• Hardware Platform (Jetson / GPU) Jetson Tx2 • DeepStream Version 5.1 • JetPack Version (valid for Jetson only) 4.5.1 • TensorRT Version 7.1.3 • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
Hi, Currently i have a trained object detection yolov4 model (ver 3.0) and i am able to deploy into deepstream (python). I am able to do a live recording using the tx2 onboard camera (CSI) and saving the output inferenced image with reference to deepstream-imagedata-multistream-redaction.
Question: I realise there are a lot of frames dropped as the framerate resolution i set was (framerate = 30/1) while the average fps timing was 6fps. I was wondering if there is any way to solve this issue? I tried boosting the device using the jetson_clock etc/ setting the streamux batched-pushout-time to -1 (max) but the average fps still remain at ~6. is there anyway to prevent this frame dropping issue? Here is my code, configuration settings, weights etc yolov4_resnet18_epoch_096_fp16.etlt_b1_gpu0_fp16.engine (12.1 MB) yolov4_labels.txt (7 Bytes) pgie_yolov4_tlt_config.txt (2.1 KB) deepstream_yolov4_drone_usb_v4.py (16.6 KB)
Hi @AastaLLL , i dont have to run the inference on every frames, all i want is to have all 30 frames in one sec, having 6 of them being inferenced. i try setting the value of interval to be 24 (because 30 - 6 = 24) however, im still getting 5 frames per second and worst of all, 1/25 frames is being annotated after 3 seconds. Is there any other solution?
Hi, from my understanding, the tracker plugin helps to give a specific id the detected object respectively am i right? So how does the tracker plugin helps with the frame rate issue? Anyways. i managed to solve the issue by remove the portion where i save the predicted frames. After removing that portion, my fps increase from 6fps to 23fps
