Trying to flash encrypted A/B partitions, my flash log seems to show its writing the A/B stuff correctly, but when i run nvbootctrl -t rootfs dump-slots-info after the flash is successful and the system boots i get RootFS A/B is not enabled.
When i run nvbootctrl -t bootloader dump-slots-info it shows Current Bootloader slot: A, and 2 slots present with status “normal”.
Here are the commands i am running in order to build and then flash:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --network usb0 --no-flash --showlogs -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" jetson-orin-nano-devkit internal
unplug / replug power and create rootfs
sudo ROOTFS_ENC=1 ROOTFS_AB=1 ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs --no-flash --external-device nvme0n1p1 -i ./sym2_t234.key -c ./tools/kernel_flash/flash_l4t_t234_nvme_rootfs_ab_enc.xml -S 160GiB --external-only --append --network usb0 jetson-orin-nano-devkit external
unplug / replug power and flash
sudo ROOTFS_AB=1 ROOTFS_RETRY_COUNT_MAX=1 ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs --network usb0 --flash-only
Flash Log:
$ sudo ROOTFS_AB=1 ROOTFS_RETRY_COUNT_MAX=1 ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs --network usb0 --flash-only
[sudo] password for rog:
/home/rog/nvidia/local_dev/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --network usb0 --usb-instance 1-10 --device-instance 0 --flash-only --external-device nvme0n1p1 -c "./tools/kernel_flash/flash_l4t_t234_nvme_rootfs_ab_enc.xml" -S 160GiB --network usb0 jetson-orin-nano-devkit external
* Step 1: Build the flashing environment *
Create flash environment 0
/home/rog/nvidia/local_dev/Linux_for_Tegra/bootloader /home/rog/nvidia/local_dev/Linux_for_Tegra
Finish creating flash environment 0.
* Step 2: Boot the device with flash initrd image *
/home/rog/nvidia/local_dev/Linux_for_Tegra/temp_initrdflash/bootloader0 /home/rog/nvidia/local_dev/Linux_for_Tegra
./tegraflash.py --bl uefi_jetson_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev --bldtb tegra234-p3767-0003-p3768-0000-a0.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd "rcmboot" --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt --bins "psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt; sce_fw camera-rtcpu-sce_sigheader.img.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt; kernel boot0.img; kernel_dtb tegra234-p3767-0003-p3768-0000-a0.dtb" --secondary_gpt_backup --bct_backup --instance 1-10
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
Entering RCM boot
[ 0.0232 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from --mb1_bin
[ 0.0232 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from --psc_bl1_bin
[ 0.0232 ] rcm boot with presigned binaries
[ 0.0239 ] tegrarcm_v2 --instance 1-10 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.0245 ] BR_CID: 0x80012344705DF2571C0000000CFF8100
[ 0.0316 ] Sending bct_br
[ 0.0376 ] Sending mb1
[ 0.0382 ] Sending psc_bl1
[ 0.0482 ] Sending bct_mb1
[ 0.0539 ] Generating blob for T23x
[ 0.0551 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[ 0.0557 ] The number of images in blob is 18
[ 0.0559 ] blobsize is 73378586
[ 0.0559 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 2924608
[ 0.0764 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 375168
[ 0.0767 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 190592
[ 0.0768 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 277312
[ 0.0769 ] Not supported type: mb2_applet
[ 0.0770 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 438768
[ 0.0771 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[ 0.0772 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 9097216
[ 0.0804 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[ 0.0811 ] Added binary blob_bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt of size 1051136
[ 0.0816 ] Added binary blob_tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt of size 110080
[ 0.0818 ] Added binary blob_camera-rtcpu-sce_sigheader.img.encrypt of size 166304
[ 0.0819 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 537952
[ 0.0820 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 400864
[ 0.0822 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[ 0.0823 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1127568
[ 0.0824 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[ 0.0825 ] Added binary blob_boot0.img of size 55592960
[ 0.1030 ] Added binary blob_tegra234-p3767-0003-p3768-0000-a0.dtb of size 347610
[ 0.1381 ] tegrarcm_v2 --instance 1-10 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[ 0.1387 ] BL: version 1.2.0.0-t234-54845784-562369e5 last_boot_error: 0
[ 0.2963 ] Sending bct_mem
[ 0.3062 ] Sending blob
[ 2.9204 ] RCM-boot started
* Step 3: Start the flashing process *
Waiting for target to boot-up...
