Hello, I upgraded my GPU to an NVIDIA GeForce 4070. I have true the nvidia-driver-525 and nvidia-driver-535 driver packages from Ubuntu. On versions of Ubuntu from 20.04 to the most recent.
The issue is that no matter the Desktop Environment. What I find is if my system locks and I unlock it. The gui will freeze for 30 seconds to 5 minutes and then it’ll come back fine. This issue doesn’t exist in Windows 10 or when I use the nouveau driver.
Now I work in Linux as my career. So I have tried to really dig in. But I get nothing. There’s no logs or any indication that it’s happening. atleast to my eyes.
I never had this issue before and it’s making things a real pain.
any ideas are appreciated.
I currently do use the gnome-session-flashback environment. But i’ve tried others and have the same issue.
This is a new build with a new psu too.
nvidia-bug-report.log.gz (760.8 KB)
I do get a ton of errors like so in my logs.
1812:2023-12-24T23:23:42.612129-05:00 burri kernel: [88404.294694] [drm:nv_drm_master_set [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
dmesg
dmesg.0
1230:[ 5.735978] kernel: nvidia: loading out-of-tree module taints kernel.
1231:[ 5.735984] kernel: nvidia: module license 'NVIDIA' taints kernel.
1233:[ 5.735986] kernel: nvidia: module license taints kernel.
1236:[ 5.887772] kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 510
1239:[ 5.888643] kernel: nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
1253:[ 5.927390] kernel: input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input15
1254:[ 5.927413] kernel: input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input16
1255:[ 5.927430] kernel: input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input17
1256:[ 5.927444] kernel: input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input18
1257:[ 5.931630] kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 535.129.03 Thu Oct 19 18:56:32 UTC 2023
1262:[ 5.946452] kernel: nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 535.129.03 Thu Oct 19 18:42:12 UTC 2023
1263:[ 5.953244] kernel: [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
1286:[ 7.006148] kernel: [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 1
1287:[ 7.040355] kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
1288:[ 7.063650] kernel: nvidia-uvm: Loaded the UVM driver, major device number 508.
There’s also this
kern.log
4821:2023-12-28T18:49:38.641975-05:00 burri kernel: [189291.294523] NVRM: Xid (PCI:0000:01:00): 68, pid=156402, name=av:h264:df0, CCMDs 0000000a 0000c9b0
syslog
25200:2023-12-28T18:49:38.641975-05:00 burri kernel: [189291.294523] NVRM: Xid (PCI:0000:01:00): 68, pid=156402, name=av:h264:df0, CCMDs 0000000a 0000c9b0
kern.log.1
335:Dec 17 01:24:33 burri kernel: [440008.127812] NVRM: Xid (PCI:0000:01:00): 68, pid=736413, name=vlc, CCMDs 0000002f 0000c9b0
1102:Dec 17 22:52:20 burri kernel: [517274.301303] NVRM: Xid (PCI:0000:01:00): 68, pid=741003, name=vlc, CCMDs 0000002a 0000c9b0
syslog.1
789:Dec 17 01:24:33 burri kernel: [440008.127812] NVRM: Xid (PCI:0000:01:00): 68, pid=736413, name=vlc, CCMDs 0000002f 0000c9b0
3857:Dec 17 22:52:20 burri kernel: [517274.301303] NVRM: Xid (PCI:0000:01:00): 68, pid=741003, name=vlc, CCMDs 0000002a 0000c9b0
These are from a week or more ago and I am still getting issue. I believe these have occured when I had VLC open on my 2nd righthand screen and it froze.
also wondering if this could be related
Hi all,
I’m experiencing random frozen screen in my system with :
Ubuntu 22.04
Kernel 5.15.0-47-generic
Nvidia driver 515.86.01
Moreover, I see the following errors in my dmesg:
[ 18.293664] [drm:nv_drm_master_set [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
[ 61.661549] audit: type=1107 audit(1677333008.480:105): pid=970 uid=103 auid=4294967295 ses=4294967295 subj=? msg='apparmor=“DENIED” operation=“dbus_bind” bus=“system” name=“nvidia.powerd.cl…
Does anybody have any ideas, still facing the issue.
Did you check with the 550 driver meanwhile?
