Flash a configuration that emulates a Jetson Orin NX to NVMeSSD
I am trying to flash the Jetson AGX Orin devkit to emulate a Jetson Orin NX with NVMe SSD.
I used the following command.
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml --network usb0 --showlogs jetson-agx-orin-devkit-as-nx-16gb external
But, following error appears in the UART serial console during flashing.
So, I interrupted flashing.
[   37.113817] ------------[ cut here ]------------
[   37.113956] WARNING: CPU: 4 PID: 2529 at drivers/mtd/devices/qspi_mtd.c:514 0xffffa5e4ab109960
[   37.114176] Modules linked in: pwm_fan spi_tegra210_qspi ofpart cmdlinepart qspi_mtd mtd
[   37.114400] CPU: 4 PID: 2529 Comm: flash_erase Tainted: G        W         5.10.104-tegra #1
[   37.122697] Hardware name: Unknown Jetson AGX Orin as NX-16GB/Jetson AGX Orin as NX-16GB, BIOS 2.1-32413640 01/24/2023
[   37.133372] pstate: 00400009 (nzcv daif +PAN -UAO -TCO BTYPE=--)
[   37.139146] pc : 0xffffa5e4ab109960
[   37.142734] lr : 0xffffa5e4ab109914
[   37.146322] sp : ffff80001d0fb6e0
[   37.149646] x29: ffff80001d0fb6e0 x28: ffff80001d0fb948
[   37.155072] x27: ffff42d08aea5700 x26: 0000000000000001
[   37.160496] x25: 0000000000000000 x24: ffff42d3a396e5d0
[   37.165921] x23: 0000000000000001 x22: ffff80001d0fb947
[   37.171432] x21: ffff42d3a396e080 x20: ffff42d08aea5700
[   37.176947] x19: ffff80001d0fb738 x18: 0000000000000010
[   37.182458] x17: 0000000000000020 x16: ffffa5e514de8e60
[   37.187970] x15: 0000000000000039 x14: 00000000000006be
[   37.193308] x13: 0000000000004369 x12: 0000000000000024
[   37.198821] x11: 071c71c71c71c71c x10: 0000000000000a80
[   37.204333] x9 : ffff80001d0fb390 x8 : ffff42d08aea61e0
[   37.209672] x7 : 0000000000000f99 x6 : 0000000000000003
[   37.215008] x5 : 0000000000000000 x4 : 0000000000000000
[   37.220434] x3 : ffff42d08aea5700 x2 : 0000000000000000
[   37.225771] x1 : ffff42d08aea5700 x0 : 0000000000000084
[   37.231109] Call trace:
[   37.233560]  0xffffa5e4ab109960
[   37.236709]  0xffffa5e4ab109b28
[   37.239684]  0xffffa5e4ab10a298
[   37.242660]  0xffffa5e4ab10a538
[   37.245813]  mtd_erase+0xe8/0x1d0 [mtd]
[   37.249574]  add_mtd_partitions+0x20f4/0x2a30 [mtd]
[   37.254386]  add_mtd_partitions+0x2848/0x2a30 [mtd]
[   37.259201]  __arm64_sys_ioctl+0xac/0xf0
[   37.263136]  el0_svc_common.constprop.0+0x80/0x1d0
[   37.267948]  do_el0_svc+0x38/0xb0
[   37.271187]  el0_svc+0x1c/0x30
[   37.274333]  el0_sync_handler+0xa8/0xb0
[   37.278096]  el0_sync+0x16c/0x180
[   37.281336] ---[ end trace 38f8d6eee35c7866 ]---
[   37.285899] qspi_mtd spi6.0: block protection enabled 132
[   37.309823] ------------[ cut here ]------------
[   37.309962] WARNING: CPU: 4 PID: 2529 at drivers/mtd/devices/qspi_mtd.c:514 0xffffa5e4ab109960
[   37.310175] Modules linked in: pwm_fan spi_tegra210_qspi ofpart cmdlinepart qspi_mtd mtd
[   37.312399] CPU: 4 PID: 2529 Comm: flash_erase Tainted: G        W         5.10.104-tegra #1
[   37.320884] Hardware name: Unknown Jetson AGX Orin as NX-16GB/Jetson AGX Orin as NX-16GB, BIOS 2.1-32413640 01/24/2023
[   37.331561] pstate: 00400009 (nzcv daif +PAN -UAO -TCO BTYPE=--)
[   37.337335] pc : 0xffffa5e4ab109960
[   37.340921] lr : 0xffffa5e4ab109914
[   37.344508] sp : ffff80001d0fb6e0
[   37.347834] x29: ffff80001d0fb6e0 x28: ffff80001d0fb948