Waiting for device to expose ssh ......RTNETLINK answers: File exists
Waiting for device to expose ssh ...Run command: flash on fc00:1:1:0::2
SSH ready
blockdev: cannot open /dev/mmcblk0boot0: No such file or directory
[ 0]: l4t_flash_from_kernel: Starting to create gpt for emmc
Active index file is /mnt/internal/flash.idx
Number of lines is 58
max_index=57
[ 2]: l4t_flash_from_kernel: Successfully create gpt for emmc
[ 2]: l4t_flash_from_kernel: Starting to create gpt for external device
Active index file is /mnt/external/flash.idx
Number of lines is 21
max_index=20
writing item=1, 9:0:primary_gpt, 512, 19968, gpt_primary_9_0.bin, 16896, fixed-<reserved>-0, e1ada80cc8f12ce76ef0ba8ffee06a394ae3dfd1
Writing primary_gpt partition with gpt_primary_9_0.bin
Offset is not aligned to K Bytes, no optimization is applied
dd if=/mnt/external/gpt_primary_9_0.bin of=/dev/nvme0n1 bs=1 skip=0 seek=512 count=16896
16896+0 records in
16896+0 records out
16896 bytes (17 kB, 16 KiB) copied, 0.0275647 s, 613 kB/s
Writing primary_gpt partition done
Error: The backup GPT table is corrupt, but the primary appears OK, so that will be used.
Warning: Not all of the space available to /dev/nvme0n1 appears to be used, you can fix the GPT to use all of the space (an extra 76773167 blocks) or continue with the current setting?
Writing secondary_gpt partition with gpt_secondary_9_0.bin
dd if=/mnt/external/gpt_secondary_9_0.bin of=/dev/nvme0n1 bs=1 skip=0 seek=460799983104 count=16896
16896+0 records in
16896+0 records out
16896 bytes (17 kB, 16 KiB) copied, 0.0291031 s, 581 kB/s
Writing secondary_gpt partition done
Fix/Ignore? Error: The backup GPT table is not at the end of the disk, as it should be. Fix, by moving the backup to the end (and removing the old backup)?
Fix
Fix/Ignore? Not all of the space available to /dev/nvme0n1 appears to be used, you can fix the GPT to use all of the space (an extra 76773167 blocks) or continue with the current setting?
Fix
Model: Samsung SSD 980 500GB (nvme)
Disk /dev/nvme0n1: 500GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
5 20.5kB 134MB 134MB A_kernel msftdata
6 134MB 135MB 786kB A_kernel-dtb msftdata
7 135MB 168MB 33.2MB A_reserved_on_user msftdata
8 168MB 302MB 134MB B_kernel msftdata
9 302MB 303MB 786kB B_kernel-dtb msftdata
10 303MB 336MB 33.2MB B_reserved_on_user msftdata
11 336MB 420MB 83.9MB recovery msftdata
12 420MB 421MB 524kB recovery-dtb msftdata
13 421MB 488MB 67.1MB fat32 esp boot, esp
14 488MB 572MB 83.9MB recovery_alt msftdata
15 572MB 572MB 524kB recovery-dtb_alt msftdata
16 572MB 639MB 67.1MB esp_alt msftdata
17 639MB 1059MB 419MB UDA msftdata
18 1059MB 1562MB 503MB reserved msftdata
1 1562MB 1981MB 419MB ext4 APP msftdata
2 1981MB 2400MB 419MB ext4 APP_b msftdata
3 2400MB 174GB 171GB APP_ENC msftdata
4 174GB 345GB 171GB APP_ENC_b msftdata
[ 16]: l4t_flash_from_kernel: Successfully create gpt for external device
[ 16]: l4t_flash_from_kernel: Starting to flash to emmc
[ 16]: l4t_flash_from_kernel: Starting to flash to external device
Flash index file is /mnt/internal/flash.idx
max_index=57
max_index=57
max_index=20
[ 16]: l4t_flash_from_kernel: Starting to flash to qspi
writing item=0, 9:0:master_boot_record, 0, 512, mbr_9_0.bin, 512, fixed-<reserved>-0, 694898d1c345bdb31b377790ed7fc0b0db184bf7
QSPI storage size: 67108864 bytes.
writing item=2, 9:0:A_kernel, 20480, 134217728, boot.img, 47202304, fixed-<reserved>-5, a668cc8e22b6358e83a9dfdd0459ffc2398d7333
Writing A_kernel partition with boot.img
Get size of partition through connection.
