I’ve been able to flash orin nano with encryption correctly. Afterwards, if I make a modification and try to re-flash, or simply flash again without any modification , I just re-use same folder, this error appears( and I am flashing the same orin nano I successfully flashed previously)
[ 99]: l4t_flash_from_kernel: Successfully flash the external device
Erased 67108864 bytes from address 0x00000000 in flash
[ 187]: l4t_flash_from_kernel: Error: /mnt/internal/flash.idx is not found
[ 187]: l4t_flash_from_kernel: /mnt/internal/flash.idx is not found. Skipping spi flashing
[ 187]: l4t_flash_from_kernel: Error flashing qspi
Here is the log:
[ 6.8924 ] tegraparser_v2 --pt flash.xml.bin --generateflashindex /home/vmasip/nvidia/Linux_for_Tegra/bootloader/signed/flash.xml.tmp flash.idx
Using bpmp-dtb concatenated with odmdata in blob for t23x
./tegraflash.py --bl uefi_jetson_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev --bldtb tegra234-p3767-0003-p3768-0000-a0.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd "rcmboot" --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt --bins "psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt; sce_fw camera-rtcpu-sce_sigheader.img.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt; kernel boot.img; kernel_dtb tegra234-p3767-0003-p3768-0000-a0.dtb" --bct_backup
saving flash command in flashcmd.txt
*** no-flash flag enabled. Exiting now... ***
User can run above saved command in factory environment without
providing pkc and sbk keys to flash a device
Example:
$ cd bootloader
$ sudo bash ./flashcmd.txt
Save initrd flashing command parameters to /home/vmasip/nvidia/Linux_for_Tegra/tools/kernel_flash/initrdflashparam.txt
/tmp/tmp.85YstF4EYB /home/vmasip/nvidia/Linux_for_Tegra
writing boot image config in bootimg.cfg
extracting kernel in zImage
extracting ramdisk in initrd.img
/tmp/tmp.85YstF4EYB/initrd /tmp/tmp.85YstF4EYB /home/vmasip/nvidia/Linux_for_Tegra
58213 bloques
grep: /home/vmasip/nvidia/Linux_for_Tegra/tools/kernel_flash/images/internal/flash.idx: No existe el archivo o el directorio
65197 bloques
flashimg0=boot0.img
Success
Cleaning up...
Finish generating flash package.
Put device in recovery mode, run with option --flash-only to flash device.
(base) vmasip@eudald-Latitude-7480:~/nvidia/Linux_for_Tegra$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --network usb0 --showlogs --flash-only
/home/vmasip/nvidia/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --network usb0 --usb-instance 1-3 --device-instance 0 --flash-only --external-device nvme0n1p1 -c "./tools/kernel_flash/flash_l4t_t234_nvme_rootfs_enc.xml" --network usb0 jetson-orin-nano-devkit external
* Step 1: Build the flashing environment *
Create flash environment 0
/home/vmasip/nvidia/Linux_for_Tegra/bootloader /home/vmasip/nvidia/Linux_for_Tegra
Finish creating flash environment 0.
