I’m using an Orin NX 16GB on a Orin Nano carrier board. The goal was to enable Disk Encryption. With commands from here I’ve managed to make encryption with custom keys. But there is some problem with partitioning disk while flashing.
I’ve tried different disks with different sizes but the maximum size that I can flash Jetson is 59 GB.
and using flag -S <size>GIB, where size - is rootfs size more than 59, I get two type of errors, that are randomly appearing. Such as: End sector for APP_ENC, expected at: 122159070, actual: 0 Error: Return value 4
Or Error: Could not stat device /dev/mmcblk0 - No such file or directory
I’ve already tried to patch flash_l4t_t234_nvme_rootfs_enc.xml but no results. Is there something I missed?
Hi carolyuu,
Tried your command, but it’s the same result as before. Attaching screenshot from flashing to another disk.
UPD: tried this command sudo ROOTFS_ENC=1 EXT_NUM_SECTORS=209715200 ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs --no-flash --external-device nvme0n1p1 -i ./ekb.key -c ./tools/kernel_flash/flash_l4t_t234_nvme_rootfs_enc.xml -S 100GiB --external-only --append --network usb0 jetson-orin-nano-devkit external
And still having error:
[ 2.7967 ] End sector for APP_ENC, expected at: 209715166, actual: 0
Command tegraparser_v2 --generategpt --pt flash.xml.bin
Error: /home/user/Desktop/Linux_for_Tegra/bootloader/signed/flash.idx is not found
Error: failed to relocate images to /home/user/Desktop/Linux_for_Tegra/tools/kernel_flash/images
Cleaning up...
hi JerryChang,
output looks the same as on my screenshot.
user@jetson:~$ sudo fdisk -l /dev/nvme0n1
Disk /dev/nvme0n1: 465.78 GiB, 500107862016 bytes, 976773168 sectors
Disk model: Samsung SSD 970 EVO Plus 500GB
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 6B40C178-1EFB-478F-A849-6D60623FA474
Device Start End Sectors Size Type
/dev/nvme0n1p1 3050048 3869247 819200 400M Microsoft basic data
/dev/nvme0n1p2 3869248 118393407 114524160 54.6G Microsoft basic data
/dev/nvme0n1p3 40 262183 262144 128M Microsoft basic data
/dev/nvme0n1p4 262184 263719 1536 768K Microsoft basic data
/dev/nvme0n1p5 263720 328487 64768 31.6M Microsoft basic data
/dev/nvme0n1p6 328488 590631 262144 128M Microsoft basic data
/dev/nvme0n1p7 590632 592167 1536 768K Microsoft basic data
/dev/nvme0n1p8 592168 656935 64768 31.6M Microsoft basic data
/dev/nvme0n1p9 656936 820775 163840 80M Microsoft basic data
/dev/nvme0n1p10 820776 821799 1024 512K Microsoft basic data
/dev/nvme0n1p11 821800 952871 131072 64M EFI System
/dev/nvme0n1p12 952872 1116711 163840 80M Microsoft basic data
/dev/nvme0n1p13 1116712 1117735 1024 512K Microsoft basic data
/dev/nvme0n1p14 1117736 1248807 131072 64M Microsoft basic data
/dev/nvme0n1p15 1248832 2068031 819200 400M Microsoft basic data
/dev/nvme0n1p16 2068032 3050047 982016 479.5M Microsoft basic data
I’ve tried parted
user@jetson:~$ sudo parted /dev/nvme0n1
GNU Parted 3.3
Using /dev/nvme0n1
Welcome to GNU Parted! Type 'help' to view a list of commands.
(parted) print free
Model: Samsung SSD 970 EVO Plus 500GB (nvme)
Disk /dev/nvme0n1: 500GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
17.4kB 20.5kB 3072B Free Space
3 20.5kB 134MB 134MB A_kernel msftdata
4 134MB 135MB 786kB A_kernel-dtb msftdata
5 135MB 168MB 33.2MB A_reserved_on_user msftdata
6 168MB 302MB 134MB B_kernel msftdata
7 302MB 303MB 786kB B_kernel-dtb msftdata
8 303MB 336MB 33.2MB B_reserved_on_user msftdata
9 336MB 420MB 83.9MB recovery msftdata
10 420MB 421MB 524kB recovery-dtb msftdata
11 421MB 488MB 67.1MB fat32 esp boot, esp
12 488MB 572MB 83.9MB recovery_alt msftdata
13 572MB 572MB 524kB recovery-dtb_alt msftdata
14 572MB 639MB 67.1MB esp_alt msftdata
639MB 639MB 12.3kB Free Space
15 639MB 1059MB 419MB UDA msftdata
16 1059MB 1562MB 503MB reserved msftdata
1 1562MB 1981MB 419MB ext4 APP msftdata
2 1981MB 60.6GB 58.6GB APP_ENC msftdata
60.6GB 500GB 439GB Free Space