47202304 bytes from /mnt/external/boot.img to /dev/nvme0n1: 1KB block=46096 remainder=0
dd if=/mnt/external/boot.img of=/dev/nvme0n1 bs=1K skip=0 seek=20 count=46096
46096+0 records in
46096+0 records out
47202304 bytes (47 MB, 45 MiB) copied, 0.633936 s, 74.5 MB/s
Writing A_kernel partition done
writing item=3, 9:0:A_kernel-dtb, 134238208, 786432, kernel_tegra234-p3767-0003-p3768-0000-a0.dtb, 347610, fixed-<reserved>-6, bfe91f2a7f3d9d5c4da5d805241c831631d9ee89
Writing A_kernel-dtb partition with kernel_tegra234-p3767-0003-p3768-0000-a0.dtb
347610 bytes from /mnt/external/kernel_tegra234-p3767-0003-p3768-0000-a0.dtb to /dev/nvme0n1: 1KB block=339 remainder=474
dd if=/mnt/external/kernel_tegra234-p3767-0003-p3768-0000-a0.dtb of=/dev/nvme0n1 bs=1K skip=0 seek=131092 count=339
339+0 records in
339+0 records out
347136 bytes (347 kB, 339 KiB) copied, 0.00625446 s, 55.5 MB/s
dd if=/mnt/external/kernel_tegra234-p3767-0003-p3768-0000-a0.dtb of=/dev/nvme0n1 bs=1 skip=347136 seek=134585344 count=474
474+0 records in
474+0 records out
474 bytes copied, 0.0012729 s, 372 kB/s
Writing A_kernel-dtb partition done
writing item=4, 9:0:A_reserved_on_user, 135024640, 33161216, , , fixed-<reserved>-7,
[ 17]: l4t_flash_from_kernel: Warning: skip writing A_reserved_on_user partition as no image is specified
writing item=5, 9:0:B_kernel, 168185856, 134217728, boot.img, 47202304, fixed-<reserved>-8, a668cc8e22b6358e83a9dfdd0459ffc2398d7333
Writing B_kernel partition with boot.img
dd if=/mnt/external/boot.img of=/dev/nvme0n1 bs=1K skip=0 seek=164244 count=46096
[ 17]: l4t_flash_from_kernel: Successfully flash the emmc
46096+0 records in
46096+0 records out
47202304 bytes (47 MB, 45 MiB) copied, 0.462622 s, 102 MB/s
Writing B_kernel partition done
writing item=6, 9:0:B_kernel-dtb, 302403584, 786432, kernel_tegra234-p3767-0003-p3768-0000-a0.dtb, 347610, fixed-<reserved>-9, bfe91f2a7f3d9d5c4da5d805241c831631d9ee89
Writing B_kernel-dtb partition with kernel_tegra234-p3767-0003-p3768-0000-a0.dtb
dd if=/mnt/external/kernel_tegra234-p3767-0003-p3768-0000-a0.dtb of=/dev/nvme0n1 bs=1K skip=0 seek=295316 count=339
339+0 records in
339+0 records out
347136 bytes (347 kB, 339 KiB) copied, 0.00422272 s, 82.2 MB/s
dd if=/mnt/external/kernel_tegra234-p3767-0003-p3768-0000-a0.dtb of=/dev/nvme0n1 bs=1 skip=347136 seek=302750720 count=474
474+0 records in
474+0 records out
474 bytes copied, 0.00104378 s, 454 kB/s
Writing B_kernel-dtb partition done
writing item=7, 9:0:B_reserved_on_user, 303190016, 33161216, , , fixed-<reserved>-10,
[ 18]: l4t_flash_from_kernel: Warning: skip writing B_reserved_on_user partition as no image is specified
writing item=8, 9:0:recovery, 336351232, 83886080, recovery.img, 50790400, fixed-<reserved>-11, 42f84f698344abaa522cb43d7cf6c4e93521fb7f
Writing recovery partition with recovery.img
50790400 bytes from /mnt/external/recovery.img to /dev/nvme0n1: 1KB block=49600 remainder=0
dd if=/mnt/external/recovery.img of=/dev/nvme0n1 bs=1K skip=0 seek=328468 count=49600
49600+0 records in
49600+0 records out
50790400 bytes (51 MB, 48 MiB) copied, 0.558315 s, 91.0 MB/s
Writing recovery partition done
writing item=9, 9:0:recovery-dtb, 420237312, 524288, tegra234-p3767-0003-p3768-0000-a0.dtb.rec, 347610, fixed-<reserved>-12, bfe91f2a7f3d9d5c4da5d805241c831631d9ee89
Writing recovery-dtb partition with tegra234-p3767-0003-p3768-0000-a0.dtb.rec
347610 bytes from /mnt/external/tegra234-p3767-0003-p3768-0000-a0.dtb.rec to /dev/nvme0n1: 1KB block=339 remainder=474
dd if=/mnt/external/tegra234-p3767-0003-p3768-0000-a0.dtb.rec of=/dev/nvme0n1 bs=1K skip=0 seek=410388 count=339
339+0 records in
339+0 records out
347136 bytes (347 kB, 339 KiB) copied, 0.00629677 s, 55.1 MB/s
dd if=/mnt/external/tegra234-p3767-0003-p3768-0000-a0.dtb.rec of=/dev/nvme0n1 bs=1 skip=347136 seek=420584448 count=474
474+0 records in
474+0 records out
474 bytes copied, 0.00121488 s, 390 kB/s
Writing recovery-dtb partition done
writing item=10, 9:0:esp, 420761600, 67108864, esp.img, 67108864, fixed-<reserved>-13, 277939b507d6f2d025084e072e73e68ff6731d50
Writing esp partition with esp.img
67108864 bytes from /mnt/external/esp.img to /dev/nvme0n1: 1KB block=65536 remainder=0
dd if=/mnt/external/esp.img of=/dev/nvme0n1 bs=1K skip=0 seek=410900 count=65536
65536+0 records in
65536+0 records out
67108864 bytes (67 MB, 64 MiB) copied, 0.729223 s, 92.0 MB/s
Writing esp partition done
writing item=11, 9:0:recovery_alt, 487870464, 83886080, , , fixed-<reserved>-14,
