I have this log saved from the build:
# Entry added by NVIDIA initrd flash tool
/home/bh/Downloads/mfi_recomputer-orin-j401/tools/kernel_flash/tmp 127.0.0.1(rw,nohide,insecure,no_subtree_check,async,no_root_squash)
Export list for localhost:
/home/bh/Downloads/mfi_recomputer-orin-j401/recomputer-orin-j401.conf: line 29: /home/bh/Downloads/mfi_recomputer-orin-j401/p3768-0000-p3767-0000-a0.conf: No such file or directory
* Step 1: Build the flashing environment *
Create flash environment 0
/home/bh/Downloads/mfi_recomputer-orin-j401/bootloader /home/bh/Downloads/mfi_recomputer-orin-j401
Finish creating flash environment 0.
* Step 2: Boot the device with flash initrd image *
/home/bh/Downloads/mfi_recomputer-orin-j401/temp_initrdflash/bootloader0 /home/bh/Downloads/mfi_recomputer-orin-j401
./tegraflash.py --bl uefi_jetson_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev --bldtb tegra234-j401-p3768-0000+p3767-0001-recomputer.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd "rcmboot" --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt --bins "psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; tsec_fw tsec_t234_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; pva_fw nvpva_020_sigheader.fw.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3767-0001-3509-a02_with_odm_sigheader.dtb.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt; kernel boot0.img; kernel_dtb tegra234-j401-p3768-0000+p3767-0001-recomputer.dtb" --bct_backup --instance 3-2
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
Entering RCM boot
[ 0.0383 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from --mb1_bin
[ 0.0383 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from --psc_bl1_bin
[ 0.0383 ] rcm boot with presigned binbhes
[ 0.0387 ] tegrarcm_v2 --instance 3-2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.0389 ] BR_CID: 0x80012344705DF1418000000009FF82C0
[ 0.0494 ] Sending bct_br
[ 0.0573 ] Sending mb1
[ 0.0579 ] Sending psc_bl1
[ 0.0681 ] Sending bct_mb1
[ 0.0738 ] Generating blob for T23x
[ 0.0755 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[ 0.0758 ] The number of images in blob is 19
[ 0.0762 ] blobsize is 107713699
[ 0.0763 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 3592256
[ 0.1253 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 310768
[ 0.1260 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 187120
[ 0.1261 ] Added binary blob_tsec_t234_sigheader.bin.encrypt of size 176128
[ 0.1263 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 279616
[ 0.1264 ] Not supported type: mb2_applet
[ 0.1265 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 439968
[ 0.1266 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[ 0.1268 ] Added binary blob_nvpva_020_sigheader.fw.encrypt of size 2164640
[ 0.1283 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 12065552
[ 0.1373 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[ 0.1391 ] Added binary blob_bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt of size 1027008
[ 0.1399 ] Added binary blob_tegra234-bpmp-3767-0001-3509-a02_with_odm_sigheader.dtb.encrypt of size 263424
[ 0.1401 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 458096
[ 0.1404 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 414976
[ 0.1406 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[ 0.1408 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1633344
[ 0.1420 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[ 0.1422 ] Added binary blob_boot0.img of size 83716096
[ 0.2017 ] Added binary blob_tegra234-j401-p3768-0000+p3767-0001-recomputer.dtb of size 244259
[ 0.2894 ] tegrarcm_v2 --instance 3-2 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[ 0.2897 ] BL: version 1.4.0.2-t234-54845784-08a4de08 last_boot_error: 0
[ 0.3365 ] Sending bct_mem
[ 0.3491 ] Sending blob
[ 3.9414 ] RCM-boot started
* Step 3: Start the flashing process *
Waiting for target to boot-up...
Waiting for device to expose ssh ......Waiting for device to expose ssh ...Run command: flash on fc00:1:1:0::2
SSH ready
blockdev: cannot open /dev/mmcblk0boot0: No such file or directory
[ 0]: l4t_flash_from_kernel: Serial Number: 1615023600357
[ 0]: l4t_flash_from_kernel: Starting to create gpt for emmc
Active index file is /mnt/internal/flash.idx
Number of lines is 61
max_index=60
[ 2]: l4t_flash_from_kernel: Successfully create gpt for emmc
[ 2]: l4t_flash_from_kernel: Starting to create gpt for external device
Active index file is /mnt/external/flash.idx
Number of lines is 18
max_index=17
writing item=1, 9:0:primary_gpt, 512, 19968, gpt_primary_9_0.bin, 16896, fixed-<reserved>-0, b93db6821626d298f21ca3685d78770b089d71b9
Writing primary_gpt partition with gpt_primary_9_0.bin
Offset is not aligned to K Bytes, no optimization is applied
dd if=/mnt/external/gpt_primary_9_0.bin of=/dev/nvme0n1 bs=1 skip=0 seek=512 count=16896
16896+0 records in
16896+0 records out
16896 bytes (17 kB, 16 KiB) copied, 0.0225611 s, 749 kB/s
Writing primary_gpt partition done
Error: The backup GPT table is corrupt, but the primary appears OK, so that will be used.
Warning: Not all of the space available to /dev/nvme0n1 appears to be used, you can fix the GPT to use all of the space (an extra 300118192 blocks) or continue with the current setting?
Writing secondary_gpt partition with gpt_secondary_9_0.bin
dd if=/mnt/external/gpt_secondary_9_0.bin of=/dev/nvme0n1 bs=1 skip=0 seek=102399983104 count=16896
16896+0 records in
16896+0 records out
16896 bytes (17 kB, 16 KiB) copied, 0.0229685 s, 736 kB/s
Writing secondary_gpt partition done
Fix/Ignore? Warning: Not all of the space available to /dev/nvme0n1 appears to be used, you can fix the GPT to use all of the space (an extra 300118192 blocks) or continue with the current setting?
