Fortran derived type (mostly structure constructor) bugs
Here are some bugs I’ve seen recently in PGI 14.1. I’m not sure if these are all still in 14.3, since I don’t have an updated installation handy. Several of these test cases also break with ifort, so I have open bugs with Intel as well, but they still work with the NAG compiler and gfortran.
The bugs are all apparent by compiling these cases with no flags, or with no flags except “-c” for those that have no main program.
  1. There’s an ICE when compiling the following simple (but invalid) Fortran module. The module is invalid because either do_nothing should accept a class(foo) argument, or the “nopass” attribute should be present on its binding. But the compiler segfaults instead of reporting a useful error.
module test_types
type :: foo
 contains
   procedure :: do_nothing
end type foo
contains
  subroutine do_nothing()
  end subroutine do_nothing
end module test_types
  1. PGI has some problem with structure constructors for types that extend types with bound procedures. In short, it rejects the following valid code:
module test_types
implicit none
type :: foo
 contains
end type foo
type, extends(foo) :: bar
   integer :: a
end type bar
contains
  subroutine do_nothing(self)
    class(foo) :: self
program test_pgi_construct
use test_types
implicit none
type(bar) :: x
x = bar(1)
print *, x%a
end program test_pgi_construct
  1. PGI 14.1 also gives a spurious warning in the following case, though the compiled code appears to work correctly:
program test_section_constructor
implicit none
type, abstract :: foo_base
end type foo_base
type, extends(foo_base) :: foo
   integer, allocatable :: a(:)
end type foo
type(foo) :: b
integer :: a1(2) = 0
integer :: a2(2,2) = 0
b = foo(a1)      ! OK
b = foo(a2(:,1)) ! Spurious warning
end program test_section_constructor
  1. Using a structure constructor for a type with a procedure pointer gives a spurious warning, but more importantly, calling the function bound to that pointer produces an ICE.
module int_getter
implicit none
contains
  integer function foo_int()
    foo_int = 0
  end function foo_int
end module int_getter
program test_function_constructor
use int_getter, only: foo_int
implicit none
abstract interface
   integer function get_int()
   end function get_int
end interface
type :: foo
   procedure(get_int), nopass, pointer :: get => null()
end type foo
type(foo) :: bar
bar = foo(foo_int) ! This gives a warning, but shouldn't.
bar%get => foo_int ! No warning (this is my current workaround for Intel)
print *, bar%get() ! Internal compiler error
end program test_function_constructor
  1. This is similar code to case (4), but it has a different problem; the apparently valid structure constructor is rejected outright. I think this is just an unimplemented feature?
module int_getter
implicit none
contains
  subroutine foo_int(a)
    integer, intent(out) :: a
    a = 0
  end subroutine foo_int
implicit none
abstract interface
   subroutine get_int(a)
   end subroutine get_int
end interface
type :: foo
end type foo
type(foo) :: bar
integer :: x
! This line is valid code, but is rejected.
bar = foo(foo_int)
bar%get => foo_int
call bar%get(x)
print *, x
The ICE in (4) goes away if you remove the default initialization (=> null()) in the type definition.
But here’s one more I found when testing workarounds for that one.
  1. Abstract interfaces defined before a type that they import cause an internal compiler error. NAG rejects this code as invalid unless the interface and type definition are traded, and this also fixes the PGI ICE.
module int_getter
implicit none
abstract interface
   integer function get_int(self)
     import :: foo
     class(foo) :: self
end interface
type :: foo
   procedure(get_int), pointer :: get
end type foo
Apparently, this is my day to find bugs.
  1. “Select type” seems to treat types beginning with the word “Record” specially:
program pgi_record
  type :: Recorder
     integer :: a
  end type Recorder
  class(Recorder), allocatable :: foo
  allocate(foo, source=Recorder(1))
  select type (foo)
  type is (Recorder)
     print *, "Hi!"
  end select
end program pgi_record
This yields the message:
PGF90-S-0034-Syntax error at or near RECORD (pgi_record.F90: 12)
  0 inform,   0 warnings,   1 severes, 0 fatal for pgi_record
Another couple:
  1. A generic binding to an abstract type, where the only specific binding it includes is deferred, can be erroneously rejected if there is no “contains” inside the module:
module int_getter
implicit none
 contains
   procedure(get_int), deferred :: get
   generic :: generic_get => get
end type foo
abstract interface
     import :: foo
     class(foo) :: self
end interface
! Uncommenting this makes the error go away.
!contains
  1. A recursive type (or a type which has a component of an ancestor class) can have issues with actions like allocating a component, or forwarding functions, if “save” is specified in the module where the type is defined.
Edit: This is on Linux on x86-64.
module foo_bar_types
implicit none
! Commenting this save gets rid of the linking error.
save
! This type doesn't have to be recursive. The same problem arises if the
! "child_foo" component is of a type that foo extends.
type :: foo
   class(foo), pointer :: child_foo
 contains
   procedure :: bar
end type foo
contains
recursive subroutine bar(self)
  class(foo) :: self
  call self%child_foo%bar()
end subroutine bar
end module foo_bar_types
program do_nothing
end program do_nothing
Hi Sean,
Thanks for all the reports. I am working to reproduce all of these here, and I will file reports on them. This is a big help for us - we really appreciate your feedback.
Best regards,
+chris
One other note: case #6 has been fixed as of 14.3, and PGI no longer produces an ICE. Now you get an error message:
cparrott@galaxy ~/UF $ pgf90 -c int_getter.f90
PGF90-S-0155-Cannot IMPORT foo (int_getter.f90: 7)
PGF90-S-0155-Derived type has not been declared - foo (int_getter.f90: 8)
0 inform, 0 warnings, 2 severes, 0 fatal for int_getter
Best regards,
+chris
Ah, thanks for the information.
TPR 20212 - linking error when recursive type specified in a module that uses “save”
Has been fixed in the current 14.6 release.
Thanks,
dave
TPR 20211 - “Generic binding to an abstract type erroneously rejected if there is no 'contains” inside’ the module" has been corrected in the 14.6 release.
Thanks,
dave
TPR 20207 - Apparently valid structure constructor is rejected outright by pgfortran
is fixed in the current 14.6 release.
Thnaks for your submission.
regards,
dave
TPR 20203 - “Potentially valid structure constructor rejected by pgfortran”
has been fixed in the current 14.6 release.
thanks,
dave
TPR 20202 - “Improper module triggers segfault in compiler instead of error message” has been fixed in the current 14.6 release.
Thanks for the original report.
dave
TPR 20567 - UF: F2003 code with abstract interface causes segv
which is one of several TPRs associated with this UF entry, has been fixed in the 14.7 release.
thanks,
dave
