Jetson orin nano bootup hang at MB2 phase
I used below command to update the flash to support A/B partition.
sudo ROOTFS_AB=1 ./tools/kernel_flash/l4t_initrd_flash.sh \
--external-device nvme0n1 \
-c ./tools/kernel_flash/flash_l4t_nvme_rootfs_ab.xml \
jetson-orin-nano-devkit-nvme \
external
and before updating the flash. I changed the instance num from 4 to 0, in the file
Linux_for_Tegra/bootloader/generic/cfg/flash_t234_qspi_nvme.xml.
    <device type="nvme" instance="**4**" sector_size="512" num_sectors="INT_NUM_SECTORS" >
        <partition name="master_boot_record" type="protective_master_boot_record">
            <allocation_policy> sequential </allocation_policy>
            <filesystem_type> basic </filesystem_type>
            <size> 512 </size>
            <file_system_attribute> 0 </file_system_attribute>
            <allocation_attribute> 8 </allocation_attribute>
            <percent_reserved> 0 </percent_reserved>
        </partition>
Bootup log as follow:
I> MB2 (version: 0.0.0.0-t234-54845784-af79ed0a)
I> t234-A01-1-Silicon (0x12347)
I> Boot-mode : Coldboot
I> Emulation:
I> Entry timestamp: 0x001ee607
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x173800000, size:0x800000]
I> Task: SE error check
I> Task: Crypto init
I> Task: MB2 Params integrity check
I> Task: Enable CCPLEX WDT 5th expiry
I> Task: ARI update carveout TZDRAM
I> Task: Configure OEM set LA/PTSA values
I> Task: Check MC errors
I> Task: Enable hot-plug capability
I> Task: PSC mailbox init
I> Task: Enable clock for external modules
I> Task: Measured Boot init
I> Task: fTPM silicon identity init
I> fTPM is not enabled.
I> Task: OEM SC7 context save init
I> Task: I2C register
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout
I> Task: Program CBB PCIE AMAP regions
I> Task: Boot device init
I> Boot_device: QSPI_FLASH instance: 0
I> Qspi clock source : pllc_out0
I> QSPI Flash: Macronix 64MB
I> QSPI-0l initialized successfully
I> Secondary storage device: QSPI_FLASH instance: 0
I> Secondary storage device: **NVME instance: 0**
I> Initializing nvme device instance 0
I> Initializing nvme controller
I> tegrabl_pcie_soc_preinit: (0):
I> Unpowergate
I> unknown unpowergate domain_id : 6
I> tegrabl_pcie_soc_init: (0):
I> APPL initialization ...
**!0x380 Exception! [elr:0x50049900, spsr:0x600002cd, esr:0xbe000011, far:0x0]**
Could you provide the source code of MB2? Or explanation of failure with “NVME instance: 0”?
We have guidance on flashing with rootfs redundancy enabled:
https://docs.nvidia.com/jetson/archives/r36.3/DeveloperGuide/SD/FlashingSupport.html#using-initrd-flash-with-orin-nx-and-nano
It’s meaningless to modify this file while you are flashing with /tools/kernel_flash/flash_l4t_nvme_rootfs_ab.xml
Also, why are you making such changes?
Yes, you are right, I didn’t want to change this instance number.
But, When I use “tools/create_nvme_disk_image.sh” to create disk image, It will report
process part_num=15;part_name=reserved;part_size=502792192;part_file=;part_type=8300 exited
process part_num=16;part_name=master_boot_record;part_size=512;part_file=;part_type=8300 started
dd: error reading '/media/Jetson/R36.3/Linux_for_Tegra/bootloader/signed/': Is a directory
According to the python script “bootloader/tegraflash_impl_t234.py”, master_boot_record not support instance 4 , only support instance 0.
    tegraflash_gpt_image_name_map = {
        'nvme_0_master_boot_record': 'mbr_12_0.bin',
        'nvme_0_primary_gpt': 'gpt_primary_12_0.bin',
        'nvme_0_secondary_gpt': 'gpt_secondary_12_0.bin',
        'sdcard_0_master_boot_record': 'mbr_6_0.bin',
        'sdcard_0_primary_gpt': 'gpt_primary_6_0.bin',
        'sdcard_0_secondary_gpt': 'gpt_secondary_6_0.bin',
It seems like there are two choices,
One is changing instance num to 0 in flash_t234_qspi_nvme.xml,
Two is adding “‘nvme_4_master_boot_record’: ‘mbr_12_4.bin’,”
I selected the one solution. But it case this new issue.
