我修改了tools/kernel_flash/flash_l4t_external.xml,添加了一个userdata分区:
<partition_layout version="01.00.0000">
<device type="external" instance="0" sector_size="512" num_sectors="EXT_NUM_SECTORS" >
<partition name="master_boot_record" type="protective_master_boot_record">
<allocation_policy> sequential </allocation_policy>
<filesystem_type> basic </filesystem_type>
<size> 512 </size>
<file_system_attribute> 0 </file_system_attribute>
<allocation_attribute> 8 </allocation_attribute>
<percent_reserved> 0 </percent_reserved>
</partition>
<partition name="primary_gpt" type="primary_gpt">
<size> 19968 </size>
</partition>
<partition name="A_kernel" id="3" type="kernel">
<size> 134217728 </size>
<filename> LNXFILE </filename>
</partition>
<partition name="A_kernel-dtb" type="kernel_dtb">
<size> 786432 </size>
<filename> DTB_FILE </filename>
</partition>
<partition name="A_reserved_on_user" type="data">
<size> 33161216 </size>
</partition>
<partition name="B_kernel" type="kernel">
</partition>
<partition name="B_kernel-dtb" type="kernel_dtb">
</partition>
<partition name="B_reserved_on_user" type="data">
</partition>
<partition name="RECNAME" type="kernel">
<size> RECSIZE </size>
<filename> RECFILE </filename>
</partition>
<partition name="RECDTB-NAME" type="kernel_dtb">
<size> 524288 </size>
<filename> RECDTB-FILE </filename>
</partition>
<partition name="esp" type="data">
<size> 67108864 </size>
<allocation_attribute> 0x8 </allocation_attribute>
<filename> ESP_FILE </filename>
<partition_type_guid> C12A7328-F81F-11D2-BA4B-00A0C93EC93B </partition_type_guid>
<description> **Required.** EFI system partition with L4T Launcher. </description>
</partition>
<partition name="RECNAME_alt" type="kernel">
</partition>
<partition name="RECDTB-NAME_alt" type="kernel_dtb">
</partition>
<partition name="esp_alt" type="data">
<description> **Required.** EFI system partition for fail-safe ESP update. </description>
</partition>
<partition name="UDA" type="data">
<size> 419430400 </size>
<align_boundary> 16384 </align_boundary>
<description> **Required.** This partition may be mounted and used to store user
data. </description>
</partition>
<partition name="reserved" type="data">
<size> 502792192 </size> <!-- Recalculate the size if RECSIZE changed -->
<description> **Required.** Reserve space in case there is any partition change
required in the future, for example, adding new partitions or increasing size
of some partitions. </description>
</partition>
<partition name="APP" id="1" type="data">
<size> APPSIZE </size>
<allocation_attribute> 0x808 </allocation_attribute>
<unique_guid> APPUUID </unique_guid>
<filename> APPFILE </filename>
<description> **Required.** Contains the rootfs. This partition must be assigned
the "1" for id as it is physically put to the end of the device, so that it
can be accessed as the fixed known special device `/dev/nvme0n1p1`. </description>
</partition>
<partition name="userdata" id="2" type="data">
<size> 115964116992 </size>
<description> **Required.** overlayfs </description>
</partition>
<partition name="secondary_gpt" type="secondary_gpt">
<size> 0xFFFFFFFFFFFFFFFF </size>
</partition>
</device>
</partition_layout>
并且修改了p3767.conf.common文件中ROOTFSSIZE=8GiB;
然后执行下面命令报错:
BOARDID=3701 BOARDSKU=0000 FAB=TS4 ./tools/kernel_flash/l4t_initrd_flash.sh -c tools/kernel_flash/flash_l4t_external.xml --external-device nvme0n1p1 --direct sdd jetson-orin-nano-devkit external
[ 7.0648 ] Disabled BPMP dtb trim, using default dtb
[ 7.0648 ]
[ 7.0655 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_aligned.bct
[ 7.0668 ] tegrahost_v2 --chip 0x23 0 --magicid MEM0 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_aligned.bct zerosbk
[ 7.0671 ] adding BCH for mem_rcm_aligned.bct
[ 7.0712 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 7.0713 ] Assuming zero filled SBK key
[ 7.0730 ] Warning: pub_key.key is not found
[ 7.0723 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
[ 7.0735 ] Copying signatures
[ 7.0740 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 7.0751 ] tegraparser_v2 --generategpt --pt flash.xml.bin
[ 7.0755 ] End sector for userdata, expected at: 119537630, actual: 0
Error: Return value 4
Command tegraparser_v2 --generategpt --pt flash.xml.bin
Error: /home/user/EC5000/Linux_for_Tegra/bootloader/signed/flash.idx is not found
Error: failed to relocate images to /home/user/EC5000/Linux_for_Tegra/tools/kernel_flash/images
Cleaning up...
请问是什么原因?
