Hi All:
I want to add a custom partition and set it to ext4 by default. I did the following, but why is there no new partition?
version:
robot@tegra:~$ more /etc/nv_tegra_release
# R35 (release), REVISION: 4.1, GCID: 33958178, BOARD: t186ref, EABI: aarch64, DATE: Tue Aug 1 19:57:35 UTC 2023
device info:
robot@tegra:~$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
loop0 7:0 0 16M 1 loop
zram0 251:0 0 970M 0 disk [SWAP]
zram1 251:1 0 970M 0 disk [SWAP]
zram2 251:2 0 970M 0 disk [SWAP]
zram3 251:3 0 970M 0 disk [SWAP]
zram4 251:4 0 970M 0 disk [SWAP]
zram5 251:5 0 970M 0 disk [SWAP]
zram6 251:6 0 970M 0 disk [SWAP]
zram7 251:7 0 970M 0 disk [SWAP]
nvme0n1 259:0 0 953.9G 0 disk
├─nvme0n1p1 259:1 0 952.4G 0 part /
├─nvme0n1p2 259:2 0 128M 0 part
├─nvme0n1p3 259:3 0 768K 0 part
├─nvme0n1p4 259:4 0 31.6M 0 part
├─nvme0n1p5 259:5 0 128M 0 part
├─nvme0n1p6 259:6 0 768K 0 part
├─nvme0n1p7 259:7 0 31.6M 0 part
├─nvme0n1p8 259:8 0 80M 0 part
├─nvme0n1p9 259:9 0 512K 0 part
├─nvme0n1p10 259:10 0 64M 0 part
├─nvme0n1p11 259:11 0 80M 0 part
├─nvme0n1p12 259:12 0 512K 0 part
├─nvme0n1p13 259:13 0 64M 0 part
├─nvme0n1p14 259:14 0 400M 0 part
└─nvme0n1p15 259:15 0 479.5M 0 part
device:
orin NX
Modify the file:
Linux_for_Tegra/tools/kernel_flash/flash_l4t_nvme_rootfs_ab.xml
flash_l4t_nvme_rootfs_ab.xml.txt (11.6 KB)
Flash command:
sudo ROOTFS_AB=1 ./flash.sh jetson-orin-nano-devkit-nvme internal
I refer to the following method:
My goal is to be able to create extra partitions by modifying the “flash_l4t_nvme_rootfs_ab.xml” file, and running the command:
sudo ROOTFS_AB=1 ./tools/kernel_flash/l4t_initrd_flash.sh \
--external-device nvme0n1 \
-c ./tools/kernel_flash/flash_l4t_nvme_rootfs_ab.xml \
-S 40GiB --showlogs \
jetson-xavier-nx-devkit-emmc external
I added this field to the default file above the UDA partition:
<partition name="my_new_partition" type="data">
<allocatio…
Hi wxsrite,
Are you using the devkit or custom board for Orin NX?
It is not an expected flash command since you are modifying the partition layout for NVMe SSD but you specified internal.
Please use initrd flash script to flash external NVMe SSD instead.
Hi KevinFFF:
I added the following:
flash_l4t_external.xml
<allocation_policy> sequential </allocation_policy>
<filesystem_type> basic </filesystem_type>
<size> 419430400 </size>
<file_system_attribute> 0 </file_system_attribute>
<allocation_attribute> 0x8 </allocation_attribute>
<percent_reserved> 0 </percent_reserved>
<description> **Optional.** Reserved for app. </description>
</partition>
flash_l4t_external.txt (10.2 KB)
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p “-c bootloader/t186ref/cfg/flash_t234_qspi.xml --no-systemimg” --network usb0 jetson-orin-nano-devkit external
[ 0.0419 ] ERROR: Partition 'my_new_partition', 'A_kernel' have the same GPT ID: 2
Error: Return value 11
Command tegraparser_v2 --pt flash.xml.tmp
Error: /home/w/wifi-up/L4T-public-source/out/Linux_for_Tegra/bootloader/signed/flash.idx is not found
Error: failed to relocate images to /home/w/wifi-up/L4T-public-source/out/Linux_for_Tegra/tools/kernel_flash/images
Cleaning up...
log.txt (129.2 KB)
Please help me see why?