[ 19]: l4t_flash_from_kernel: Warning: skip writing recovery_alt partition as no image is specified
writing item=12, 9:0:recovery-dtb_alt, 571756544, 524288, , , fixed-<reserved>-15,
[ 19]: l4t_flash_from_kernel: Warning: skip writing recovery-dtb_alt partition as no image is specified
writing item=13, 9:0:esp_alt, 572280832, 67108864, , , fixed-<reserved>-16,
[ 19]: l4t_flash_from_kernel: Warning: skip writing esp_alt partition as no image is specified
writing item=14, 9:0:UDA, 639401984, 419430400, user_data_encrypted.img_ext, 46432464, fixed-<reserved>-17, 8d682b322c59759c304388a2de9d25b8f9d02ee9
Writing UDA partition with user_data_encrypted.img_ext
blkdiscard /dev/nvme0n1p17
/mnt/simg2img /mnt/external/user_data_encrypted.img_ext /dev/nvme0n1p17
Writing UDA partition done
writing item=15, 9:0:reserved, 1058832384, 502792192, , , fixed-<reserved>-18,
[ 20]: l4t_flash_from_kernel: Warning: skip writing reserved partition as no image is specified
writing item=16, 9:0:APP, 1561624576, 419430400, , , fixed-<reserved>-1,
Formatting APP partition /dev/nvme0n1p1 ...
mke2fs 1.45.5 (07-Jan-2020)
Discarding device blocks: done
Creating filesystem with 102400 4k blocks and 102400 inodes
Filesystem UUID: 8acbc01d-3215-4bb3-9fd1-1f25d0c68140
Superblock backups stored on blocks:
32768, 98304
Allocating group tables: done
Writing inode tables: done
Creating journal (4096 blocks): done
Writing superblocks and filesystem accounting information: done
Formatting APP parition done
tar --xattrs -xpf /mnt/external/system_boot.img --checkpoint=10000 --warning=no-timestamp --numeric-owner -C /tmp/ci-Lb7EKB0EjK
writing item=17, 9:0:APP_b, 1981054976, 419430400, , , fixed-<reserved>-2,
Formatting APP partition /dev/nvme0n1p2 ...
Filesystem UUID: 331239d5-9144-43d6-b0fd-259c01fd9d50
32768, 98304
tar --xattrs -xpf /mnt/external/system_boot.img_b --checkpoint=10000 --warning=no-timestamp --numeric-owner -C /tmp/ci-WuHU8eVdNj
writing item=18, 9:0:APP_ENC, 2400485376, 171379261440, system_root_encrypted.img_ext, 8005698072, fixed-<reserved>-3,
Writing APP_ENC partition with system_root_encrypted.img_ext
blkdiscard /dev/nvme0n1p3
/mnt/simg2img /mnt/external/system_root_encrypted.img_ext /dev/nvme0n1p3
Writing APP_ENC partition done
writing item=19, 9:0:APP_ENC_b, 173779746816, 171379261440, system_root_encrypted.img_ext_b, 7916458112, fixed-<reserved>-4,
Writing APP_ENC_b partition with system_root_encrypted.img_ext_b
blkdiscard /dev/nvme0n1p4
/mnt/simg2img /mnt/external/system_root_encrypted.img_ext_b /dev/nvme0n1p4
Erased 67108864 bytes from address 0x00000000 in flash
max_index=57
Writing br_bct_BR.bct (parittion: BCT) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/br_bct_BR.bct
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:0
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00000000 in flash
[ 157]: l4t_flash_from_kernel: QSPI erase block size is 65536
[ 157]: l4t_flash_from_kernel: Writing 16 copies of /mnt/internal/br_bct_BR.bct
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:65536
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00010000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:131072
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00020000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:196608
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00030000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:262144
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00040000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:327680
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00050000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:393216
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00060000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:458752
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00070000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:524288
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00080000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:589824
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00090000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:655360
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x000a0000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:720896
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x000b0000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:786432
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x000c0000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:851968
