The code below is written for Fortran 2003 and I am using the following compiler version.
pgfortran 15.5-0 64-bit target on Apple OS/X -tp haswell
The codebase is huge and so including only sections that I think are required below. I am getting the following error messages. Please help me understand the error messages.
invoke_axpy:
809, Generating copyin(field1_proxy%data(1:undf),field2_proxy%data(1:undf))
Generating copyout(field_res_proxy%data(1:undf))
Accelerator kernel generated
810, !$acc loop gang, vector(128) ! blockidx%x threadidx%x
809, Generating Tesla code
nvvmCompileProgram error: 9.
Error: Warning: Linking two modules of different target triples!
psy/psykal_lite.F90(809): Error: Formal parameter space overflowed (4096 bytes max) in function invoke_axpy_809_gpu
PGF90-F-0155-Compiler failed to translate accelerator region (see -Minfo messages): Device compiler exited with error status code (psy/psykal_lite.F90: 1)
PGF90/x86-64 OSX 15.5-0: compilation aborted
!> invoke_axpy: (a * x + y) ; a-scalar, x,y-vector
subroutine invoke_axpy(scalar,field1,field2,field_res)
use log_mod, only : log_event, LOG_LEVEL_ERROR
implicit none
type( field_type ), intent(in ) :: field1,field2
type( field_type ), intent(inout ) :: field_res
real(kind=r_def), intent(in ) :: scalar
type( field_proxy_type) :: field1_proxy,field2_proxy &
, field_res_proxy
integer :: i,undf
field1_proxy = field1%get_proxy()
field2_proxy = field2%get_proxy()
field_res_proxy = field_res%get_proxy()
!sanity check
undf = field1_proxy%vspace%get_undf()
if(undf /= field2_proxy%vspace%get_undf() ) then
! they are not on the same function space
call log_event("Psy:axpy:field1 and field2 live on different w-spaces" &
, LOG_LEVEL_ERROR)
!abort
stop
endif
if(undf /= field_res_proxy%vspace%get_undf() ) then
call log_event("Psy:axpy:field1 and result_field live on different w-spaces" &
, LOG_LEVEL_ERROR)
!abort
stop
endif
!$acc parallel loop copyin(field1_proxy%data(1:undf),field2_proxy%data(1:undf)) copyout(field_res_proxy%data(1:undf))
do i = 1,undf
field_res_proxy%data(i) = (scalar * field1_proxy%data(i)) + field2_proxy%data(i)
end do
!$acc end parallel loop
end subroutine invoke_axpy
type, public :: field_type
private
!> Each field has a pointer to the function space on which it lives
type( function_space_type ), pointer :: vspace => null( )
!> Allocatable array of type real which holds the values of the field
real(kind=r_def), allocatable :: data( : )
contains
!> Function to get a proxy with public pointers to the data in a
!! field_type.
procedure, public :: get_proxy
!> Sends the field contents to the log
!! @param[in] title A title added to the log before the data is written out
procedure, public :: log_field
procedure, public :: log_dofs
procedure, public :: log_minmax
!> function returns the enumerated integer for the functions_space on which
!! the field lives
procedure :: which_function_space
!> Routine to read field
procedure :: read_field
!> Routine to write field
procedure :: write_field
end type field_type