Fix
Model: Vi3000 Internal PCIe NVMe M.2 SSD 256GB (nvme)
Disk /dev/nvme0n1: 256GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
2 20.5kB 134MB 134MB A_kernel msftdata
3 134MB 135MB 786kB A_kernel-dtb msftdata
4 135MB 168MB 33.2MB A_reserved_on_user msftdata
5 168MB 302MB 134MB B_kernel msftdata
6 302MB 303MB 786kB B_kernel-dtb msftdata
7 303MB 336MB 33.2MB B_reserved_on_user msftdata
8 336MB 420MB 83.9MB recovery msftdata
9 420MB 421MB 524kB recovery-dtb msftdata
10 421MB 488MB 67.1MB fat32 esp boot, esp
11 488MB 572MB 83.9MB recovery_alt msftdata
12 572MB 572MB 524kB recovery-dtb_alt msftdata
13 572MB 639MB 67.1MB esp_alt msftdata
14 639MB 1059MB 419MB UDA msftdata
15 1059MB 1562MB 503MB reserved msftdata
1 1562MB 102GB 101GB ext4 APP msftdata
[ 28]: l4t_flash_from_kernel: Expanding last partition to fill the storage device
[ 28]: l4t_flash_from_kernel: Successfully create gpt for external device
[ 28]: l4t_flash_from_kernel: Starting to flash to emmc
max_index=60
Flash index file is /mnt/internal/flash.idx
max_index=60
[ 28]: l4t_flash_from_kernel: Starting to flash to external device
max_index=17
[ 28]: l4t_flash_from_kernel: Starting to flash to qspi
writing item=0, 9:0:master_boot_record, 0, 512, mbr_9_0.bin, 512, fixed-<reserved>-0, 694898d1c345bdb31b377790ed7fc0b0db184bf7
QSPI storage size: 67108864 bytes.
writing item=2, 9:0:A_kernel, 20480, 134217728, boot.img, 53639168, fixed-<reserved>-2, efd37263efc1af56110ed2c1648c808ffc571ef9
Writing A_kernel partition with boot.img
Get size of partition through connection.
53639168 bytes from /mnt/external/boot.img to /dev/nvme0n1: 1KB block=52382 remainder=0
dd if=/mnt/external/boot.img of=/dev/nvme0n1 bs=1K skip=0 seek=20 count=52382
[ 30]: l4t_flash_from_kernel: Successfully flash the emmc
52382+0 records in
52382+0 records out
53639168 bytes (54 MB, 51 MiB) copied, 1.76113 s, 30.5 MB/s
Writing A_kernel partition done
writing item=3, 9:0:A_kernel-dtb, 134238208, 786432, kernel_tegra234-j401-p3768-0000+p3767-0001-recomputer.dtb, 244259, fixed-<reserved>-3, 8413c2ce49d113711a03f995bcf7ca6db85458ff
Writing A_kernel-dtb partition with kernel_tegra234-j401-p3768-0000+p3767-0001-recomputer.dtb
244259 bytes from /mnt/external/kernel_tegra234-j401-p3768-0000+p3767-0001-recomputer.dtb to /dev/nvme0n1: 1KB block=238 remainder=547
dd if=/mnt/external/kernel_tegra234-j401-p3768-0000+p3767-0001-recomputer.dtb of=/dev/nvme0n1 bs=1K skip=0 seek=131092 count=238
238+0 records in
238+0 records out
243712 bytes (244 kB, 238 KiB) copied, 0.0103278 s, 23.6 MB/s
dd if=/mnt/external/kernel_tegra234-j401-p3768-0000+p3767-0001-recomputer.dtb of=/dev/nvme0n1 bs=1 skip=243712 seek=134481920 count=547
547+0 records in
547+0 records out
547 bytes copied, 0.00122038 s, 448 kB/s
Writing A_kernel-dtb partition done
writing item=4, 9:0:A_reserved_on_user, 135024640, 33161216, , , fixed-<reserved>-4,
[ 30]: l4t_flash_from_kernel: Warning: skip writing A_reserved_on_user partition as no image is specified
writing item=5, 9:0:B_kernel, 168185856, 134217728, boot.img, 53639168, fixed-<reserved>-5, efd37263efc1af56110ed2c1648c808ffc571ef9
Writing B_kernel partition with boot.img
dd if=/mnt/external/boot.img of=/dev/nvme0n1 bs=1K skip=0 seek=164244 count=52382
52382+0 records in
52382+0 records out
53639168 bytes (54 MB, 51 MiB) copied, 1.24812 s, 43.0 MB/s
Writing B_kernel partition done
writing item=6, 9:0:B_kernel-dtb, 302403584, 786432, kernel_tegra234-j401-p3768-0000+p3767-0001-recomputer.dtb, 244259, fixed-<reserved>-6, 8413c2ce49d113711a03f995bcf7ca6db85458ff
Writing B_kernel-dtb partition with kernel_tegra234-j401-p3768-0000+p3767-0001-recomputer.dtb
dd if=/mnt/external/kernel_tegra234-j401-p3768-0000+p3767-0001-recomputer.dtb of=/dev/nvme0n1 bs=1K skip=0 seek=295316 count=238
238+0 records in
238+0 records out
243712 bytes (244 kB, 238 KiB) copied, 0.00625782 s, 38.9 MB/s
dd if=/mnt/external/kernel_tegra234-j401-p3768-0000+p3767-0001-recomputer.dtb of=/dev/nvme0n1 bs=1 skip=243712 seek=302647296 count=547
547+0 records in
547+0 records out
547 bytes copied, 0.00163347 s, 335 kB/s
Writing B_kernel-dtb partition done
writing item=7, 9:0:B_reserved_on_user, 303190016, 33161216, , , fixed-<reserved>-7,
[ 32]: l4t_flash_from_kernel: Warning: skip writing B_reserved_on_user partition as no image is specified
writing item=8, 9:0:recovery, 336351232, 83886080, recovery.img, 59107328, fixed-<reserved>-8, ebeb81bb6acabc9c6c8d09c2282ef717e0fa6340
Writing recovery partition with recovery.img
59107328 bytes from /mnt/external/recovery.img to /dev/nvme0n1: 1KB block=57722 remainder=0
dd if=/mnt/external/recovery.img of=/dev/nvme0n1 bs=1K skip=0 seek=328468 count=57722
57722+0 records in
57722+0 records out
59107328 bytes (59 MB, 56 MiB) copied, 1.97568 s, 29.9 MB/s
Writing recovery partition done
writing item=9, 9:0:recovery-dtb, 420237312, 524288, tegra234-j401-p3768-0000+p3767-0001-recomputer.dtb.rec, 244259, fixed-<reserved>-9, 8413c2ce49d113711a03f995bcf7ca6db85458ff
Writing recovery-dtb partition with tegra234-j401-p3768-0000+p3767-0001-recomputer.dtb.rec
244259 bytes from /mnt/external/tegra234-j401-p3768-0000+p3767-0001-recomputer.dtb.rec to /dev/nvme0n1: 1KB block=238 remainder=547
dd if=/mnt/external/tegra234-j401-p3768-0000+p3767-0001-recomputer.dtb.rec of=/dev/nvme0n1 bs=1K skip=0 seek=410388 count=238
238+0 records in
238+0 records out
243712 bytes (244 kB, 238 KiB) copied, 0.0107183 s, 22.7 MB/s
dd if=/mnt/external/tegra234-j401-p3768-0000+p3767-0001-recomputer.dtb.rec of=/dev/nvme0n1 bs=1 skip=243712 seek=420481024 count=547
547+0 records in
547+0 records out
547 bytes copied, 0.0012017 s, 455 kB/s
Writing recovery-dtb partition done
writing item=10, 9:0:esp, 420761600, 67108864, esp.img, 67108864, fixed-<reserved>-10, b4af544592b0b9102ec0efe85a0b01535bd8e161
Writing esp partition with esp.img
