I’m trying to flash with encrypted rootfs, and it fails on searching for mmcblk0 instead of nvme in the ‘nfs’ sequence (after qspi initrd booted?).
Please ignore eks, keys, fuses - this is an issue with the initrd_flash script and blobs generated.
System:
- Jetson Orin NX 16G
- Forecr carrier
- JetPack r35.5.0
Details:
- the following simple flash command without encryption works correctly:
prepare:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh
–no-flash
–external-device nvme0n1p1
-c tools/kernel_flash/flash_l4t_external.xml
-p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml"
–showlogs
–network usb0 jetson-orin-nano-devkit external;
flash:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs --network usb0 --flash-only
blobs created in images dir:
[4.0K] images
├── [4.0K] external
│ ├── [ 42M] boot.img
│ ├── [ 64M] esp.img
│ ├── [ 57] flash.cfg
│ ├── [1.8K] flash.idx
│ ├── [ 16K] gpt_primary_9_0.bin
│ ├── [ 16K] gpt_secondary_9_0.bin
│ ├── [338K] kernel_tegra234-p3767-0000-p3509-a02.dtb
│ ├── [ 512] mbr_9_0.bin
│ ├── [ 45M] recovery.img
│ ├── [5.5G] system.img
│ ├── [ 41] system.img.sha1sum
│ └── [338K] tegra234-p3767-0000-p3509-a02.dtb.rec
├── [4.0K] internal
│ ├── [392K] adsp-fw_sigheader.bin.encrypt
│ ├── [ 32K] bct_backup.img
│ ├── [1003K] bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt
│ ├── [8.0K] br_bct_BR.bct
│ ├── [527K] camera-rtcpu-t234-rce_sigheader.img.encrypt
│ ├── [721K] display-t234-dce_with_tegra234-p3767-0000-p3509-a02_with_odm_overlay_aligned_blob_w_bin_sigheader.bin.encrypt
│ ├── [9.0K] eks_t234_sigheader.img.encrypt
│ ├── [ 38] flash.cfg
│ ├── [7.6K] flash.idx
│ ├── [ 16K] gpt_backup_secondary_3_0.bin
│ ├── [ 16K] gpt_secondary_3_0.bin
│ ├── [ 17K] mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
│ ├── [275K] mb1_t234_prod_aligned_sigheader.bin.encrypt
│ ├── [120K] mb2rf_t234_sigheader.bin.encrypt
│ ├── [427K] mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt
│ ├── [186K] mce_flash_o10_cr_prod_sigheader.bin.encrypt
│ ├── [238K] mem_coldboot_sigheader.bct.encrypt
│ ├── [288K] nvdec_t234_prod_sigheader.fw.encrypt
│ ├── [120K] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt
│ ├── [366K] pscfw_t234_prod_sigheader.bin.encrypt
│ ├── [120K] psc_rf_t234_prod_sigheader.bin.encrypt
│ ├── [ 98] qspi_bootblob_ver.txt
│ ├── [181K] sc7_t234_prod_sigheader.bin.encrypt
│ ├── [264K] spe_t234_sigheader.bin.encrypt
│ ├── [253K] tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt
│ ├── [1.2M] tos-optee_t234_sigheader.img.encrypt
│ ├── [2.8M] uefi_jetson_with_dtb_aligned_blob_w_bin_sigheader.bin.encrypt
│ └── [161K] xusb_t234_prod_sigheader.bin.encrypt
├── [ 38K] l4t_flash_from_kernel.sh
└── [ 53K] simg2img
- when I try to flash with disk encryption using the following:
prepare qspi
–no-flash
–showlogs
–network usb0 jetson-orin-nano-devkit internal
prepare external
sudo ROOTFS_ENC=1 ./tools/kernel_flash/l4t_initrd_flash.sh
–no-flash
-i MY_KEY
-c tools/kernel_flash/flash_l4t_t234_nvme_rootfs_enc.xml
–external-only
–append
–showlogs
–network usb0
flash:
[4.0K] images.bak
├── [4.0K] external
│ ├── [719K] display-t234-dce_with_kernel_tegra234-p3767-0000-p3509-a02_aligned_blob_w_bin_sigheader.bin.encrypt
│ ├── [9.4K] flash.idx
│ ├── [ 16K] gpt_primary_6_0.bin
│ ├── [ 16K] gpt_secondary_6_0.bin
│ ├── [ 512] mbr_6_0.bin
│ ├── [338K] tegra234-p3767-0000-p3509-a02.dtb.rec
├── [4.0K] internal
│ ├── [ 29] flash.cfg
└── [ 53K] simg2img
In the flash sequence, after the initrd boots and starts update from nfs, due to the script generating gpt_primary_6.0.bin instead of gpt_primary_9.0.bin your l4t_flash_from_kernel.sh try to flock /dev/mmcblk0p1 due to 6 being id for sdcard (instead of nvme0n1p1 being id 9) and fails.
(see function create_gpt in it).
What I’ve missed or did wrong ?
Waiting for your response.
Thanks,
Nadir.
