When I changed the custom partition to 900G, the flash failed.Please help me find the reason, thank you!
Add a custom partition
flash_l4t_t234_nvme-v2.xml
blockdev: cannot open /dev/mmcblk0boot0: No such file or directory
[ 0]: l4t_flash_from_kernel: Starting to create gpt for emmc
Active index file is /mnt/internal/flash.idx
Number of lines is 58
max_index=57
[ 2]: l4t_flash_from_kernel: Successfully create gpt for emmc
[ 2]: l4t_flash_from_kernel: Starting to create gpt for external device
Active index file is /mnt/external/flash.idx
Number of lines is 19
max_index=18
writing item=1, 9:0:primary_gpt, 512, 19968, gpt_primary_9_0.bin, 16896, fixed-<reserved>-0, 8f9c15f324262cca7636df7b7a0bc64fda930ecd
Writing primary_gpt partition with gpt_primary_9_0.bin
Offset is not aligned to K Bytes, no optimization is applied
dd if=/mnt/external/gpt_primary_9_0.bin of=/dev/nvme0n1 bs=1 skip=0 seek=512 count=16896
16896+0 records in
16896+0 records out
16896 bytes (17 kB, 16 KiB) copied, 0.0190197 s, 888 kB/s
Writing primary_gpt partition done
Error: The backup GPT table is corrupt, but the primary appears OK, so that will be used.
Warning: Not all of the space available to /dev/nvme0n1 appears to be used, you can fix the GPT to use all of the space (an extra 1878250159 blocks) or continue with the current setting?
Error: Can't have the end before the start! (start sector=122159072 length=-1)
[ 8]: l4t_flash_from_kernel: Error: partprobe failed. This indicates that:
- the xml indicates the gpt is larger than the device storage
- the xml might be invalid
- the device might have a problem.
Please make correction.
Flash failure
Cleaning up...
Hi WayneWWW:
Because we only want to reserve 64G for the system, the rest are our own customized partitions. Separating the system and our own content will help us manage our own related files and programs.
Waiting for device to expose ssh ......RTNETLINK answers: File exists
Waiting for device to expose ssh ...Run command: flash on fc00:1:1:0::2
SSH ready
max_index=57
max_index=18
writing item=1, 9:0:primary_gpt, 512, 19968, gpt_primary_9_0.bin, 16896, fixed-<reserved>-0, 099348700e302cbe25df245fed482859b0093450
16896+0 records in
16896+0 records out
16896 bytes (17 kB, 16 KiB) copied, 0.018006 s, 938 kB/s
Warning: Not all of the space available to /dev/nvme0n1 appears to be used, you can fix the GPT to use all of the space (an extra 1819307439 blocks) or continue with the current setting?
Error: Can't have the end before the start! (start sector=134217696 length=-1)
[ 9]: l4t_flash_from_kernel: Error: partprobe failed. This indicates that:
Flash failure
Cleaning up...
I changed it to -s 50GiB, but the problem still exists.
SSH ready
max_index=57
[ 1]: l4t_flash_from_kernel: Successfully create gpt for emmc
[ 1]: l4t_flash_from_kernel: Starting to create gpt for external device
max_index=18
writing item=1, 9:0:primary_gpt, 512, 19968, gpt_primary_9_0.bin, 16896, fixed-<reserved>-0, 9e1ce9b7038e9c236a2831579cd822eb2e878783
16896+0 records in
16896+0 records out
16896 bytes (17 kB, 16 KiB) copied, 0.0176537 s, 957 kB/s
Warning: Not all of the space available to /dev/nvme0n1 appears to be used, you can fix the GPT to use all of the space (an extra 1866191535 blocks) or continue with the current setting?
Flash failure
Cleaning up...
