Hi! I try to modified the UDA size partition with the flash_l4t_nvme_rootfs_enc.xml config file in the jetpack 5.1.2 R35.4.1. I finally find how to modified the rootfs with p3767.conf.common. Can you show me how to modified the size of this partition. I try to modified the lash_l4t_nvme_rootfs_enc.xml, but I was not able to change the size of this partition.
<?xml version="1.0"?>
<!-- Nvidia Tegra Partition Layout Version 1.0.0 -->
<partition_layout version="01.00.0000">
<device type="external" instance="0" sector_size="512" num_sectors="NUM_SECTORS">
<partition name="master_boot_record" type="protective_master_boot_record">
<allocation_policy> sequential </allocation_policy>
<filesystem_type> basic </filesystem_type>
<size> 512 </size>
<file_system_attribute> 0 </file_system_attribute>
<allocation_attribute> 8 </allocation_attribute>
<percent_reserved> 0 </percent_reserved>
<description> **Required.** Contains protective MBR. </description>
</partition>
<partition name="primary_gpt" type="primary_gpt">
<size> 19968 </size>
<description> **Required.** Contains primary GPT of the `nvme` device. All
partitions defined after this entry are configured in the kernel, and are accessible
by standard partition tools such as gdisk and parted. </description>
</partition>
<partition name="APP" type="data">
<size> 419430400 </size>
<allocation_attribute> 0x8 </allocation_attribute>
<align_boundary> 4096 </align_boundary>
<unique_guid> APPUUID </unique_guid>
<filename> system_boot.img </filename>
<description> **Required.** Contains the boot partition. This partition must be defined
after `primary_GPT` so that it can be accessed as the fixed known special device
`/dev/nvme0n1p1`. </description>
</partition>
<partition name="APP_ENC" type="data" encrypted="true">
<size> APP_ENC_SIZE </size>
<unique_guid> APP_ENC_UUID </unique_guid>
<filename> system_root_encrypted.img_ext </filename>
<description> **Required.** Contains the encrypted root partition("/"). </description>
</partition>
<partition name="kernel" type="kernel">
<size> 134217728 </size>
<filename> LNXFILE </filename>
<description> **Required.** Chain A; contains boot.img (kernel, initrd, etc)
which is loaded in when cpu-bootloader failes to launch the kernel
from the rootfs at `/boot`. </description>
</partition>
<partition name="kernel-dtb" type="kernel_dtb">
<size> 786432 </size>
<filename> DTB_FILE </filename>
<description> **Required.** Chain A; contains kernel device tree blob. </description>
</partition>
<partition name="reserved_for_chain_A_user" type="data">
<size> 33161216 </size>
<description> **Required.** Reserved space for chain A on user device. </description>
</partition>
<partition name="kernel_b" type="kernel">
<description> **Required.** Chain B; contains boot.img (kernel, initrd, etc)
</partition>
<partition name="kernel-dtb_b" type="kernel_dtb">
<description> **Required.** Chain B; contains kernel device tree blob. </description>
</partition>
<partition name="reserved_for_chain_B_user" type="data">
<description> **Required.** Reserved space for chain B on user device. </description>
</partition>
<partition name="RECNAME" type="kernel">
<size> RECSIZE </size>
<filename> RECFILE </filename>
<description> **Required.** Contains recovery image. </description>
</partition>
<partition name="RECDTB-NAME" type="kernel_dtb">
<size> 524288 </size>
<filename> RECDTB-FILE </filename>
<description> **Required.** Contains recovery DTB image. </description>
</partition>
<partition name="RECROOTFS" type="data">
<size> RECROOTFSSIZE </size>
<description> **Optional.** Reserved for future use by the recovery filesystem;
removable. </description>
</partition>
<partition name="esp" type="data">
<size> 67108864 </size>
<filename> ESP_FILE </filename>
<partition_type_guid> C12A7328-F81F-11D2-BA4B-00A0C93EC93B </partition_type_guid>
<description> **Required.** EFI system partition with L4T Launcher. </description>
</partition>
<partition name="RECNAME_alt" type="kernel">
<description> **Required.** For fail-safe recovery update. </description>
</partition>
<partition name="RECDTB-NAME_alt" type="kernel_dtb">
<description> **Required.** For fail-safe recovery DTB update. </description>
</partition>
<partition name="esp_alt" type="data">
<description> **Required.** EFI system partition for fail-safe ESP update. </description>
</partition>
<partition name="UDA" type="data" encrypted="true">
<size> 220200960 </size>
<allocation_attribute> 0x808 </allocation_attribute>
<filename> UDA_FILE </filename>
<description> **Required.** Automatically takes all remaining space on the device except space
occupied by `secondary_gpt`. Allocation attribute must be set to 0x808. This
partition may be mounted and used to store user data. </description>
</partition>
<partition name="secondary_gpt" type="secondary_gpt">
<size> 0xFFFFFFFFFFFFFFFF </size>
<description> **Required.** Contains secondary GPT of the `nvme`
</partition>
</device>
</partition_layout>
Can you tell me how to modified the size of this partition. Here you can see the size of my partition after my rootfs is modified to 20GiB.
Just want to specified that I try to modified the size of the partition in the config file.
Thanks in advanced!
