It appears I am receiving an internal compiler error when using a user defined operator with the incorrect type.
I am receiving the following error when compiling with pgfortran (versions 14.2 and 14.6). I am only using the ‘-c’ flag. The error also occurs when compiling in debug mode (‘-g’ flag).
ILM FILE line 146: Bad ilm operand 0
PGF90-F-0000-Internal compiler error. Errors in ILM file 1 (main.f90: 19)
!operator.f90
module operator
implicit none
interface operator (.match.)
module procedure is_match
end interface
contains
function is_match(a,b) result(match)
real, intent(in) :: a, b
logical :: match
if (a == b) match =.true.
end function
end module
!main.f90
program main
use operator
implicit none
real :: a,b
double precision :: c, d
a = 2.0
b = 3.0
if (a .match. b) print *, 'A and B Match'
c = 2d0
d = 2d0
if (c .match. d) print *, 'C and D Match'
end program
The compiler error occurs when the following line is included. When this line is commented out, the error does not appear. You can see that the .match. operator is being used incorrectly since i am applying it to two double precision variables. The operator is expecting two real values. I expect that the compiler should catch this error.
if (c .match. d) print *, ‘C and D Match’