[   37.353259] x27: ffff42d08aea5700 x26: 0000000000000001
[   37.358683] x25: 0000000000000000 x24: ffff42d3a396e5d0
[   37.364108] x23: 0000000000000001 x22: ffff80001d0fb947
[   37.369620] x21: ffff42d3a396e080 x20: ffff42d08aea5700
[   37.375134] x19: ffff80001d0fb738 x18: 0000000000000000
[   37.380646] x17: 0000000000000000 x16: ffffa5e514de8e60
[   37.386158] x15: 0000000000000000 x14: 0000000000000010
[   37.391496] x13: 0000000000000684 x12: 0000000000000024
[   37.397008] x11: 071c71c71c71c71c x10: 0000000000000a80
[   37.402522] x9 : ffff80001d0fb390 x8 : ffff42d08aea61e0
[   37.407859] x7 : 0000000000000013 x6 : 0000000000000003
[   37.413197] x5 : 0000000000000000 x4 : 0000000000000000
[   37.418621] x3 : ffff42d08aea5700 x2 : 0000000000000000
[   37.423960] x1 : ffff42d08aea5700 x0 : 0000000000000084
[   37.429297] Call trace:
[   37.431747]  0xffffa5e4ab109960
[   37.434896]  0xffffa5e4ab109b28
[   37.437872]  0xffffa5e4ab10a298
[   37.440847]  0xffffa5e4ab10a538
[   37.444000]  mtd_erase+0xe8/0x1d0 [mtd]
[   37.447759]  add_mtd_partitions+0x20f4/0x2a30 [mtd]
[   37.452573]  add_mtd_partitions+0x2848/0x2a30 [mtd]
[   37.457389]  __arm64_sys_ioctl+0xac/0xf0
[   37.461327]  el0_svc_common.constprop.0+0x80/0x1d0
[   37.466135]  do_el0_svc+0x38/0xb0
[   37.469374]  el0_svc+0x1c/0x30
[   37.472523]  el0_sync_handler+0xa8/0xb0
[   37.476285]  el0_sync+0x16c/0x180
[   37.479521] ---[ end trace 38f8d6eee35c7867 ]---
[   37.484091] qspi_mtd spi6.0: block protection enabled 132
[   37.505827] ------------[ cut here ]------------
my environment
host-pc: ubuntu 18.04
L4T: 35.2.1
Jetson: AGX Orin Developer Kit
host-pc-log
host.log (262.3 KB)
serial console log
serialconsole.log (174.1 KB)
I’ve confirmed that I can flash NVMe SSD without emulating Orin NX in the same environment using the following command.
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml --network usb0 --showlogs jetson-agx-orin-devkit external
I want to know if I can emulate OrinNX and flash to NVMeSSD.
If I can, how can I do it?
When you flash emmc with flash.sh but with “jetson-agx-orin-devkit-as-nx-16gb”, could you see the nvme drive after boot into kernel?
thank you for reply.
Yes, I can see nvme device.
Thanks for reporting this issue. We will check.
Hi S.Harumoto,
Please try below command:
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml --no-systemimg" --network usb0 --no-flash jetson-agx-orin-devkit-as-nx-16gb external
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml --no-systemimg" --network usb0 --use-backup-image jetson-agx-orin-devkit external
I tried these commands but the same error appeared.
host-pc-log
initrd_flash_host20230206.log (329.9 KB)
serial console log
initrd_flash_uart_20230206.log (518.2 KB)
Hi S.Harumoto,
Can you use another NVMe SSD to try again?
I tried another NVMe SSD, but the same error appeared.
I think that there is no problem in NVMeSSD. bacause I can flash NVMeSSD without emulating Orin NX.
I also tried my first posted command in R35.1.
It works correctly.
So, I think the some changes in R35.2.1 are causing this error.
Hi S.Harumoto,
Typo on second command, I’m sorry…
Please run first command to create image, and change the second command with “jetson-agx-orin-devkit” config.
Flashing successfully completed.
Thank you for your help.
