compiled-u-boot-from-source-does-not-work/
https://devtalk.nvidia.com/default/topic/905345/built-tx1-u-boot-from-source/
Can someone please help me out, it would be much appreciated.
Thanks,
Austin
