I’m using eMMC and SD card on Jetson AGX Orin devkit. When ROOTFS_AB is enabled on eMMC and switching between slots, different eMMC partitions are used for rootfs. However for SD card when switching between slots, the same partition is used for rootfs.
Here is the console output for eMMC case:
# nvbootctrl -t rootfs dump-slots-info
Current rootfs slot: A
Active rootfs slot: A
num_slots: 2
slot: 0, retry_count: 3, status: normal
slot: 1, retry_count: 3, status: normal
# nvbootctrl dump-slots-info
Current version: 35.4.1
Capsule update status: 0
Current bootloader slot: A
Active bootloader slot: A
num_slots: 2
slot: 0, status: normal
slot: 1, status: normal
# nvbootctrl get-current-slot
0
# lsblk -l
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
loop0 7:0 0 16M 1 loop
mmcblk0 179:0 0 59.3G 0 disk
mmcblk0p1 179:1 0 27G 0 part /
mmcblk0p2 179:2 0 27G 0 part
mmcblk0p3 179:3 0 128M 0 part
mmcblk0p4 179:4 0 768K 0 part
mmcblk0p5 179:5 0 31.6M 0 part
mmcblk0p6 179:6 0 128M 0 part
mmcblk0p7 179:7 0 768K 0 part
mmcblk0p8 179:8 0 31.6M 0 part
mmcblk0p9 179:9 0 80M 0 part
mmcblk0p10 179:10 0 512K 0 part
mmcblk0p11 179:11 0 64M 0 part
mmcblk0p12 179:12 0 80M 0 part
mmcblk0p13 179:13 0 512K 0 part
mmcblk0p14 179:14 0 64M 0 part
mmcblk0p15 179:15 0 400M 0 part
mmcblk0p16 179:16 0 479.5M 0 part
The rootfs for eMMC slot 0 is mounted from mmcblk0p1 partition.
After switching active slot to 1 and rebooting the devkit:
1
root@jetsonDevkit2:~# lsblk -l
mmcblk0p2 179:2 0 27G 0 part /
The rootfs for eMMC slot 1 is mounted from mmcblk0p2 partition, different partition than slot 0.
Installed and formatted Micro SD card in Jetson agx orin devkit, which is recognized as as mmcblk1
SD card image is flashed using this command:
sudo ROOTFS_AB=1 ./tools/kernel_flash/l4t_initrd_flash.sh --external-device mmcblk1p1 -c ./tools/kernel_flash/flash_l4t_external.xml --showlogs --network usb0 jetson-agx-orin-devkit internal
The boot order changed to boot from SD card. After reboot:
Current rootfs slot: B
Active rootfs slot: B
num_slots: 2
Current bootloader slot: B
Active bootloader slot: B
num_slots: 2
1
# lsblk -l
mmcblk1 179:32 0 953.6G 0 disk
mmcblk1p1 179:33 0 27G 0 part /
mmcblk1p2 179:34 0 128M 0 part
mmcblk1p3 179:35 0 768K 0 part
mmcblk1p4 179:36 0 31.6M 0 part
mmcblk1p5 179:37 0 128M 0 part
mmcblk1p6 179:38 0 768K 0 part
mmcblk1p7 179:39 0 31.6M 0 part
mmcblk1p8 179:40 0 80M 0 part
mmcblk1p9 179:41 0 512K 0 part
mmcblk1p10 179:42 0 300M 0 part
mmcblk1p11 179:43 0 64M 0 part
mmcblk1p12 179:44 0 80M 0 part
mmcblk1p13 179:45 0 512K 0 part
mmcblk1p14 179:46 0 64M 0 part
The rootfs for SD card slot 1 is mounted from mmcblk1p1 partition.
After changing the SD card slot from 1 to 0 and rebooting the devkit:
0
# lsblk -l
The rootfs for SD card slot 0 is using the same mmcblk1p1 partition as slot 1.
While eMMC slots are using different rootfs partitions, why the SD card with ROOTFS_AB enabled is using the same partition for both slots?