* Step 2: Boot the device with flash initrd image *
/home/vmasip/nvidia/Linux_for_Tegra/temp_initrdflash/bootloader0 /home/vmasip/nvidia/Linux_for_Tegra
./tegraflash.py --bl uefi_jetson_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev --bldtb tegra234-p3767-0003-p3768-0000-a0.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd "rcmboot" --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt --bins "psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt; sce_fw camera-rtcpu-sce_sigheader.img.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt; kernel boot0.img; kernel_dtb tegra234-p3767-0003-p3768-0000-a0.dtb" --bct_backup --instance 1-3
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
Entering RCM boot
[ 0.0411 ] rcm boot with presigned binaries
[ 0.0421 ] tegrarcm_v2 --instance 1-3 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.0430 ] BR_CID: 0x80012344705DF1885000000004FE0180
[ 0.0512 ] Sending bct_br
[ 0.0579 ] Sending mb1
[ 0.0584 ] Sending psc_bl1
[ 0.0690 ] Sending bct_mb1
[ 0.0749 ] Generating blob for T23x
[ 0.0770 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[ 0.0780 ] The number of images in blob is 18
[ 0.0785 ] blobsize is 66328694
[ 0.0786 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 3186752
[ 0.1107 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 375168
[ 0.1115 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 190592
[ 0.1121 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 277312
[ 0.1125 ] Not supported type: mb2_applet
[ 0.1127 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 437008
[ 0.1131 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[ 0.1134 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 9097216
[ 0.1195 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[ 0.1224 ] Added binary blob_bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt of size 1027008
[ 0.1232 ] Added binary blob_tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt of size 199936
[ 0.1237 ] Added binary blob_camera-rtcpu-sce_sigheader.img.encrypt of size 166304
[ 0.1240 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 540000
[ 0.1248 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 400960
[ 0.1254 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[ 0.1259 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1288096
[ 0.1264 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[ 0.1269 ] Added binary blob_boot0.img of size 48054272
[ 0.1594 ] Added binary blob_tegra234-p3767-0003-p3768-0000-a0.dtb of size 347622
[ 0.2140 ] tegrarcm_v2 --instance 1-3 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[ 0.2150 ] BL: version 1.4.0.1-t234-54845784-08e631ca last_boot_error: 0
[ 0.3201 ] Sending bct_mem
[ 0.3534 ] Sending blob
[ 3.7443 ] RCM-boot started
* Step 3: Start the flashing process *
Waiting for target to boot-up...
Waiting for device to expose ssh ......RTNETLINK answers: File exists
Waiting for device to expose ssh ...Run command: flash on fc00:1:1:0::2
SSH ready
blockdev: cannot open /dev/mmcblk0boot0: No such file or directory
[ 0]: l4t_flash_from_kernel: Serial Number: 1425123205974
[ 0]: l4t_flash_from_kernel: Starting to create gpt for external device
Active index file is /mnt/external/flash.idx
Number of lines is 19
max_index=18
writing item=1, 9:0:primary_gpt, 512, 19968, gpt_primary_9_0.bin, 16896, fixed-<reserved>-0, e89e446511a0fcb7384b1272d7239adea8b1de47
Writing primary_gpt partition with gpt_primary_9_0.bin
Offset is not aligned to K Bytes, no optimization is applied
dd if=/mnt/external/gpt_primary_9_0.bin of=/dev/nvme0n1 bs=1 skip=0 seek=512 count=16896
16896+0 records in
16896+0 records out
16896 bytes (17 kB, 16 KiB) copied, 0.0289823 s, 583 kB/s
Writing primary_gpt partition done
Writing secondary_gpt partition with gpt_secondary_9_0.bin
dd if=/mnt/external/gpt_secondary_9_0.bin of=/dev/nvme0n1 bs=1 skip=0 seek=512110173696 count=16896
16896+0 records in
16896+0 records out
16896 bytes (17 kB, 16 KiB) copied, 0.027614 s, 612 kB/s
Writing secondary_gpt partition done
[ 14]: l4t_flash_from_kernel: Successfully create gpt for external device
[ 14]: l4t_flash_from_kernel: Starting to flash to external device
max_index=18
[ 14]: l4t_flash_from_kernel: Starting to flash to qspi
QSPI storage size: 67108864 bytes.
writing item=0, 9:0:master_boot_record, 0, 512, mbr_9_0.bin, 512, fixed-<reserved>-0, 694898d1c345bdb31b377790ed7fc0b0db184bf7
writing item=2, 9:0:A_kernel, 20480, 134217728, boot.img, 47200256, fixed-<reserved>-3, f4a91beb187775c840db8474430ae7b3f4619641
Writing A_kernel partition with boot.img
Get size of partition through connection.
