`nvsdkmanager_flash` doesn't partition as expected
The command I used is
sudo -E ROOTFS_AB=1 ROOTFSSIZE=240GiB ./nvsdkmanager_flash.sh --storage nvme0n1p1
I expected nvme0n1p1 and nvme0n1p2 to be both 120GiB, instead I have nothing that is 120GiB and my rootfs partition is on mmcblk0p1 and mmcblk0p2.
A followup question is:
  1. Can I adjust partitions via a rootfs.tar based OTA?
  2. Can I encrypt my disk and do an OTA? I read documentation say this is possible, but someone (I think a mod, not sure) on the forum say r35 onwards it isn’t possible. Not sure which source to follow (source: Disk Encryption Feature Support - #11 by JerryChang)
I am running AGX Orin DevKit with r35_release_v5.0/release/ota_tools_R35.5.0_aarch64.tbz2
Just want to know which part I’m messing up in!
Thanks for the patience and help folks!
Hi sabhinav,
Partition is determined from the partition layout XML. We don’t suggest you modify it if you are not familiar with how it works.
Disk-encryption for OTA is supported from R35.5.0. (i.e. you can flash your board with disk-encryption in R35.4.1 and perform image-based OTA updating to R35.5.0)
Please use initrd flash command and -S option to specify the size for rootfs to flash your NVMe SSD.
If you want to enable rootfs a/b and get 120GiB for each rootfs partition, please just specify -S 120GiB in the initrd flash command.
SDK Manager never supports ROOTFS_AB.
Thanks @KevinFFF - sudo ROOTFS_AB=1 ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1 -S 120GiB -c ./tools/kernel_flash/flash_l4t_t234_nvme.xml jetson-agx-orin-devkit external is what I ran right now.
NAME         MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
loop0          7:0    0    16M  1 loop
mmcblk0      179:0    0  59.3G  0 disk
├─mmcblk0p1  179:1    0    27G  0 part
├─mmcblk0p2  179:2    0    27G  0 part
├─mmcblk0p3  179:3    0   128M  0 part
├─mmcblk0p4  179:4    0   768K  0 part
├─mmcblk0p5  179:5    0  31.6M  0 part
├─mmcblk0p6  179:6    0   128M  0 part
├─mmcblk0p7  179:7    0   768K  0 part
├─mmcblk0p8  179:8    0  31.6M  0 part
├─mmcblk0p9  179:9    0    80M  0 part
├─mmcblk0p10 179:10   0   512K  0 part
├─mmcblk0p11 179:11   0    64M  0 part
├─mmcblk0p12 179:12   0    80M  0 part
├─mmcblk0p13 179:13   0   512K  0 part
├─mmcblk0p14 179:14   0    64M  0 part
├─mmcblk0p15 179:15   0   400M  0 part
└─mmcblk0p16 179:16   0 479.5M  0 part
zram0        251:0    0   2.6G  0 disk [SWAP]
zram1        251:1    0   2.6G  0 disk [SWAP]
zram2        251:2    0   2.6G  0 disk [SWAP]
zram3        251:3    0   2.6G  0 disk [SWAP]
zram4        251:4    0   2.6G  0 disk [SWAP]
zram5        251:5    0   2.6G  0 disk [SWAP]
zram6        251:6    0   2.6G  0 disk [SWAP]
zram7        251:7    0   2.6G  0 disk [SWAP]
zram8        251:8    0   2.6G  0 disk [SWAP]
zram9        251:9    0   2.6G  0 disk [SWAP]
zram10       251:10   0   2.6G  0 disk [SWAP]
zram11       251:11   0   2.6G  0 disk [SWAP]
nvme0n1      259:0    0 931.5G  0 disk
├─nvme0n1p1  259:1    0 930.1G  0 part /
├─nvme0n1p2  259:2    0   128M  0 part
├─nvme0n1p3  259:3    0   768K  0 part
├─nvme0n1p4  259:4    0  31.6M  0 part
├─nvme0n1p5  259:5    0   128M  0 part
├─nvme0n1p6  259:6    0   768K  0 part
├─nvme0n1p7  259:7    0  31.6M  0 part
├─nvme0n1p8  259:8    0    80M  0 part
├─nvme0n1p9  259:9    0   512K  0 part
├─nvme0n1p10 259:10   0    64M  0 part
├─nvme0n1p11 259:11   0    80M  0 part
├─nvme0n1p12 259:12   0   512K  0 part
├─nvme0n1p13 259:13   0    64M  0 part
├─nvme0n1p14 259:14   0   400M  0 part
└─nvme0n1p15 259:15   0 479.5M  0 part
Is what is generated. Instead I want 1 50GiB MMC partition and two 120GiB NVME partitions.
It seems there’s only one rootfs in your NVMe drive (i.e. rootfs a/b is not enabled).
Do you mean the result you shared is from above command?
If so, please share the full flash log for further check.
It is the result of the flash, I get that on running lsblk.
Here’s the logs: Flash Log for initrd Jetson AGX Orin DevKit - Pastebin.com
It seems you’ve flash the board successfully and check the disk is encrypted in How do I verify if my Jetson AGX Orin Devkit was encrypted? - #2
