Thank you for your prompt reply. But I have another problem. I now use the pgfortran 11.8 to compile the code.
mod_a.f90
module a
type :: a
real, dimension(:,:,:), allocatable :: v
contains
procedure, pass(this) :: alloc => a_alloc
procedure, pass(this) :: init => a_init
end type
contains
subroutine a_alloc(this)
class(a) :: this
allocate(this%v(10, 10, 10))
end subroutine a_alloc
subroutine a_init(this)
class(a) :: this
this%v = 1.0
end subroutine a_init
end module a
mod_b.f90
module b
use a
implicit none
type :: b
type(a), dimension(:), allocatable :: as
contains
procedure, pass(this) :: alloc => b_alloc
procedure, pass(this) :: init => b_init
end type
contains
subroutine b_alloc(this)
class(b) :: this
integer :: i
allocate(this%as(10))
do i = 1, 10
call this%as(i)%alloc()
end do
end subroutine b_alloc
subroutine b_init(this)
class(b) :: this
integer :: i
do i = 1, 10
call this%as(i)%init()
end do
end subroutine b_init
end module b
test.f90
program test
use a
use b
type(b) :: bb
call bb%alloc()
call bb%init()
end program test
The test program compiled sucessfully, but it causes segment fault when running.
Using pgdebug to debug the code
pgdbg> r
libm.so.6 loaded by ld-linux-x86-64.so.2.
libpthread.so.0 loaded by ld-linux-x86-64.so.2.
librt.so.1 loaded by ld-linux-x86-64.so.2.
libc.so.6 loaded by ld-linux-x86-64.so.2.
Signalled SIGSEGV at 0x4027F2, function b_init, file mod_b.f90, line 27
0x4027F2: 48 63 9 movslq (%rcx),%rcx
pgdbg> list
#22: subroutine b_init(this)
#23: class(b) :: this
#24:
#25: integer :: i
#26: do i = 1, 10
#27:==>> call this%as(i)%init()
#28: end do
#29: end subroutine b_init
#30:
#31: end module b
pgdbg> print this
as = ERROR: NO TYPE for as
as$td = ( integer*4 (1:18), pointer) 0x649770
.fake = 0
.fake = 0
pgdbg> print this%as
Why does ‘as’ have no type and why its value cannot be printed?
Then I modified test.f90 to do all work through it’s member ‘as’ instead of through the type bound procedure of ‘b’, then the program run successfully.
program test
use a
use b
type(b) :: bb
integer :: i
allocate(bb%as(10))
do i = 1, 10
call bb%as(i)%alloc()
call bb%as(i)%init()
end do
end program test
and I can print the ‘as’ of bb
pgdbg> p bb
as = ( type(a) (-1395399808:0), pointer) 0x0
.fake = 0
.fake = 0
It seems when calling type bound procedure of ‘b’, the ‘this’ is failed to pass to the procedure. However, the ‘this’ to ‘a’ is sucessfully passed to type bound procedure of ‘a’.