What do you think ? Do you have other official solution to resolve “create_nvme_disk_image.sh” issue?
We don’t have any scripts called create_nvme_disk_image.sh
Where did you get this stuff?
Sorry, I forgot that this file is created by my colleagues.
#!/bin/bash
script_name="$(basename "${0}")"
l4t_tools_dir="$(cd "$(dirname "${0}")" && pwd)"
l4t_dir="${l4t_tools_dir%/*}"
sudo ${l4t_tools_dir}/jetson-disk-image-creator.sh -o nvme-blob.img -b jetson-orin-nano-devkit-nvme -d NVME && sudo gzip -v -9 nvme-blob.img
and jetson-disk-image-creator.sh is also be add nvme support.
#!/bin/bash
# SPDX-FileCopyrightText: Copyright (c) 2019-2023 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
# SPDX-License-Identifier: LicenseRef-NvidiaProprietary
# NVIDIA CORPORATION, its affiliates and licensors retain all intellectual
# property and proprietary rights in and to this material, related
# documentation and any modifications thereto. Any use, reproduction,
# disclosure or distribution of this material and related documentation
# without an express license agreement from NVIDIA CORPORATION or
# its affiliates is strictly prohibited.
# This is a script to generate the SD card flashable image for
# jetson-xavier-nx-devkit and jetson-agx-orin-devkit platforms
set -e
function usage()
	if [ -n "${1}" ]; then
		echo "${1}"
	fi
	echo "Usage:"
	echo "${script_name} -o <sd_blob_name> -b <board> -r <revision> -d <device>"
	echo "	sd_blob_name	- valid file name"
	echo "	board		- board name. Supported boards are:"
	echo "			   jetson-xavier-nx-devkit"
	echo "			   jetson-agx-xavier-devkit"
	echo "		           jetson-agx-orin-devkit"
	echo "		           jetson-orin-nano-devkit"
	echo "		           jetson-orin-nano-devkit-nvme"
	echo "	revision	- SKU revision number"
	echo "			   jetson-xavier-nx-devkit: default"
	echo "			   jetson-agx-xavier-devkit: default"
	echo "			   jetson-agx-orin-devkit: default"
	echo "			   jetson-orin-nano-devkit: default"
	echo "	device   	- Root filesystem device"
	echo "			   jetson-xavier-nx-devkit: SD/USB"
	echo "			   jetson-agx-xavier-devkit: SD/USB"
	echo "			   jetson-agx-orin-devkit: SD/USB"
	echo "			   jetson-orin-nano-devkit: SD/USB"
	echo "			   jetson-orin-nano-devkit-nvme: NVME/USB"
	echo "Example:"
	echo "${script_name} -o sd-blob.img -b jetson-xavier-nx-devkit -d SD"
	echo "${script_name} -o sd-blob.img -b jetson-agx-orin-devkit -d USB"
	echo "${script_name} -o nvme-blob.img -b jetson-orin-nano-devkit-nvme -d NVME"
	exit 1
function cleanup() {
	set +e
	if [ -n "${tmpdir}" ]; then
		umount "${tmpdir}"
		rmdir "${tmpdir}"
	fi
	if [ -n "${loop_dev}" ]; then
		losetup -d "${loop_dev}"
	fi
trap cleanup EXIT
function check_device()
	case "${board}" in
	jetson-xavier-nx-devkit)
		case "${rootfs_dev}" in