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x000d0000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:917504
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x000e0000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:983040
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x000f0000 in flash
Writing mb1_t234_prod_aligned_sigheader.bin.encrypt (parittion: A_mb1) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/mb1_t234_prod_aligned_sigheader.bin.encrypt
Writing /mnt/internal/mb1_t234_prod_aligned_sigheader.bin.encrypt (280976 bytes) into /dev/mtd0:1048576
Copied 280976 bytes from /mnt/internal/mb1_t234_prod_aligned_sigheader.bin.encrypt to address 0x00100000 in flash
Writing psc_bl1_t234_prod_aligned_sigheader.bin.encrypt (parittion: A_psc_bl1) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/psc_bl1_t234_prod_aligned_sigheader.bin.encrypt
Writing /mnt/internal/psc_bl1_t234_prod_aligned_sigheader.bin.encrypt (122864 bytes) into /dev/mtd0:1572864
Copied 122864 bytes from /mnt/internal/psc_bl1_t234_prod_aligned_sigheader.bin.encrypt to address 0x00180000 in flash
Writing mb1_cold_boot_bct_MB1_sigheader.bct.encrypt (parittion: A_MB1_BCT) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
Writing /mnt/internal/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt (17328 bytes) into /dev/mtd0:1835008
Copied 17328 bytes from /mnt/internal/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt to address 0x001c0000 in flash
Writing mem_coldboot_sigheader.bct.encrypt (parittion: A_MEM_BCT) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/mem_coldboot_sigheader.bct.encrypt
Writing /mnt/internal/mem_coldboot_sigheader.bct.encrypt (243712 bytes) into /dev/mtd0:1966080
Copied 243712 bytes from /mnt/internal/mem_coldboot_sigheader.bct.encrypt to address 0x001e0000 in flash
[ 169]: l4t_flash_from_kernel: Warning: skip writing A_tsec-fw partition as no image is specified
Writing nvdec_t234_prod_sigheader.fw.encrypt (parittion: A_nvdec) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/nvdec_t234_prod_sigheader.fw.encrypt
Writing /mnt/internal/nvdec_t234_prod_sigheader.fw.encrypt (294912 bytes) into /dev/mtd0:3276800
Copied 294912 bytes from /mnt/internal/nvdec_t234_prod_sigheader.fw.encrypt to address 0x00320000 in flash
Writing mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt (parittion: A_mb2) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt
Writing /mnt/internal/mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt (438768 bytes) into /dev/mtd0:4325376
Copied 438768 bytes from /mnt/internal/mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt to address 0x00420000 in flash
Writing xusb_t234_prod_sigheader.bin.encrypt (parittion: A_xusb-fw) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/xusb_t234_prod_sigheader.bin.encrypt
Writing /mnt/internal/xusb_t234_prod_sigheader.bin.encrypt (164864 bytes) into /dev/mtd0:4849664
Copied 164864 bytes from /mnt/internal/xusb_t234_prod_sigheader.bin.encrypt to address 0x004a0000 in flash
Writing bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt (parittion: A_bpmp-fw) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt
Writing /mnt/internal/bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt (1051136 bytes) into /dev/mtd0:5111808
Copied 1051136 bytes from /mnt/internal/bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt to address 0x004e0000 in flash
Writing tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt (parittion: A_bpmp-fw-dtb) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt
Writing /mnt/internal/tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt (110080 bytes) into /dev/mtd0:6684672
Copied 110080 bytes from /mnt/internal/tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt to address 0x00660000 in flash
Writing pscfw_t234_prod_sigheader.bin.encrypt (parittion: A_psc-fw) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/pscfw_t234_prod_sigheader.bin.encrypt
Writing /mnt/internal/pscfw_t234_prod_sigheader.bin.encrypt (375168 bytes) into /dev/mtd0:10878976
Writing APP_ENC_b partition done
writing item=20, 9:0:secondary_gpt, 460799983104, 16896, gpt_secondary_9_0.bin, 16896, fixed-<reserved>-0, 1e1e6f2099b7986288f133675cb118b3b9456a71
[ 195]: l4t_flash_from_kernel: Successfully flash the external device
Copied 375168 bytes from /mnt/internal/pscfw_t234_prod_sigheader.bin.encrypt to address 0x00a60000 in flash