Could you try to modify the following line to check if it could help?
- <partition name="my_new_partition" type="data">
+ <partition name="my_new_partition" id="3" type="data">
</partition>
Hi KevinFFF:
If you do the above, you will still get an error.
w@w:~/wifi-up/L4T-public-source/out/Linux_for_Tegra$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external-new.xml -p “-c bootloader/t186ref/cfg/flash_t234_qspi.xml --no-systemimg” --network usb0 jetson-orin-nano-devkit external
[ 0.0337 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0338 ] Assuming zero filled SBK key
[ 0.0337 ] Parsing partition layout
[ 0.0349 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.0355 ] ERROR: Partition 'my_new_partition', 'A_kernel-dtb' have the same GPT ID: 3
Cleaning up...
log.txt (137.2 KB)
flash_l4t_external-new.xml.txt (10.2 KB)
wxsrite:
--no-systemimg
Could you try to remove --no-systemimg in your command and verify?
Or use flash_l4t_t234_nvme.xml instead of flash_l4t_external.xml.
Hi, KevinFFF:
Using the above file, the following error is reported
error.txt (289.2 KB)
uart_log.txt (158.7 KB)
copying cfgfile(/home/w/wifi-up/L4T-public-source/out/Linux_for_Tegra/tools/kernel_flash/flash_l4t_external-new.xml) to flash.xml... done.
I’ve noticed that you are using Orin NX(T234) so that please use flash_l4t_t234_nvme.xml instead of flash_l4t_external.xml.
You can add your custom partition in flash_l4t_t234_nvme.xml .
wxsrite
October 24, 2024, 1:46am
11
Hi KevinFFF:
Thank you so much.
Use the following command to verify that it is indeed possible.
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_t234_nvme.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" --showlogs --network usb0 jetson-orin-nano-devkit external
The verification results are as follows:
flash_l4t_t234_nvme.xml.txt (8.8 KB)
flash-ok-uart.txt (553.5 KB)
flash-ok.txt (1.9 MB)
├─nvme0n1p1 259:1 0 952G 0 part /
├─nvme0n1p14 259:14 0 400M 0 part ---This is a new partition
├─nvme0n1p15 259:15 0 400M 0 part
└─nvme0n1p16 259:16 0 479.5M 0 part
root@tegra:/home/robot# sudo parted -l
Model: KINGSTON OM8SEP41024Q-A01 (nvme)
Disk /dev/nvme0n1: 1024GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
2 20.5kB 134MB 134MB A_kernel msftdata
3 134MB 135MB 786kB A_kernel-dtb msftdata
4 135MB 168MB 33.2MB A_reserved_on_user msftdata
5 168MB 302MB 134MB B_kernel msftdata
6 302MB 303MB 786kB B_kernel-dtb msftdata
7 303MB 336MB 33.2MB B_reserved_on_user msftdata
8 336MB 420MB 83.9MB recovery msftdata
9 420MB 421MB 524kB recovery-dtb msftdata
10 421MB 488MB 67.1MB fat32 esp boot, esp
11 488MB 572MB 83.9MB recovery_alt msftdata
12 572MB 572MB 524kB recovery-dtb_alt msftdata
13 572MB 639MB 67.1MB esp_alt msftdata
14 639MB 1059MB 419MB USR msftdata ---This is a new partition
15 1059MB 1478MB 419MB UDA msftdata
16 1478MB 1981MB 503MB reserved msftdata
1 1981MB 1024GB 1022GB ext4 APP msftdata
Another question is how to make the file system of the newly added partition ext4.
I would like to ask, why can’t I use the following file?
Can I add a custom partition by flashing the machine using the following command?
sudo ./flash.sh jetson-orin-nano-devkit-nvme internal
Okay, it seems you’ve added custom partition successfully.
You may need to customize it for your use case.
Please refer to the initrd and flash script to check how it format the partition.
Or you can simply run mkfs.ext4 command to format it as ext4.
You can compare the partition layout between them.
T234 uses flash_l4t_t234_nvme.xml instead.
flash_l4t_external.xml is used for other external devices like USB storage.
Please do not use jetson-orin-nano-devkit-nvme.conf as board config which is used for another module.