		"SD" | "sd")
			rootfs_dev="mmcblk0p1"
		"USB" | "usb")
			rootfs_dev="sda1"
			usage "Incorrect root filesystem device - Supported devices - SD, USB"
		esac
	jetson-agx-xavier-devkit)
		"SD" | "sd")
			rootfs_dev="mmcblk1p1"
		"USB" | "usb")
			rootfs_dev="sda1"
		esac
	jetson-agx-orin-devkit)
		"SD" | "sd")
		"USB" | "usb")
			rootfs_dev="sda1"
		esac
	jetson-orin-nano-devkit)
		"SD" | "sd")
		"USB" | "usb")
			rootfs_dev="sda1"
		esac
	jetson-orin-nano-devkit-nvme)
		"NVME" | "nvme")
			rootfs_dev="nvme0n1p1"
		"USB" | "usb")
			rootfs_dev="sda1"
			usage "Incorrect root filesystem device - Supported devices - NVME, USB"
		esac
	esac
function check_revision()
	case "${board}" in
		rev="000"
	esac
function check_pre_req()
	if [ $(id -u) -ne 0 ]; then
		echo "ERROR: This script requires root privilege" > /dev/stderr
		usage
		exit 1
	fi
	while [ -n "${1}" ]; do
		case "${1}" in
		-h | --help)
			usage
		-b | --board)
			[ -n "${2}" ] || usage "Not enough parameters"
			board="${2}"
			shift 2
		-o | --outname)
			sd_blob_name="${2}"
			shift 2
		-r | --revision)
			rev="${2}"
			shift 2
		-d | --device)
			rootfs_dev="${2}"
			shift 2
			usage "Unknown option: ${1}"
		esac
	done
	if [ "${board}" == "" ]; then
		echo "ERROR: Invalid board name" > /dev/stderr
		usage
	else
		case "${board}" in
			boardid="3668"
			target="jetson-xavier-nx-devkit"
			storage="sdcard"
			boardid="2888"
			target="jetson-agx-xavier-devkit"
			storage="sdmmc_user"
			boardid="3701"
			target="jetson-agx-orin-devkit"
			boardid="3767"
			boardsku="0005"
			target="jetson-orin-nano-devkit"
			storage="sdcard"
			boardid="3767"
			boardsku="0005"
			target="jetson-orin-nano-devkit-nvme"
			storage="nvme"
			usage "Unknown board: ${board}"
		esac
	fi
	check_revision
	check_device
	if [ "${sd_blob_name}" == "" ]; then
		echo "ERROR: Invalid SD blob image name" > /dev/stderr
		usage
	fi
	if [ ! -f "${l4t_dir}/flash.sh" ]; then
		echo "ERROR: ${l4t_dir}/flash.sh is not found" > /dev/stderr
		usage
	fi
	if [ ! -f "${l4t_tools_dir}/nvptparser.py" ]; then
		echo "ERROR: ${l4t_tools_dir}/nvptparser.py is not found" > /dev/stderr
		usage
	fi
	if [ ! -d "${bootloader_dir}" ]; then
		echo "ERROR: ${bootloader_dir} directory not found" > /dev/stderr
		usage
	fi
	if [ ! -d "${rfs_dir}" ]; then
		echo "ERROR: ${rfs_dir} directory not found" > /dev/stderr
		usage
	fi
function create_raw_image()
	# Calulate raw image size by accumulating partition size with 1MB (2048-sector * 512) round up and plus 2MB for GPTs
	sd_blob_size=$("${l4t_tools_dir}/nvptparser.py" "${signed_image_dir}/${signed_cfg}" "${storage}" | awk -F'[=;]' '{sum += (int($6 / (2048 * 512)) + 1)} END {printf "%dM\n", sum + 2}')
	echo "${script_name} - creating ${sd_blob_name} of ${sd_blob_size}..."