67108864 bytes from /mnt/external/esp.img to /dev/nvme0n1: 1KB block=65536 remainder=0
dd if=/mnt/external/esp.img of=/dev/nvme0n1 bs=1K skip=0 seek=410900 count=65536
65536+0 records in
65536+0 records out
67108864 bytes (67 MB, 64 MiB) copied, 2.26168 s, 29.7 MB/s
Writing esp partition done
writing item=11, 9:0:recovery_alt, 487870464, 83886080, , , fixed-<reserved>-11,
[ 36]: l4t_flash_from_kernel: Warning: skip writing recovery_alt partition as no image is specified
writing item=12, 9:0:recovery-dtb_alt, 571756544, 524288, , , fixed-<reserved>-12,
[ 36]: l4t_flash_from_kernel: Warning: skip writing recovery-dtb_alt partition as no image is specified
writing item=13, 9:0:esp_alt, 572280832, 67108864, , , fixed-<reserved>-13,
[ 36]: l4t_flash_from_kernel: Warning: skip writing esp_alt partition as no image is specified
writing item=14, 9:0:UDA, 639401984, 419430400, , , fixed-<reserved>-14,
[ 36]: l4t_flash_from_kernel: Skip writing UDA partition
writing item=15, 9:0:reserved, 1058832384, 502792192, , , fixed-<reserved>-15,
[ 36]: l4t_flash_from_kernel: Warning: skip writing reserved partition as no image is specified
writing item=16, 9:0:APP, 1561624576, 100838354944, , , expand-<reserved>-1,
Formatting APP partition /dev/nvme0n1p1 ...
mke2fs 1.46.5 (30-Dec-2021)
Discarding device blocks: 0/62133513 8388608/6213351317825792/6213351329360128/6213351339321600/6213351347710208/6213351352953088/62133513 done
Creating filesystem with 62133513 4k blocks and 15540224 inodes
Filesystem UUID: 93857e76-4196-40fa-89d3-0b912d3ae82e
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
4096000, 7962624, 11239424, 20480000, 23887872
Allocating group tables: 0/1897 done
Writing inode tables: 0/1897 done
Creating journal (262144 blocks): done
Writing superblocks and filesystem accounting information: 0/1897 done
Formatting APP pbhtion done
tar -x -I 'zstd -T0' -pf /mnt/external/system.img --checkpoint=10000 --warning=no-timestamp --numeric-owner --xattrs --xattrs-include=* -C /tmp/ci-JzKV4wvcoj
tar: Read checkpoint 10000
tar: Read checkpoint 20000
tar: Read checkpoint 30000
tar: Read checkpoint 40000
tar: Read checkpoint 50000
tar: Read checkpoint 60000
tar: Read checkpoint 70000
tar: Read checkpoint 80000
tar: Read checkpoint 90000
tar: Read checkpoint 100000
tar: Read checkpoint 110000
tar: Read checkpoint 120000
tar: Read checkpoint 130000
tar: Read checkpoint 140000
tar: Read checkpoint 150000
tar: Read checkpoint 160000
tar: Read checkpoint 170000
tar: Read checkpoint 180000
tar: Read checkpoint 190000
tar: Read checkpoint 200000
tar: Read checkpoint 210000
tar: Read checkpoint 220000
tar: Read checkpoint 230000
tar: Read checkpoint 240000
tar: Read checkpoint 250000
tar: Read checkpoint 260000
tar: Read checkpoint 270000
tar: Read checkpoint 280000
tar: Read checkpoint 290000
tar: Read checkpoint 300000
tar: Read checkpoint 310000
tar: Read checkpoint 320000
tar: Read checkpoint 330000
tar: Read checkpoint 340000
tar: Read checkpoint 350000
tar: Read checkpoint 360000
tar: Read checkpoint 370000
tar: Read checkpoint 380000
tar: Read checkpoint 390000
tar: Read checkpoint 400000
tar: Read checkpoint 410000
tar: Read checkpoint 420000
tar: Read checkpoint 430000
tar: Read checkpoint 440000
tar: Read checkpoint 450000
tar: Read checkpoint 460000
tar: Read checkpoint 470000
tar: Read checkpoint 480000
tar: Read checkpoint 490000
tar: Read checkpoint 500000
tar: Read checkpoint 510000
tar: Read checkpoint 520000
tar: Read checkpoint 530000
tar: Read checkpoint 540000
tar: Read checkpoint 550000
tar: Read checkpoint 560000
tar: Read checkpoint 570000
tar: Read checkpoint 580000
tar: Read checkpoint 590000
tar: Read checkpoint 600000
tar: Read checkpoint 610000
tar: Read checkpoint 620000
tar: Read checkpoint 630000
tar: Read checkpoint 640000
tar: Read checkpoint 650000
tar: Read checkpoint 660000
tar: Read checkpoint 670000
tar: Read checkpoint 680000
tar: Read checkpoint 690000
tar: Read checkpoint 700000
tar: Read checkpoint 710000
tar: Read checkpoint 720000
tar: Read checkpoint 730000
tar: Read checkpoint 740000
tar: Read checkpoint 750000
tar: Read checkpoint 760000
tar: Read checkpoint 770000
tar: Read checkpoint 780000
tar: Read checkpoint 790000
tar: Read checkpoint 800000
tar: Read checkpoint 810000
tar: Read checkpoint 820000
tar: Read checkpoint 830000
tar: Read checkpoint 840000
tar: Read checkpoint 850000
tar: Read checkpoint 860000
tar: Read checkpoint 870000
tar: Read checkpoint 880000
tar: Read checkpoint 890000
tar: Read checkpoint 900000
tar: Read checkpoint 910000
tar: Read checkpoint 920000
tar: Read checkpoint 930000
tar: Read checkpoint 940000
tar: Read checkpoint 950000
tar: Read checkpoint 960000
tar: Read checkpoint 970000
tar: Read checkpoint 980000
tar: Read checkpoint 990000
tar: Read checkpoint 1000000
tar: Read checkpoint 1010000
Erased 67108864 bytes from address 0x00000000 in flash
max_index=60
Writing br_bct_BR.bct (pbhttion: BCT) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/br_bct_BR.bct
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:0
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00000000 in flash
[ 202]: l4t_flash_from_kernel: QSPI erase block size is 16384
[ 202]: l4t_flash_from_kernel: Writing 64 copies of /mnt/internal/br_bct_BR.bct
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:16384
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00004000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:32768
tar: Read checkpoint 1020000
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00008000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:49152
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x0000c000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:65536
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00010000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:81920