Writing mce_flash_o10_cr_prod_sigheader.bin.encrypt (parittion: A_mts-mce) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/mce_flash_o10_cr_prod_sigheader.bin.encrypt
Writing /mnt/internal/mce_flash_o10_cr_prod_sigheader.bin.encrypt (190592 bytes) into /dev/mtd0:11665408
Copied 190592 bytes from /mnt/internal/mce_flash_o10_cr_prod_sigheader.bin.encrypt to address 0x00b20000 in flash
Writing sc7_t234_prod_sigheader.bin.encrypt (parittion: A_sc7) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/sc7_t234_prod_sigheader.bin.encrypt
Writing /mnt/internal/sc7_t234_prod_sigheader.bin.encrypt (184544 bytes) into /dev/mtd0:12189696
Copied 184544 bytes from /mnt/internal/sc7_t234_prod_sigheader.bin.encrypt to address 0x00ba0000 in flash
Writing psc_rf_t234_prod_sigheader.bin.encrypt (parittion: A_pscrf) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/psc_rf_t234_prod_sigheader.bin.encrypt
Writing /mnt/internal/psc_rf_t234_prod_sigheader.bin.encrypt (122320 bytes) into /dev/mtd0:12386304
Copied 122320 bytes from /mnt/internal/psc_rf_t234_prod_sigheader.bin.encrypt to address 0x00bd0000 in flash
Writing mb2rf_t234_sigheader.bin.encrypt (parittion: A_mb2rf) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/mb2rf_t234_sigheader.bin.encrypt
Writing /mnt/internal/mb2rf_t234_sigheader.bin.encrypt (122752 bytes) into /dev/mtd0:12582912
Copied 122752 bytes from /mnt/internal/mb2rf_t234_sigheader.bin.encrypt to address 0x00c00000 in flash
Writing uefi_jetson_with_dtb_sigheader.bin.encrypt (parittion: A_cpu-bootloader) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/uefi_jetson_with_dtb_sigheader.bin.encrypt
Writing /mnt/internal/uefi_jetson_with_dtb_sigheader.bin.encrypt (2924608 bytes) into /dev/mtd0:12713984
Copied 2924608 bytes from /mnt/internal/uefi_jetson_with_dtb_sigheader.bin.encrypt to address 0x00c20000 in flash
Writing tos-optee_t234_sigheader.img.encrypt (parittion: A_secure-os) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/tos-optee_t234_sigheader.img.encrypt
Writing /mnt/internal/tos-optee_t234_sigheader.img.encrypt (1127568 bytes) into /dev/mtd0:16384000
Copied 1127568 bytes from /mnt/internal/tos-optee_t234_sigheader.img.encrypt to address 0x00fa0000 in flash
[ 204]: l4t_flash_from_kernel: Warning: skip writing A_smm-fw partition as no image is specified
Writing eks_t234_sigheader.img.encrypt (parittion: A_eks) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/eks_t234_sigheader.img.encrypt
Writing /mnt/internal/eks_t234_sigheader.img.encrypt (9232 bytes) into /dev/mtd0:22675456
Copied 9232 bytes from /mnt/internal/eks_t234_sigheader.img.encrypt to address 0x015a0000 in flash
Writing display-t234-dce_with_tegra234-p3767-0003-p3768-0000-a0_with_odm_overlay_aligned_blob_w_bin_sigheader.bin.encrypt (parittion: A_dce-fw) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/display-t234-dce_with_tegra234-p3767-0003-p3768-0000-a0_with_odm_overlay_aligned_blob_w_bin_sigheader.bin.encrypt
Writing /mnt/internal/display-t234-dce_with_tegra234-p3767-0003-p3768-0000-a0_with_odm_overlay_aligned_blob_w_bin_sigheader.bin.encrypt (738256 bytes) into /dev/mtd0:22937600
Copied 738256 bytes from /mnt/internal/display-t234-dce_with_tegra234-p3767-0003-p3768-0000-a0_with_odm_overlay_aligned_blob_w_bin_sigheader.bin.encrypt to address 0x015e0000 in flash
Writing spe_t234_sigheader.bin.encrypt (parittion: A_spe-fw) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/spe_t234_sigheader.bin.encrypt
Writing /mnt/internal/spe_t234_sigheader.bin.encrypt (270336 bytes) into /dev/mtd0:28180480
Copied 270336 bytes from /mnt/internal/spe_t234_sigheader.bin.encrypt to address 0x01ae0000 in flash
Writing camera-rtcpu-t234-rce_sigheader.img.encrypt (parittion: A_rce-fw) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/camera-rtcpu-t234-rce_sigheader.img.encrypt
Writing /mnt/internal/camera-rtcpu-t234-rce_sigheader.img.encrypt (537952 bytes) into /dev/mtd0:28770304
Copied 537952 bytes from /mnt/internal/camera-rtcpu-t234-rce_sigheader.img.encrypt to address 0x01b70000 in flash
Writing adsp-fw_sigheader.bin.encrypt (parittion: A_adsp-fw) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/adsp-fw_sigheader.bin.encrypt
Writing /mnt/internal/adsp-fw_sigheader.bin.encrypt (400864 bytes) into /dev/mtd0:29818880
Copied 400864 bytes from /mnt/internal/adsp-fw_sigheader.bin.encrypt to address 0x01c70000 in flash
[ 208]: l4t_flash_from_kernel: Warning: skip writing A_reserved_on_boot partition as no image is specified