	dd if=/dev/zero of="${sd_blob_name}" bs=1 count=0 seek="${sd_blob_size}"
function create_signed_images()
	echo "${script_name} - creating signed images"
	pushd "${l4t_dir}"
	# rootfs size = rfs_dir size + extra 10% for ext4 metadata and safety margin
	rootfs_size=$(du -ms "${rfs_dir}" | awk '{print $1}')
	rootfs_size=$((rootfs_size + (rootfs_size / 10) + 100))
	# Generate signed images
	BOARDID="${boardid}" BOARDSKU="${boardsku}" FAB="${rev}" BUILD_SD_IMAGE=1 BOOTDEV="${rootfs_dev}" "${l4t_dir}/flash.sh" "--no-flash" "--sign" "-S" "${rootfs_size}MiB" "${target}" "${rootfs_dev}"
	popd
	if [ ! -f "${bootloader_dir}/flashcmd.txt" ]; then
		echo "ERROR: ${bootloader_dir}/flashcmd.txt not found" > /dev/stderr
		exit 1
	fi
	if [ ! -d "${signed_image_dir}" ]; then
		echo "ERROR: ${bootloader_dir}/signed directory not found" > /dev/stderr
		exit 1
	fi
	chipid=$(sed -nr 's/.*chip ([^ ]*).*/\1/p' "${bootloader_dir}/flashcmd.txt")
	if [ "${chipid}" = "0x21" ]; then
		signed_cfg="flash.xml"
	else
		signed_cfg="flash.xml.tmp"
	fi
	if [ ! -f "${signed_image_dir}/${signed_cfg}" ]; then
		echo "ERROR: ${signed_image_dir}/${signed_cfg} not found" > /dev/stderr
		exit 1
	fi
function create_partitions()
	echo "${script_name} - create partitions"
	partitions=($("${l4t_tools_dir}/nvptparser.py" "${signed_image_dir}/${signed_cfg}" "${storage}"))
	sgdisk -og "${sd_blob_name}"
	for part in "${partitions[@]}"; do
		eval "${part}"
		if [ "${part_name}" = "master_boot_record" ]; then
			continue
		fi
		part_size=$((${part_size} / 512)) # convert to sectors
		sgdisk -n "${part_num}":0:+"${part_size}" \
			-c "${part_num}":"${part_name}" \
			-t "${part_num}":"${part_type}" "${sd_blob_name}"
	done
function write_partitions()
	echo "${script_name} - write partitions"
	loop_dev="$(losetup --show -f -P "${sd_blob_name}")"
		echo process ${part} started
		eval "${part}"
		target_file=""
		if [ "${part_name}" = "APP" ]; then
			target_file="${bootloader_dir}/${part_file}.raw"
		elif [ -e "${signed_image_dir}/${part_file}" ]; then
			target_file="${signed_image_dir}/${part_file}"
		elif [ -e "${bootloader_dir}/${part_file}" ]; then
			target_file="${bootloader_dir}/${part_file}"
		fi
			dd conv=notrunc if="${signed_image_dir}/${part_file}" of="${sd_blob_name}" bs="${part_size}" count=1
			echo process ${part} conitnued
			continue
		fi
		if [ "${target_file}" != "" ] && [ "${part_file}" != "" ]; then
			echo "${script_name} - writing ${target_file}"
			sudo dd if="${target_file}" of="${loop_dev}p${part_num}"
		fi
		echo process ${part} finished
	done
	loop_dev=""
boardsku=""
sd_blob_name=""
sd_blob_size=""
if [ -z "${ROOTFS_DIR}" ]; then
	rfs_dir="${l4t_dir}/rootfs"
else
	rfs_dir="${ROOTFS_DIR}"
fi
bootloader_dir="${l4t_dir}/bootloader"
signed_image_dir="${bootloader_dir}/signed"
loop_dev=""
tmpdir=""
echo "********************************************"
echo "     Jetson Disk Image Creation Tool     "
check_pre_req "${@}"
create_raw_image
create_partitions
write_partitions
echo "   Jetson Disk Image Creation Complete   "
difference from the original code.
I don’t know what this has to do with your original issue.
The NVMe image, not to mention whether it’s working or not, and flashing with rootfs AB are completely two different things.
Sorry, Please temporarily ignore A/B issue.
Could you help to check why adding nvme support in “jetson-disk-image-creator.sh” will cause dd error?
What’s the right solution to support nvme in “jetson-disk-image-creator.sh”?
I don’t see anything about dd in this entire post.
You didn’t even mention the complete workflow.
reported by this code in tools/jetson-disk-image-creator.sh.
		eval "${part}"
		target_file=""
		fi
		**if [ "${part_name}" = "master_boot_record" ]; then**
**			dd conv=notrunc if="${signed_image_dir}/${part_file}" of="${sd_blob_name}" bs="${part_size}" count=1**
**			echo process ${part} conitnued**
**			continue**
**		fi**
		fi
	done
	loop_dev=""
The purpose is that we want to create one disk image for offline burning.
But we found that the original script tools/jetson-disk-image-creator.sh is only support SD and USB.
So, we try to add creating nvme image support.
Are you able to create an image for SD card with your current script?
The dd error does not look related to your own changes.
Please also put the complete log when the script is run.
sd_disk_image_creator.log (74.5 KB)
I’m also asking for the log of the failure case with NVMe.
nvme_disk_image_creator.log (75.6 KB)
Any updates?
We will need some more time to check it.
I just tried the second method, which works correctly.
For NVMe disks on Orin Nano DevKit board, the instance number is tied to the physical connectors (C4/C7) so you cannot change it arbitrarily.