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00014000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:98304
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00018000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:114688
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x0001c000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:131072
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00020000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:147456
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00024000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:163840
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00028000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:180224
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x0002c000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:196608
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00030000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:212992
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00034000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:229376
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00038000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:245760
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x0003c000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:262144
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00040000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:278528
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00044000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:294912
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00048000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:311296
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x0004c000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:327680
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00050000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:344064
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00054000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:360448
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00058000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:376832
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x0005c000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:393216
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00060000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:409600
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00064000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:425984
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00068000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:442368
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x0006c000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:458752
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00070000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:475136
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00074000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:491520
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00078000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:507904
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x0007c000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:524288
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00080000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:540672
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00084000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:557056
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00088000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:573440
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x0008c000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:589824
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00090000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:606208
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00094000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:622592
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x00098000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:638976
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x0009c000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:655360
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x000a0000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:671744
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x000a4000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:688128
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x000a8000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:704512
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x000ac000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:720896
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x000b0000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:737280
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x000b4000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:753664
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x000b8000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:770048
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x000bc000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:786432
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x000c0000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:802816
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x000c4000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:819200
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x000c8000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:835584
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x000cc000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:851968
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x000d0000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:868352
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x000d4000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:884736
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x000d8000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:901120
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x000dc000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:917504
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x000e0000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:933888
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x000e4000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:950272
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x000e8000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:966656
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x000ec000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:983040
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x000f0000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:999424
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x000f4000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:1015808
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x000f8000 in flash
Writing /mnt/internal/br_bct_BR.bct (8192 bytes) into /dev/mtd0:1032192
Copied 8192 bytes from /mnt/internal/br_bct_BR.bct to address 0x000fc000 in flash
Writing mb1_t234_prod_aligned_sigheader.bin.encrypt (pbhttion: A_mb1) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/mb1_t234_prod_aligned_sigheader.bin.encrypt
Writing /mnt/internal/mb1_t234_prod_aligned_sigheader.bin.encrypt (282544 bytes) into /dev/mtd0:1048576
tar: Read checkpoint 1030000
Copied 282544 bytes from /mnt/internal/mb1_t234_prod_aligned_sigheader.bin.encrypt to address 0x00100000 in flash
Writing psc_bl1_t234_prod_aligned_sigheader.bin.encrypt (pbhttion: A_psc_bl1) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/psc_bl1_t234_prod_aligned_sigheader.bin.encrypt
Writing /mnt/internal/psc_bl1_t234_prod_aligned_sigheader.bin.encrypt (123008 bytes) into /dev/mtd0:1572864
Copied 123008 bytes from /mnt/internal/psc_bl1_t234_prod_aligned_sigheader.bin.encrypt to address 0x00180000 in flash
Writing mb1_cold_boot_bct_MB1_sigheader.bct.encrypt (pbhttion: A_MB1_BCT) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
Writing /mnt/internal/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt (17616 bytes) into /dev/mtd0:1835008
Copied 17616 bytes from /mnt/internal/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt to address 0x001c0000 in flash
Writing mem_coldboot_sigheader.bct.encrypt (pbhttion: A_MEM_BCT) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/mem_coldboot_sigheader.bct.encrypt
Writing /mnt/internal/mem_coldboot_sigheader.bct.encrypt (243712 bytes) into /dev/mtd0:1966080
Copied 243712 bytes from /mnt/internal/mem_coldboot_sigheader.bct.encrypt to address 0x001e0000 in flash
tar: Read checkpoint 1040000
Writing tsec_t234_sigheader.bin.encrypt (pbhttion: A_tsec-fw) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/tsec_t234_sigheader.bin.encrypt
Writing /mnt/internal/tsec_t234_sigheader.bin.encrypt (176128 bytes) into /dev/mtd0:2228224
Copied 176128 bytes from /mnt/internal/tsec_t234_sigheader.bin.encrypt to address 0x00220000 in flash
Writing nvdec_t234_prod_sigheader.fw.encrypt (pbhttion: A_nvdec) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/nvdec_t234_prod_sigheader.fw.encrypt
Writing /mnt/internal/nvdec_t234_prod_sigheader.fw.encrypt (294912 bytes) into /dev/mtd0:3276800
Copied 294912 bytes from /mnt/internal/nvdec_t234_prod_sigheader.fw.encrypt to address 0x00320000 in flash
Writing mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt (pbhttion: A_mb2) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt
Writing /mnt/internal/mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt (439968 bytes) into /dev/mtd0:4325376
Copied 439968 bytes from /mnt/internal/mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt to address 0x00420000 in flash
Writing xusb_t234_prod_sigheader.bin.encrypt (pbhttion: A_xusb-fw) into /dev/mtd0
tar: Read checkpoint 1050000
Sha1 checksum matched for /mnt/internal/xusb_t234_prod_sigheader.bin.encrypt
Writing /mnt/internal/xusb_t234_prod_sigheader.bin.encrypt (164864 bytes) into /dev/mtd0:4849664
Copied 164864 bytes from /mnt/internal/xusb_t234_prod_sigheader.bin.encrypt to address 0x004a0000 in flash
Writing bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt (pbhttion: A_bpmp-fw) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt
Writing /mnt/internal/bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt (1027008 bytes) into /dev/mtd0:5111808
tar: Read checkpoint 1060000
Copied 1027008 bytes from /mnt/internal/bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt to address 0x004e0000 in flash
Writing tegra234-bpmp-3767-0001-3509-a02_with_odm_sigheader.dtb.encrypt (pbhttion: A_bpmp-fw-dtb) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/tegra234-bpmp-3767-0001-3509-a02_with_odm_sigheader.dtb.encrypt
Writing /mnt/internal/tegra234-bpmp-3767-0001-3509-a02_with_odm_sigheader.dtb.encrypt (263424 bytes) into /dev/mtd0:6684672
Copied 263424 bytes from /mnt/internal/tegra234-bpmp-3767-0001-3509-a02_with_odm_sigheader.dtb.encrypt to address 0x00660000 in flash
Writing pscfw_t234_prod_sigheader.bin.encrypt (pbhttion: A_psc-fw) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/pscfw_t234_prod_sigheader.bin.encrypt
Writing /mnt/internal/pscfw_t234_prod_sigheader.bin.encrypt (310768 bytes) into /dev/mtd0:10878976
tar: Read checkpoint 1070000
Copied 310768 bytes from /mnt/internal/pscfw_t234_prod_sigheader.bin.encrypt to address 0x00a60000 in flash
Writing mce_flash_o10_cr_prod_sigheader.bin.encrypt (pbhttion: A_mts-mce) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/mce_flash_o10_cr_prod_sigheader.bin.encrypt
