The following code generates an internal compiler error with pgfortran 13.9:
module bound_op_mod
implicit none
type foo
integer :: n
contains
procedure, pass(f1) :: sum_this => sum_foo
generic, public :: operator(+) => sum_this
end type foo
contains
function sum_foo(f1, f2) result(new_f)
class(foo), intent(in) :: f1, f2
type(foo) :: new_f
new_f = foo(f1%n + f2%n)
end function sum_foo
end module bound_op_mod
program test_bound_operator
use bound_op_mod, only: foo
implicit none
type(foo) :: f
f = foo(1) + foo(2)
print *, f
end program test_bound_operator
The error messages are:
PGF90-S-0000-Internal compiler error. mkexpr1: bad id 14 (pgi_internal_error.F90: 9)
PGF90-S-0000-Internal compiler error. sym_of_ast: unexpected ast 0 (pgi_internal_error.F90: 9)
PGF90-S-0155-Type bound procedure must be a module procedure or an external procedure with an explicit interface - (pgi_internal_error.F90: 9)
(“pgi_internal_error.F90” was the name of the file I put this test case in.)
On one machine with PGI 13.9, the compiler hangs after this point. On another machine with 13.7, it manages to error out without hanging. I have (much more complex) code that successfully uses type-bound operators with PGI 13.7, so it’s not at all clear to me what the issue is in this simple case.