Writing mb1_t234_prod_aligned_sigheader.bin.encrypt (parittion: B_mb1) into /dev/mtd0
Writing /mnt/internal/mb1_t234_prod_aligned_sigheader.bin.encrypt (280976 bytes) into /dev/mtd0:33292288
Copied 280976 bytes from /mnt/internal/mb1_t234_prod_aligned_sigheader.bin.encrypt to address 0x01fc0000 in flash
Writing psc_bl1_t234_prod_aligned_sigheader.bin.encrypt (parittion: B_psc_bl1) into /dev/mtd0
Writing /mnt/internal/psc_bl1_t234_prod_aligned_sigheader.bin.encrypt (122864 bytes) into /dev/mtd0:33816576
Copied 122864 bytes from /mnt/internal/psc_bl1_t234_prod_aligned_sigheader.bin.encrypt to address 0x02040000 in flash
Writing mb1_cold_boot_bct_MB1_sigheader.bct.encrypt (parittion: B_MB1_BCT) into /dev/mtd0
Writing /mnt/internal/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt (17328 bytes) into /dev/mtd0:34078720
Copied 17328 bytes from /mnt/internal/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt to address 0x02080000 in flash
Writing mem_coldboot_sigheader.bct.encrypt (parittion: B_MEM_BCT) into /dev/mtd0
Writing /mnt/internal/mem_coldboot_sigheader.bct.encrypt (243712 bytes) into /dev/mtd0:34209792
Copied 243712 bytes from /mnt/internal/mem_coldboot_sigheader.bct.encrypt to address 0x020a0000 in flash
[ 209]: l4t_flash_from_kernel: Warning: skip writing B_tsec-fw partition as no image is specified
Writing nvdec_t234_prod_sigheader.fw.encrypt (parittion: B_nvdec) into /dev/mtd0
Writing /mnt/internal/nvdec_t234_prod_sigheader.fw.encrypt (294912 bytes) into /dev/mtd0:35520512
Copied 294912 bytes from /mnt/internal/nvdec_t234_prod_sigheader.fw.encrypt to address 0x021e0000 in flash
Writing mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt (parittion: B_mb2) into /dev/mtd0
Writing /mnt/internal/mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt (438768 bytes) into /dev/mtd0:36569088
Copied 438768 bytes from /mnt/internal/mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt to address 0x022e0000 in flash
Writing xusb_t234_prod_sigheader.bin.encrypt (parittion: B_xusb-fw) into /dev/mtd0
Writing /mnt/internal/xusb_t234_prod_sigheader.bin.encrypt (164864 bytes) into /dev/mtd0:37093376
Copied 164864 bytes from /mnt/internal/xusb_t234_prod_sigheader.bin.encrypt to address 0x02360000 in flash
Writing bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt (parittion: B_bpmp-fw) into /dev/mtd0
Writing /mnt/internal/bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt (1051136 bytes) into /dev/mtd0:37355520
Copied 1051136 bytes from /mnt/internal/bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt to address 0x023a0000 in flash
Writing tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt (parittion: B_bpmp-fw-dtb) into /dev/mtd0
Writing /mnt/internal/tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt (110080 bytes) into /dev/mtd0:38928384
Copied 110080 bytes from /mnt/internal/tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt to address 0x02520000 in flash
Writing pscfw_t234_prod_sigheader.bin.encrypt (parittion: B_psc-fw) into /dev/mtd0
Writing /mnt/internal/pscfw_t234_prod_sigheader.bin.encrypt (375168 bytes) into /dev/mtd0:43122688
Copied 375168 bytes from /mnt/internal/pscfw_t234_prod_sigheader.bin.encrypt to address 0x02920000 in flash
Writing mce_flash_o10_cr_prod_sigheader.bin.encrypt (parittion: B_mts-mce) into /dev/mtd0
Writing /mnt/internal/mce_flash_o10_cr_prod_sigheader.bin.encrypt (190592 bytes) into /dev/mtd0:43909120
Copied 190592 bytes from /mnt/internal/mce_flash_o10_cr_prod_sigheader.bin.encrypt to address 0x029e0000 in flash
Writing sc7_t234_prod_sigheader.bin.encrypt (parittion: B_sc7) into /dev/mtd0
Writing /mnt/internal/sc7_t234_prod_sigheader.bin.encrypt (184544 bytes) into /dev/mtd0:44433408
Copied 184544 bytes from /mnt/internal/sc7_t234_prod_sigheader.bin.encrypt to address 0x02a60000 in flash
Writing psc_rf_t234_prod_sigheader.bin.encrypt (parittion: B_pscrf) into /dev/mtd0
Writing /mnt/internal/psc_rf_t234_prod_sigheader.bin.encrypt (122320 bytes) into /dev/mtd0:44630016
Copied 122320 bytes from /mnt/internal/psc_rf_t234_prod_sigheader.bin.encrypt to address 0x02a90000 in flash
Writing mb2rf_t234_sigheader.bin.encrypt (parittion: B_mb2rf) into /dev/mtd0
Writing /mnt/internal/mb2rf_t234_sigheader.bin.encrypt (122752 bytes) into /dev/mtd0:44826624
Copied 122752 bytes from /mnt/internal/mb2rf_t234_sigheader.bin.encrypt to address 0x02ac0000 in flash
Writing uefi_jetson_with_dtb_sigheader.bin.encrypt (parittion: B_cpu-bootloader) into /dev/mtd0