47200256 bytes from /mnt/external/boot.img to /dev/nvme0n1: 1KB block=46094 remainder=0
dd if=/mnt/external/boot.img of=/dev/nvme0n1 bs=1K skip=0 seek=20 count=46094
46094+0 records in
46094+0 records out
47200256 bytes (47 MB, 45 MiB) copied, 0.669597 s, 70.5 MB/s
Writing A_kernel partition done
writing item=3, 9:0:A_kernel-dtb, 134238208, 786432, kernel_tegra234-p3767-0003-p3768-0000-a0.dtb, 347622, fixed-<reserved>-4, eeb8c123f309f381622d1099b705c9947fd712c3
Writing A_kernel-dtb partition with kernel_tegra234-p3767-0003-p3768-0000-a0.dtb
347622 bytes from /mnt/external/kernel_tegra234-p3767-0003-p3768-0000-a0.dtb to /dev/nvme0n1: 1KB block=339 remainder=486
dd if=/mnt/external/kernel_tegra234-p3767-0003-p3768-0000-a0.dtb of=/dev/nvme0n1 bs=1K skip=0 seek=131092 count=339
339+0 records in
339+0 records out
347136 bytes (347 kB, 339 KiB) copied, 0.00671731 s, 51.7 MB/s
dd if=/mnt/external/kernel_tegra234-p3767-0003-p3768-0000-a0.dtb of=/dev/nvme0n1 bs=1 skip=347136 seek=134585344 count=486
486+0 records in
486+0 records out
486 bytes copied, 0.00132429 s, 367 kB/s
Writing A_kernel-dtb partition done
writing item=4, 9:0:A_reserved_on_user, 135024640, 33161216, , , fixed-<reserved>-5,
[ 15]: l4t_flash_from_kernel: Warning: skip writing A_reserved_on_user partition as no image is specified
writing item=5, 9:0:B_kernel, 168185856, 134217728, boot.img, 47200256, fixed-<reserved>-6, f4a91beb187775c840db8474430ae7b3f4619641
Writing B_kernel partition with boot.img
dd if=/mnt/external/boot.img of=/dev/nvme0n1 bs=1K skip=0 seek=164244 count=46094
46094+0 records in
46094+0 records out
47200256 bytes (47 MB, 45 MiB) copied, 0.402297 s, 117 MB/s
Writing B_kernel partition done
writing item=6, 9:0:B_kernel-dtb, 302403584, 786432, kernel_tegra234-p3767-0003-p3768-0000-a0.dtb, 347622, fixed-<reserved>-7, eeb8c123f309f381622d1099b705c9947fd712c3
Writing B_kernel-dtb partition with kernel_tegra234-p3767-0003-p3768-0000-a0.dtb
dd if=/mnt/external/kernel_tegra234-p3767-0003-p3768-0000-a0.dtb of=/dev/nvme0n1 bs=1K skip=0 seek=295316 count=339
339+0 records in
339+0 records out
347136 bytes (347 kB, 339 KiB) copied, 0.00359648 s, 96.5 MB/s
dd if=/mnt/external/kernel_tegra234-p3767-0003-p3768-0000-a0.dtb of=/dev/nvme0n1 bs=1 skip=347136 seek=302750720 count=486
486+0 records in
486+0 records out
486 bytes copied, 0.0010167 s, 478 kB/s
Writing B_kernel-dtb partition done
writing item=7, 9:0:B_reserved_on_user, 303190016, 33161216, , , fixed-<reserved>-8,
[ 15]: l4t_flash_from_kernel: Warning: skip writing B_reserved_on_user partition as no image is specified
writing item=8, 9:0:recovery, 336351232, 83886080, recovery.img, 50782208, fixed-<reserved>-9, 7338cacaee0c088dc1fcd50c0448b452d1d751c2
Writing recovery partition with recovery.img
50782208 bytes from /mnt/external/recovery.img to /dev/nvme0n1: 1KB block=49592 remainder=0
dd if=/mnt/external/recovery.img of=/dev/nvme0n1 bs=1K skip=0 seek=328468 count=49592
49592+0 records in
49592+0 records out
50782208 bytes (51 MB, 48 MiB) copied, 0.700957 s, 72.4 MB/s
Writing recovery partition done
writing item=9, 9:0:recovery-dtb, 420237312, 524288, tegra234-p3767-0003-p3768-0000-a0.dtb.rec, 347622, fixed-<reserved>-10, eeb8c123f309f381622d1099b705c9947fd712c3
Writing recovery-dtb partition with tegra234-p3767-0003-p3768-0000-a0.dtb.rec
347622 bytes from /mnt/external/tegra234-p3767-0003-p3768-0000-a0.dtb.rec to /dev/nvme0n1: 1KB block=339 remainder=486
