I wonder if there is a way to let the profiler count FLOPs and if not if there is any other method to calculate FLOPS per second beneath analyzing the algorithm…?
How can I find out the theoretical maximum of FLOPS/s for my board (Geforce 9600) ?
Regards,
m
SP Clock Rate * #SP * #Floating point operations pr cc for each SP
In your case Shader Clock is 1.625 GHz. It has 64 SP. Each SP can do a MAD instruction which is 2 flops and the SFU associated with each SP can do 1 multiply - if they not busy. Giving you a peak GFLOP/s at:
1.625 * 64 * 3 = 312 GFLOP/s
A more reasonable estimate is not counting the SFU and just issuing 1 instruction pr cc. But that’s on the low side. This doesn’t count for double precision floating point operations.
Thanks a lot!
I thought the stream processors and the multiprocessors are the same thing, Now I see that I have 12 multiprocessors but 64 streaming processors, can you tell me the difference?
Also, I think you have the number of multiprocessors or number of stream processors wrong for your card. All CUDA-devices made thus far have 8 stream processors per multiprocessor.
The GeForce 9600 GT has 64 stream processors, grouped into 8 multiprocessors. The GeForce 9600 GSO has 96 stream processors, grouped into 12 multiprocessors.