Writing /mnt/internal/uefi_jetson_with_dtb_sigheader.bin.encrypt (2924608 bytes) into /dev/mtd0:44957696
Copied 2924608 bytes from /mnt/internal/uefi_jetson_with_dtb_sigheader.bin.encrypt to address 0x02ae0000 in flash
Writing tos-optee_t234_sigheader.img.encrypt (parittion: B_secure-os) into /dev/mtd0
Writing /mnt/internal/tos-optee_t234_sigheader.img.encrypt (1127568 bytes) into /dev/mtd0:48627712
Copied 1127568 bytes from /mnt/internal/tos-optee_t234_sigheader.img.encrypt to address 0x02e60000 in flash
[ 222]: l4t_flash_from_kernel: Warning: skip writing B_smm-fw partition as no image is specified
Writing eks_t234_sigheader.img.encrypt (parittion: B_eks) into /dev/mtd0
Writing /mnt/internal/eks_t234_sigheader.img.encrypt (9232 bytes) into /dev/mtd0:54919168
Copied 9232 bytes from /mnt/internal/eks_t234_sigheader.img.encrypt to address 0x03460000 in flash
Writing display-t234-dce_with_tegra234-p3767-0003-p3768-0000-a0_with_odm_overlay_aligned_blob_w_bin_sigheader.bin.encrypt (parittion: B_dce-fw) into /dev/mtd0
Writing /mnt/internal/display-t234-dce_with_tegra234-p3767-0003-p3768-0000-a0_with_odm_overlay_aligned_blob_w_bin_sigheader.bin.encrypt (738256 bytes) into /dev/mtd0:55181312
Copied 738256 bytes from /mnt/internal/display-t234-dce_with_tegra234-p3767-0003-p3768-0000-a0_with_odm_overlay_aligned_blob_w_bin_sigheader.bin.encrypt to address 0x034a0000 in flash
Writing spe_t234_sigheader.bin.encrypt (parittion: B_spe-fw) into /dev/mtd0
Writing /mnt/internal/spe_t234_sigheader.bin.encrypt (270336 bytes) into /dev/mtd0:60424192
Copied 270336 bytes from /mnt/internal/spe_t234_sigheader.bin.encrypt to address 0x039a0000 in flash
Writing camera-rtcpu-t234-rce_sigheader.img.encrypt (parittion: B_rce-fw) into /dev/mtd0
Writing /mnt/internal/camera-rtcpu-t234-rce_sigheader.img.encrypt (537952 bytes) into /dev/mtd0:61014016
Copied 537952 bytes from /mnt/internal/camera-rtcpu-t234-rce_sigheader.img.encrypt to address 0x03a30000 in flash
Writing adsp-fw_sigheader.bin.encrypt (parittion: B_adsp-fw) into /dev/mtd0
Writing /mnt/internal/adsp-fw_sigheader.bin.encrypt (400864 bytes) into /dev/mtd0:62062592
Copied 400864 bytes from /mnt/internal/adsp-fw_sigheader.bin.encrypt to address 0x03b30000 in flash
[ 226]: l4t_flash_from_kernel: Warning: skip writing B_reserved_on_boot partition as no image is specified
[ 226]: l4t_flash_from_kernel: Warning: skip writing uefi_variables partition as no image is specified
[ 226]: l4t_flash_from_kernel: Warning: skip writing uefi_ftw partition as no image is specified
[ 226]: l4t_flash_from_kernel: Warning: skip writing worm partition as no image is specified
Writing bct_backup.img (parittion: BCT-boot-chain_backup) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/bct_backup.img
Writing /mnt/internal/bct_backup.img (32768 bytes) into /dev/mtd0:66715648
Copied 32768 bytes from /mnt/internal/bct_backup.img to address 0x03fa0000 in flash
[ 226]: l4t_flash_from_kernel: Warning: skip writing reserved_partition partition as no image is specified
Writing gpt_secondary_3_0.bin (parittion: secondary_gpt_backup) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/gpt_secondary_3_0.bin
Writing /mnt/internal/gpt_secondary_3_0.bin (16896 bytes) into /dev/mtd0:66846720
Copied 16896 bytes from /mnt/internal/gpt_secondary_3_0.bin to address 0x03fc0000 in flash
Writing qspi_bootblob_ver.txt (parittion: B_VER) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/qspi_bootblob_ver.txt
Writing /mnt/internal/qspi_bootblob_ver.txt (101 bytes) into /dev/mtd0:66912256
Copied 101 bytes from /mnt/internal/qspi_bootblob_ver.txt to address 0x03fd0000 in flash
Writing qspi_bootblob_ver.txt (parittion: A_VER) into /dev/mtd0
Writing /mnt/internal/qspi_bootblob_ver.txt (101 bytes) into /dev/mtd0:66977792
Copied 101 bytes from /mnt/internal/qspi_bootblob_ver.txt to address 0x03fe0000 in flash
Writing gpt_secondary_3_0.bin (parittion: secondary_gpt) into /dev/mtd0
Writing /mnt/internal/gpt_secondary_3_0.bin (16896 bytes) into /dev/mtd0:67091968
Copied 16896 bytes from /mnt/internal/gpt_secondary_3_0.bin to address 0x03ffbe00 in flash
[ 226]: l4t_flash_from_kernel: Successfully flash the qspi
[ 226]: l4t_flash_from_kernel: Flashing success
[ 226]: l4t_flash_from_kernel: The device size indicated in the partition layout xml is smaller than the actual size. This utility will try to fix the GPT.
Flash is successful
Reboot device
Cleaning up...
Log is saved to Linux_for_Tegra/initrdlog/flash_1-10_0_20240927-102953.log