dd if=/mnt/external/tegra234-p3767-0003-p3768-0000-a0.dtb.rec of=/dev/nvme0n1 bs=1K skip=0 seek=410388 count=339
339+0 records in
339+0 records out
347136 bytes (347 kB, 339 KiB) copied, 0.0078097 s, 44.4 MB/s
dd if=/mnt/external/tegra234-p3767-0003-p3768-0000-a0.dtb.rec of=/dev/nvme0n1 bs=1 skip=347136 seek=420584448 count=486
486+0 records in
486+0 records out
486 bytes copied, 0.00144522 s, 336 kB/s
Writing recovery-dtb partition done
writing item=10, 9:0:esp, 420761600, 67108864, esp.img, 67108864, fixed-<reserved>-11, ba5fea5ca747be8459f45b4621b5d60ba4b6de1b
Writing esp partition with esp.img
67108864 bytes from /mnt/external/esp.img to /dev/nvme0n1: 1KB block=65536 remainder=0
dd if=/mnt/external/esp.img of=/dev/nvme0n1 bs=1K skip=0 seek=410900 count=65536
65536+0 records in
65536+0 records out
67108864 bytes (67 MB, 64 MiB) copied, 1.00052 s, 67.1 MB/s
Writing esp partition done
writing item=11, 9:0:recovery_alt, 487870464, 83886080, , , fixed-<reserved>-12,
[ 17]: l4t_flash_from_kernel: Warning: skip writing recovery_alt partition as no image is specified
writing item=12, 9:0:recovery-dtb_alt, 571756544, 524288, , , fixed-<reserved>-13,
[ 17]: l4t_flash_from_kernel: Warning: skip writing recovery-dtb_alt partition as no image is specified
writing item=13, 9:0:esp_alt, 572280832, 67108864, , , fixed-<reserved>-14,
[ 17]: l4t_flash_from_kernel: Warning: skip writing esp_alt partition as no image is specified
writing item=14, 9:0:UDA, 639401984, 419430400, , , fixed-<reserved>-15,
blkdiscard /dev/nvme0n1p15
/mnt/simg2img /mnt/external/user_data_encrypted.img_ext /dev/nvme0n1p15
writing item=15, 9:0:reserved, 1058832384, 502792192, , , fixed-<reserved>-16,
[ 18]: l4t_flash_from_kernel: Warning: skip writing reserved partition as no image is specified
writing item=16, 9:0:APP, 1561624576, 419430400, , , fixed-<reserved>-1,
Formatting APP partition /dev/nvme0n1p1 ...
mke2fs 1.45.5 (07-Jan-2020)
Discarding device blocks: done
Creating filesystem with 102400 4k blocks and 102400 inodes
Filesystem UUID: 29d36718-cbdb-41ed-bdc1-72dc2eeefc4f
Superblock backups stored on blocks:
32768, 98304
Allocating group tables: done
Writing inode tables: done
Creating journal (4096 blocks): done
Writing superblocks and filesystem accounting information: done
Formatting APP parition done
tar -xpf /mnt/external/system_boot.img --checkpoint=10000 --warning=no-timestamp --numeric-owner --xattrs --xattrs-include=* -C /tmp/ci-pwAADhB1sX
writing item=17, 9:0:APP_ENC, 1981054976, 58636369920, , , fixed-<reserved>-2,
blkdiscard /dev/nvme0n1p2
/mnt/simg2img /mnt/external/system_root_encrypted.img_ext /dev/nvme0n1p2
writing item=18, 9:0:secondary_gpt, 512110173696, 16896, gpt_secondary_9_0.bin, 16896, fixed-<reserved>-0, 21032cfc0dc4488554a95a1f5d494b77afa6fd49
Flash failure
Cleaning up...
This is my flashing script:
cd $L4T_FOLDER
sudo ./tools/kernel_flash/l4t_initrd_flash_internal.sh --no-flash --network usb0 --showlogs -p -c bootloader/t186ref/cfg/flash_t234_qspi.xml jetson-orin-nano-devkit internal
sudo ./flash.sh --no-flash -k A_eks jetson-orin-nano-devkit internal
sudo cp bootloader/eks_t234_sigheader.img.encrypt ./tools/kernel_flash/images/internal/.
sudo ROOTFS_ENC=1 ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs --no-flash --external-device nvme0n1p1 -i ./sym2_t234.key -c ./tools/kernel_flash/flash_l4t_t234_nvme_rootfs_enc.xml --external-only --append --network usb0 jetson-orin-nano-devkit external
