The following test program compiles with pgfortran 11.3.0 64.bit, but segfaults somewhere around the return from function initallocarray. Using a subroutine instead of the function would solve the issue, but unfortunately is not an option in our code.
Additionally, using gfortran 4.4+ and ifort 11.0+ the code compiles and runs without segfaulting.
program test
type allocptr
integer, pointer :: this => null()
end type allocptr
type allocarray
type(allocptr), allocatable, dimension(:) :: terms
end type allocarray
type(allocarray) :: a
a = initallocarray(10)
contains
type(allocarray) function initallocarray(dim)
integer, intent(in) :: dim
allocate(initallocarray%terms(dim))
end function initallocarray
end program
Compiler:
$ pgfortran -V
pgfortran 11.3-0 64-bit target on x86-64 Linux -tp shanghai
Architecture:
Linux hopper07 2.6.27.48-0.12-default #1 SMP 2010-09-20 11:03:26 -0400 x86_64 x86_64 x86_64 GNU/Linux
Any help would be greatly appreciated! Thanks in advance!
