I believe the code below is valid and GNU, Intel and NAG seem to agree.
module pg_test
type point
real(kind=8) :: coo(3) = [0.0d0,0.0d0,0.0d0]
end type point
type, extends(point) :: waypoint
integer :: cnt
end type waypoint
contains
subroutine filament_init( points_in)
implicit none
class(point), intent(in) :: points_in(:)
class(point), allocatable :: points(:)
allocate(points(size(points_in)),source=points_in)
print *, points(1)%coo(1)
select type (points)
type is (waypoint)
print *, 'type is waypoint'
class default
print *, points_in(1)%coo(1)
end select
end subroutine filament_init
end module pg_test
program test
print *, 'hello'
end program test
But pgfortran 13.7 throws the following severe at compile time:
PGF90-S-0076-Subscripts specified for non-array variable points (test.f90: 23)
Version information:
$ pgfortran --version
pgfortran 13.7-0 64-bit target on x86-64 Linux -tp sandybridge
Let me know if you need more information to reproduce