Writing /mnt/internal/mce_flash_o10_cr_prod_sigheader.bin.encrypt (187120 bytes) into /dev/mtd0:11665408
Copied 187120 bytes from /mnt/internal/mce_flash_o10_cr_prod_sigheader.bin.encrypt to address 0x00b20000 in flash
Writing sc7_t234_prod_sigheader.bin.encrypt (pbhttion: A_sc7) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/sc7_t234_prod_sigheader.bin.encrypt
Writing /mnt/internal/sc7_t234_prod_sigheader.bin.encrypt (186656 bytes) into /dev/mtd0:12189696
Copied 186656 bytes from /mnt/internal/sc7_t234_prod_sigheader.bin.encrypt to address 0x00ba0000 in flash
Writing psc_rf_t234_prod_sigheader.bin.encrypt (pbhttion: A_pscrf) into /dev/mtd0
tar: Read checkpoint 1080000
Sha1 checksum matched for /mnt/internal/psc_rf_t234_prod_sigheader.bin.encrypt
Writing /mnt/internal/psc_rf_t234_prod_sigheader.bin.encrypt (122464 bytes) into /dev/mtd0:12386304
Copied 122464 bytes from /mnt/internal/psc_rf_t234_prod_sigheader.bin.encrypt to address 0x00bd0000 in flash
Writing mb2rf_t234_sigheader.bin.encrypt (pbhttion: A_mb2rf) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/mb2rf_t234_sigheader.bin.encrypt
Writing /mnt/internal/mb2rf_t234_sigheader.bin.encrypt (122672 bytes) into /dev/mtd0:12582912
Copied 122672 bytes from /mnt/internal/mb2rf_t234_sigheader.bin.encrypt to address 0x00c00000 in flash
Writing uefi_jetson_with_dtb_aligned_blob_w_bin_sigheader.bin.encrypt (pbhttion: A_cpu-bootloader) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/uefi_jetson_with_dtb_aligned_blob_w_bin_sigheader.bin.encrypt
Writing /mnt/internal/uefi_jetson_with_dtb_aligned_blob_w_bin_sigheader.bin.encrypt (3264544 bytes) into /dev/mtd0:12713984
tar: Read checkpoint 1090000
tar: Read checkpoint 1100000
tar: Read checkpoint 1110000
tar: Read checkpoint 1120000
tar: Read checkpoint 1130000
Copied 3264544 bytes from /mnt/internal/uefi_jetson_with_dtb_aligned_blob_w_bin_sigheader.bin.encrypt to address 0x00c20000 in flash
Writing tos-optee_t234_sigheader.img.encrypt (pbhttion: A_secure-os) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/tos-optee_t234_sigheader.img.encrypt
Writing /mnt/internal/tos-optee_t234_sigheader.img.encrypt (1633344 bytes) into /dev/mtd0:16384000
tar: Read checkpoint 1140000
tar: Read checkpoint 1150000
Copied 1633344 bytes from /mnt/internal/tos-optee_t234_sigheader.img.encrypt to address 0x00fa0000 in flash
[ 220]: l4t_flash_from_kernel: Warning: skip writing A_smm-fw partition as no image is specified
Writing eks_t234_sigheader.img.encrypt (pbhttion: A_eks) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/eks_t234_sigheader.img.encrypt
Writing /mnt/internal/eks_t234_sigheader.img.encrypt (9232 bytes) into /dev/mtd0:22675456
Copied 9232 bytes from /mnt/internal/eks_t234_sigheader.img.encrypt to address 0x015a0000 in flash
Writing display-t234-dce_with_tegra234-j401-p3768-0000+p3767-0001-recomputer_with_odm_overlay.dtb_with_dce_overlay_aligned_blob_w_bin_sigheader.bin.encrypt (pbhttion: A_dce-fw) into /dev/mtd0
tar: Read checkpoint 1160000
Sha1 checksum matched for /mnt/internal/display-t234-dce_with_tegra234-j401-p3768-0000+p3767-0001-recomputer_with_odm_overlay.dtb_with_dce_overlay_aligned_blob_w_bin_sigheader.bin.encrypt
Writing /mnt/internal/display-t234-dce_with_tegra234-j401-p3768-0000+p3767-0001-recomputer_with_odm_overlay.dtb_with_dce_overlay_aligned_blob_w_bin_sigheader.bin.encrypt (780144 bytes) into /dev/mtd0:22937600
Copied 780144 bytes from /mnt/internal/display-t234-dce_with_tegra234-j401-p3768-0000+p3767-0001-recomputer_with_odm_overlay.dtb_with_dce_overlay_aligned_blob_w_bin_sigheader.bin.encrypt to address 0x015e0000 in flash
Writing spe_t234_sigheader.bin.encrypt (pbhttion: A_spe-fw) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/spe_t234_sigheader.bin.encrypt
Writing /mnt/internal/spe_t234_sigheader.bin.encrypt (270336 bytes) into /dev/mtd0:28180480
tar: Read checkpoint 1170000
Copied 270336 bytes from /mnt/internal/spe_t234_sigheader.bin.encrypt to address 0x01ae0000 in flash
Writing camera-rtcpu-t234-rce_sigheader.img.encrypt (pbhttion: A_rce-fw) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/camera-rtcpu-t234-rce_sigheader.img.encrypt
Writing /mnt/internal/camera-rtcpu-t234-rce_sigheader.img.encrypt (458096 bytes) into /dev/mtd0:28770304
tar: Read checkpoint 1180000
Copied 458096 bytes from /mnt/internal/camera-rtcpu-t234-rce_sigheader.img.encrypt to address 0x01b70000 in flash
Writing adsp-fw_sigheader.bin.encrypt (pbhttion: A_adsp-fw) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/adsp-fw_sigheader.bin.encrypt
Writing /mnt/internal/adsp-fw_sigheader.bin.encrypt (414976 bytes) into /dev/mtd0:29818880
Copied 414976 bytes from /mnt/internal/adsp-fw_sigheader.bin.encrypt to address 0x01c70000 in flash
Writing nvpva_020_aligned_blob_w_bin_sigheader.fw.encrypt (pbhttion: A_pva-fw) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/nvpva_020_aligned_blob_w_bin_sigheader.fw.encrypt
Writing /mnt/internal/nvpva_020_aligned_blob_w_bin_sigheader.fw.encrypt (67024 bytes) into /dev/mtd0:31916032
Copied 67024 bytes from /mnt/internal/nvpva_020_aligned_blob_w_bin_sigheader.fw.encrypt to address 0x01e70000 in flash
[ 224]: l4t_flash_from_kernel: Warning: skip writing A_reserved_on_boot partition as no image is specified
Writing mb1_t234_prod_aligned_sigheader.bin.encrypt (pbhttion: B_mb1) into /dev/mtd0
Writing /mnt/internal/mb1_t234_prod_aligned_sigheader.bin.encrypt (282544 bytes) into /dev/mtd0:33292288
tar: Read checkpoint 1190000
Copied 282544 bytes from /mnt/internal/mb1_t234_prod_aligned_sigheader.bin.encrypt to address 0x01fc0000 in flash
Writing psc_bl1_t234_prod_aligned_sigheader.bin.encrypt (pbhttion: B_psc_bl1) into /dev/mtd0
Writing /mnt/internal/psc_bl1_t234_prod_aligned_sigheader.bin.encrypt (123008 bytes) into /dev/mtd0:33816576
