My goal is to be able to create extra partitions by modifying the “flash_l4t_nvme_rootfs_ab.xml” file, and running the command:
sudo ROOTFS_AB=1 ./tools/kernel_flash/l4t_initrd_flash.sh \
--external-device nvme0n1 \
-c ./tools/kernel_flash/flash_l4t_nvme_rootfs_ab.xml \
-S 40GiB --showlogs \
jetson-xavier-nx-devkit-emmc external
I added this field to the default file above the UDA partition:
<partition name="my_new_partition" type="data">
<allocation_policy> sequential </allocation_policy>
<filesystem_type> basic </filesystem_type>
<size> 10000000000 </size>
<file_system_attribute> 0 </file_system_attribute>
<allocation_attribute> 0x8 </allocation_attribute>
<percent_reserved> 0 </percent_reserved>
<description> For use by a customer </description>
</partition>
This flashed successfully, and a lsusb
command confirms that the partition was successfully created on nvme0n1p11
nvme0n1 259:0 0 477G 0 disk
├─nvme0n1p1 259:1 0 40G 0 part /
├─nvme0n1p2 259:2 0 40G 0 part
├─nvme0n1p3 259:3 0 64M 0 part
├─nvme0n1p4 259:4 0 64M 0 part
├─nvme0n1p5 259:5 0 448K 0 part
├─nvme0n1p6 259:6 0 448K 0 part
├─nvme0n1p7 259:7 0 80M 0 part
├─nvme0n1p8 259:8 0 512K 0 part
├─nvme0n1p9 259:9 0 100M 0 part
├─nvme0n1p10 259:10 0 64M 0 part
├─nvme0n1p11 259:11 0 9.3G 0 part
└─nvme0n1p12 259:12 0 387.3G 0 part
I tried to mount it via this command sudo mount /dev/nvme0n1p11 /mnt/test/
, but received the following error:
NTFS signature is missing.
Failed to mount '/dev/nvme0n1p11': Invalid argument
The device '/dev/nvme0n1p11' doesn't seem to have a valid NTFS.
Maybe the wrong device is used? Or the whole disk instead of a
partition (e.g. /dev/sda, not /dev/sda1)? Or the other way around?
What changes do I need to make to “flash_l4t_nvme_rootfs_ab.xml” to make this a valid NTFS?
