I am attempting to specify multiple kernels on a single bootloader, and then have those kernels each with their own partition that they can have a unique rootfs on.
I have edited the extlinux.conf to add a backup kernel, and then specified a separate partition for each:
LABEL primary
MENU LABEL primary kernel
LINUX /boot/Image
FDT /boot/dtb/kernel_tegra234-p3701-0005-p3737-0000.dtb
INITRD /boot/initrd
APPEND ${cbootargs} root=/dev/mmcblk0p2 rw rootwait rootfstype=ext4
LABEL previous
MENU LABEL previous kernel
LINUX /boot/Image-previous
INITRD /boot/initrd
APPEND ${cbootargs} root=/dev/mmcblk0p3 rw rootwait rootfstype=ext4
I have a few questions:
Is this possible to flash two separate and different rootfs at flashing time to the different partitions?
Will the common bootloader files e.g. /boot be placed automatically in mmcblk0p1 in this config?
Is it possible to have both the primary and previous kernel share another partition (lets say mmcblk0p4) for certain common rootfs directories (e.g. /home)?
I am aware of rootfs A/B redundancy support, but this is tied to separate bootloaders. My requirements dictate that I have more redundancy than A/B bootloaders, and separate kernel and rootfs redundancy needs to be present for both bootloaders.
In the extlinux.conf file I am specifying each kernel to boot from a different partition. Based on your response, I would first need to flash to mmcblk0p2 and then clone to mmcblk0p3 so both kernels have a bootable rootfs. I assume this means that the boot files such as the kernel images in /boot will be taken from mmcblk0p2 or whatever the partition that was flashed? Or does it require a copy of the /boot directory in each partition to be able to boot?
Loading the kernel image and mounting the rootfs are two different things. Where to load the kernel image/dtb is determined in the UEFI boot menu, and it’s totally fine that the partition you read these stuff from is different from the one you want to mount as the rootfs.
For example, in the UEFI boot menu, you can boot from mmcblk0p1, and in the extlinux.conf in that partition, you can add two entries stating that you are going to mount mmcblk0p2 and mmcblk0p3 as the rootfs.
So ideally, you don’t need kernel image in partitions that is only meant to be used as rootfs, but I’d suggest using dd to clone the whole partition so you won’t miss anything.
Normally I see the UEFI VFAT partition as the first partition. Until you mentioned this I never really thought about alternate locations, but on my AGX Orin I see the VFAT exists at “mmcblk0p10”. Jetsons always use the first partition in eMMC as the rootfs. It would seem something has been customized, and I can’t really answer your question, but if you run the command “lsblk -f”, do you see “vfat” associated with mmcblk0p10? If so, then perhaps this is where your content goes, while mmcblk0p1 remains rootfs (or one of them).
I mean you can load the kernel and device tree from a partition that is different from the one you want to mount as the rootfs. I’m not referring to the EFI partition here.
I think you will only see bootable devices instead of partitions in UEFI boot menu. So mmcblk0p1 would be used for loading kernel here.
I guess I never really noticed that this file specifies the partition layout and is placing a bunch of the images and dtb files for the bootloader and UEFI all in different partitions.
I am now a little confused as to how the Orin knows where the bootloader image and UEFI dtb files are located and what partitions to access as specified in that flash_t234_qspi_sdmmc.xml file.
I suppose I would need to specify the partitions in this xml file before flashing, to allow for space for my extra rootfs and a shared partition.
However, if I do so and make a rootfs on mmcblk0p2, which is normally the bootloader image partition, will the Orin still find the bootloader image if moved to mmcblk0p3?
Also the A_kernel partition looks like it stores the bootloader image. Can you confirm that despite the name, it’s the bootloader and not the kernel image stored there?
What would be the bare minimum file structure for mmcblk0p1 that the UEFI would show as bootable so that I could then mount to another partition? For example, I would assume /boot and /etc at the very least.
I think these partitions are read by UEFI with UUID instead of fixed name like mmcblk0px, so it won’t cause the issue.
NO.
I’m sure it’s kernel instead of bootloader, but it’s rarely used because kernel/kernel-dtb are read from rootfs by default, instead of from dedicated partitions.
This is configurable in the UEFI boot menu.
If you just want to save disk space, then the basic flavor rootfs should do it.
So then to confirm, the bootloaders are stored and read from the 64MiB QPSI NOR not any partition on the eMMC, and the kernel images/ kernel dtb are read from the rootfs (APP) partition, not the A_kernel or whatever those random partitions specified in the config are?
If so, I can assume I can delete those extra partitions and only keep required ones like ESP?
I suppose I was more asking about what file structure is the minimum for the bootloader to consider a bootable rootfs if all I am using it for is directing it to mount to another partition. So you are saying that I would need a full linux file system, but I can minimize it of course by removing unnecessary modules and files like the basic rootfs flavor does?
Also, going back to the original redundancy request, I modified the partitions on the eMMC to test booting a kernel with a rootfs on another partition:
I cloned the original APP partition (mmcblk0p1) to mmcblk0p16. I then modified the extlinux.conf file to use mmcblk0p16 as the rootfs.
TIMEOUT 30
DEFAULT primary
MENU TITLE L4T boot options
LABEL primary
LINUX /boot/Image
INITRD /boot/initrd
APPEND ${cbootargs} root=/dev/mmcblk0p16 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 console=tty0 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb
I rebooted, but the original APP partition (mmcblk0p1) is still being used. Shouldn’t the bootloader find mmcblk0p1, try to boot from it, but then it reads extlinux.conf which redirects the rootfs mount point to be mmcblk0p16? Any ideas why this does not work?
I placed a file on mmcblk0p1 “test.txt” to identify it. When I rebooted, the “test.txt” file was still there so it loaded mmcblk0p1.
I was able to use fstab to mount the partition on a separate directory, but trying to mount mmcblk0p16 to root either using fstab or extlinux.conf doesn’t work.
Interestingly, I discovered that manually selecting the eMMC as the boot device in the bootloader screen will use the updated extlinux.conf file and boot from mmcblk0p16. However, when I let it boot normally, it just uses mmcblk0p1.
I just tested on my local device (AGX Orin DevKit + L4T 35.4.1), and I can successfully mount /dev/mmcblk0p16 as the rootfs, no matter specifying the boot device in UEFI or not, or using device name or PARTUUID in extlinux.conf.