Copied 123008 bytes from /mnt/internal/psc_bl1_t234_prod_aligned_sigheader.bin.encrypt to address 0x02040000 in flash
Writing mb1_cold_boot_bct_MB1_sigheader.bct.encrypt (pbhttion: B_MB1_BCT) into /dev/mtd0
Writing /mnt/internal/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt (17616 bytes) into /dev/mtd0:34078720
Copied 17616 bytes from /mnt/internal/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt to address 0x02080000 in flash
Writing mem_coldboot_sigheader.bct.encrypt (pbhttion: B_MEM_BCT) into /dev/mtd0
Writing /mnt/internal/mem_coldboot_sigheader.bct.encrypt (243712 bytes) into /dev/mtd0:34209792
tar: Read checkpoint 1200000
Copied 243712 bytes from /mnt/internal/mem_coldboot_sigheader.bct.encrypt to address 0x020a0000 in flash
Writing tsec_t234_sigheader.bin.encrypt (pbhttion: B_tsec-fw) into /dev/mtd0
Writing /mnt/internal/tsec_t234_sigheader.bin.encrypt (176128 bytes) into /dev/mtd0:34471936
Copied 176128 bytes from /mnt/internal/tsec_t234_sigheader.bin.encrypt to address 0x020e0000 in flash
Writing nvdec_t234_prod_sigheader.fw.encrypt (pbhttion: B_nvdec) into /dev/mtd0
Writing /mnt/internal/nvdec_t234_prod_sigheader.fw.encrypt (294912 bytes) into /dev/mtd0:35520512
Copied 294912 bytes from /mnt/internal/nvdec_t234_prod_sigheader.fw.encrypt to address 0x021e0000 in flash
tar: Read checkpoint 1210000
Writing mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt (pbhttion: B_mb2) into /dev/mtd0
Writing /mnt/internal/mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt (439968 bytes) into /dev/mtd0:36569088
Copied 439968 bytes from /mnt/internal/mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt to address 0x022e0000 in flash
Writing xusb_t234_prod_sigheader.bin.encrypt (pbhttion: B_xusb-fw) into /dev/mtd0
Writing /mnt/internal/xusb_t234_prod_sigheader.bin.encrypt (164864 bytes) into /dev/mtd0:37093376
tar: Read checkpoint 1220000
Copied 164864 bytes from /mnt/internal/xusb_t234_prod_sigheader.bin.encrypt to address 0x02360000 in flash
Writing bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt (pbhttion: B_bpmp-fw) into /dev/mtd0
Writing /mnt/internal/bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt (1027008 bytes) into /dev/mtd0:37355520
tar: Read checkpoint 1230000
tar: Read checkpoint 1240000
Copied 1027008 bytes from /mnt/internal/bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt to address 0x023a0000 in flash
Writing tegra234-bpmp-3767-0001-3509-a02_with_odm_sigheader.dtb.encrypt (pbhttion: B_bpmp-fw-dtb) into /dev/mtd0
Writing /mnt/internal/tegra234-bpmp-3767-0001-3509-a02_with_odm_sigheader.dtb.encrypt (263424 bytes) into /dev/mtd0:38928384
Copied 263424 bytes from /mnt/internal/tegra234-bpmp-3767-0001-3509-a02_with_odm_sigheader.dtb.encrypt to address 0x02520000 in flash
Writing pscfw_t234_prod_sigheader.bin.encrypt (pbhttion: B_psc-fw) into /dev/mtd0
Writing /mnt/internal/pscfw_t234_prod_sigheader.bin.encrypt (310768 bytes) into /dev/mtd0:43122688
Copied 310768 bytes from /mnt/internal/pscfw_t234_prod_sigheader.bin.encrypt to address 0x02920000 in flash
Writing mce_flash_o10_cr_prod_sigheader.bin.encrypt (pbhttion: B_mts-mce) into /dev/mtd0
Writing /mnt/internal/mce_flash_o10_cr_prod_sigheader.bin.encrypt (187120 bytes) into /dev/mtd0:43909120
Copied 187120 bytes from /mnt/internal/mce_flash_o10_cr_prod_sigheader.bin.encrypt to address 0x029e0000 in flash
Writing sc7_t234_prod_sigheader.bin.encrypt (pbhttion: B_sc7) into /dev/mtd0
Writing /mnt/internal/sc7_t234_prod_sigheader.bin.encrypt (186656 bytes) into /dev/mtd0:44433408
tar: Read checkpoint 1250000
Copied 186656 bytes from /mnt/internal/sc7_t234_prod_sigheader.bin.encrypt to address 0x02a60000 in flash
Writing psc_rf_t234_prod_sigheader.bin.encrypt (pbhttion: B_pscrf) into /dev/mtd0
Writing /mnt/internal/psc_rf_t234_prod_sigheader.bin.encrypt (122464 bytes) into /dev/mtd0:44630016
Copied 122464 bytes from /mnt/internal/psc_rf_t234_prod_sigheader.bin.encrypt to address 0x02a90000 in flash
Writing mb2rf_t234_sigheader.bin.encrypt (pbhttion: B_mb2rf) into /dev/mtd0
Writing /mnt/internal/mb2rf_t234_sigheader.bin.encrypt (122672 bytes) into /dev/mtd0:44826624
Copied 122672 bytes from /mnt/internal/mb2rf_t234_sigheader.bin.encrypt to address 0x02ac0000 in flash
Writing uefi_jetson_with_dtb_aligned_blob_w_bin_sigheader.bin.encrypt (pbhttion: B_cpu-bootloader) into /dev/mtd0
Writing /mnt/internal/uefi_jetson_with_dtb_aligned_blob_w_bin_sigheader.bin.encrypt (3264544 bytes) into /dev/mtd0:44957696
tar: Read checkpoint 1260000
tar: Read checkpoint 1270000
tar: Read checkpoint 1280000
Copied 3264544 bytes from /mnt/internal/uefi_jetson_with_dtb_aligned_blob_w_bin_sigheader.bin.encrypt to address 0x02ae0000 in flash
Writing tos-optee_t234_sigheader.img.encrypt (pbhttion: B_secure-os) into /dev/mtd0
Writing /mnt/internal/tos-optee_t234_sigheader.img.encrypt (1633344 bytes) into /dev/mtd0:48627712
tar: Read checkpoint 1290000
tar: Read checkpoint 1300000
Copied 1633344 bytes from /mnt/internal/tos-optee_t234_sigheader.img.encrypt to address 0x02e60000 in flash
tar: Read checkpoint 1310000
[ 239]: l4t_flash_from_kernel: Warning: skip writing B_smm-fw partition as no image is specified
Writing eks_t234_sigheader.img.encrypt (pbhttion: B_eks) into /dev/mtd0
Writing /mnt/internal/eks_t234_sigheader.img.encrypt (9232 bytes) into /dev/mtd0:54919168
Copied 9232 bytes from /mnt/internal/eks_t234_sigheader.img.encrypt to address 0x03460000 in flash
Writing display-t234-dce_with_tegra234-j401-p3768-0000+p3767-0001-recomputer_with_odm_overlay.dtb_with_dce_overlay_aligned_blob_w_bin_sigheader.bin.encrypt (pbhttion: B_dce-fw) into /dev/mtd0
Writing /mnt/internal/display-t234-dce_with_tegra234-j401-p3768-0000+p3767-0001-recomputer_with_odm_overlay.dtb_with_dce_overlay_aligned_blob_w_bin_sigheader.bin.encrypt (780144 bytes) into /dev/mtd0:55181312
Copied 780144 bytes from /mnt/internal/display-t234-dce_with_tegra234-j401-p3768-0000+p3767-0001-recomputer_with_odm_overlay.dtb_with_dce_overlay_aligned_blob_w_bin_sigheader.bin.encrypt to address 0x034a0000 in flash
Writing spe_t234_sigheader.bin.encrypt (pbhttion: B_spe-fw) into /dev/mtd0
Writing /mnt/internal/spe_t234_sigheader.bin.encrypt (270336 bytes) into /dev/mtd0:60424192
tar: Read checkpoint 1320000
Copied 270336 bytes from /mnt/internal/spe_t234_sigheader.bin.encrypt to address 0x039a0000 in flash
Writing camera-rtcpu-t234-rce_sigheader.img.encrypt (pbhttion: B_rce-fw) into /dev/mtd0
Writing /mnt/internal/camera-rtcpu-t234-rce_sigheader.img.encrypt (458096 bytes) into /dev/mtd0:61014016
Copied 458096 bytes from /mnt/internal/camera-rtcpu-t234-rce_sigheader.img.encrypt to address 0x03a30000 in flash
Writing adsp-fw_sigheader.bin.encrypt (pbhttion: B_adsp-fw) into /dev/mtd0
Writing /mnt/internal/adsp-fw_sigheader.bin.encrypt (414976 bytes) into /dev/mtd0:62062592
tar: Read checkpoint 1330000
Copied 414976 bytes from /mnt/internal/adsp-fw_sigheader.bin.encrypt to address 0x03b30000 in flash
Writing nvpva_020_aligned_blob_w_bin_sigheader.fw.encrypt (pbhttion: B_pva-fw) into /dev/mtd0
Writing /mnt/internal/nvpva_020_aligned_blob_w_bin_sigheader.fw.encrypt (67024 bytes) into /dev/mtd0:64159744
Copied 67024 bytes from /mnt/internal/nvpva_020_aligned_blob_w_bin_sigheader.fw.encrypt to address 0x03d30000 in flash
[ 243]: l4t_flash_from_kernel: Warning: skip writing B_reserved_on_boot partition as no image is specified
[ 243]: l4t_flash_from_kernel: Warning: skip writing uefi_vbhables partition as no image is specified
[ 243]: l4t_flash_from_kernel: Warning: skip writing uefi_ftw partition as no image is specified
[ 243]: l4t_flash_from_kernel: Warning: skip writing reserved partition as no image is specified
[ 243]: l4t_flash_from_kernel: Warning: skip writing worm partition as no image is specified
Writing bct_backup.img (pbhttion: BCT-boot-chain_backup) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/bct_backup.img
Writing /mnt/internal/bct_backup.img (32768 bytes) into /dev/mtd0:66715648
Copied 32768 bytes from /mnt/internal/bct_backup.img to address 0x03fa0000 in flash
[ 243]: l4t_flash_from_kernel: Warning: skip writing reserved_partition partition as no image is specified
Writing gpt_backup_secondary_3_0.bin (pbhttion: secondary_gpt_backup) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/gpt_backup_secondary_3_0.bin
Writing /mnt/internal/gpt_backup_secondary_3_0.bin (16896 bytes) into /dev/mtd0:66846720
Copied 16896 bytes from /mnt/internal/gpt_backup_secondary_3_0.bin to address 0x03fc0000 in flash
Writing qspi_bootblob_ver.txt (pbhttion: B_VER) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/qspi_bootblob_ver.txt
Writing /mnt/internal/qspi_bootblob_ver.txt (109 bytes) into /dev/mtd0:66912256
Copied 109 bytes from /mnt/internal/qspi_bootblob_ver.txt to address 0x03fd0000 in flash
Writing qspi_bootblob_ver.txt (pbhttion: A_VER) into /dev/mtd0
Writing /mnt/internal/qspi_bootblob_ver.txt (109 bytes) into /dev/mtd0:66977792
Copied 109 bytes from /mnt/internal/qspi_bootblob_ver.txt to address 0x03fe0000 in flash
Writing gpt_secondary_3_0.bin (pbhttion: secondary_gpt) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/gpt_secondary_3_0.bin
Writing /mnt/internal/gpt_secondary_3_0.bin (16896 bytes) into /dev/mtd0:67091968
Copied 16896 bytes from /mnt/internal/gpt_secondary_3_0.bin to address 0x03ffbe00 in flash
[ 243]: l4t_flash_from_kernel: Successfully flash the qspi
tar: Read checkpoint 1340000
tar: Read checkpoint 1350000
tar: Read checkpoint 1360000
tar: Read checkpoint 1370000
tar: Read checkpoint 1380000
tar: Read checkpoint 1390000
tar: Read checkpoint 1400000
tar: Read checkpoint 1410000
tar: Read checkpoint 1420000
tar: Read checkpoint 1430000
tar: Read checkpoint 1440000
tar: Read checkpoint 1450000
tar: Read checkpoint 1460000
tar: Read checkpoint 1470000
tar: Read checkpoint 1480000
tar: Read checkpoint 1490000
tar: Read checkpoint 1500000
tar: Read checkpoint 1510000
tar: Read checkpoint 1520000
tar: Read checkpoint 1530000
tar: Read checkpoint 1540000
tar: Read checkpoint 1550000
tar: Read checkpoint 1560000
tar: Read checkpoint 1570000
tar: Read checkpoint 1580000
tar: Read checkpoint 1590000
tar: Read checkpoint 1600000
tar: Read checkpoint 1610000
tar: Read checkpoint 1620000
tar: Read checkpoint 1630000
tar: Read checkpoint 1640000
tar: Read checkpoint 1650000
tar: Read checkpoint 1660000
tar: Read checkpoint 1670000
tar: Read checkpoint 1680000
tar: Read checkpoint 1690000
tar: Read checkpoint 1700000
tar: Read checkpoint 1710000
tar: Read checkpoint 1720000
tar: Read checkpoint 1730000
tar: Read checkpoint 1740000
tar: Read checkpoint 1750000
tar: Read checkpoint 1760000
tar: Read checkpoint 1770000
tar: Read checkpoint 1780000
tar: Read checkpoint 1790000
tar: Read checkpoint 1800000
tar: Read checkpoint 1810000
tar: Read checkpoint 1820000
tar: Read checkpoint 1830000
tar: Read checkpoint 1840000
tar: Read checkpoint 1850000
tar: Read checkpoint 1860000
tar: Read checkpoint 1870000
tar: Read checkpoint 1880000
tar: Read checkpoint 1890000
tar: Read checkpoint 1900000
tar: Read checkpoint 1910000
tar: Read checkpoint 1920000
tar: Read checkpoint 1930000
tar: Read checkpoint 1940000
writing item=17, 9:0:secondary_gpt, 102399983104, 16896, gpt_secondary_9_0.bin, 16896, fixed-<reserved>-0, 84d7ea96fe399ad9d471b245124d9d201dd03ae9
[ 327]: l4t_flash_from_kernel: Successfully flash the external device
[ 327]: l4t_flash_from_kernel: Flashing success
[ 327]: l4t_flash_from_kernel: The device size indicated in the partition layout xml is smaller than the actual size. This utility will try to fix the GPT.
Flash is successful
Reboot device
Cleaning up...
