Ubuntu 23.10 hangs when waking up.
Hi there,
Please check out »»»»»»»»»» If you have a problem, PLEASE read this first ««««««««««
and provide a bit more details, including the bug report log.
nvidia-bug-report.log.gz (363.1 KB)
nvidia-bug-report.log.gz (352.7 KB)
I have trouble waking up the system after suspend. I’ve tried many of the options / solutions provided to no effect.
The nvidia-smi info:
Sun Dec 31 20:32:15 2023
| NVIDIA-SMI 535.129.03 Driver Version: 535.129.03 CUDA Version: 12.2 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 3050 … Off | 00000000:01:00.0 Off | N/A |
| N/A 42C P8 7W / 60W | 220MiB / 4096MiB | 26% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1801 G /usr/lib/xorg/Xorg 128MiB |
| 0 N/A N/A 4243 G /usr/bin/gnome-shell 50MiB |
| 0 N/A N/A 5235 G /usr/libexec/xdg-desktop-portal-gnome 29MiB |
| 0 N/A N/A 5744 G …ures=SpareRendererForSitePerProcess 2MiB |
and the Unix system details:
Linux awesomesystem 6.5.0-14-generic #14-Ubuntu SMP PREEMPT_DYNAMIC Tue Nov 14 14:59:49 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
CPU: 6 PID: 2157 Comm: rustdesk Tainted: P W O 6.5.0-14-generic #14-Ubuntu
Hardware name: HP Victus by HP Gaming Laptop 15-fa0xxx/8A4F, BIOS F.23 08/25/2023
Not sure if this helps, but I keep seeing similar messages in dmesg:
[ 5.232811] ================================================================================
[ 5.232825] ================================================================================
[ 5.232826] UBSAN: array-index-out-of-bounds in build/nvidia/535.129.03/build/nvidia-uvm/uvm_mmu.c:555:51
[ 5.232827] index 16 is out of range for type ‘uvm_page_directory_t []’
Hello @nvidia2647, welcome to the NVIDIA developer forums.
The warning message is harmless and will be fixed in a future driver release, see also this thread: UBSAN: array-index-out-of-bounds complaints in newer kernels
As for the system not waking up you might want to use sudo prime-select nvidia to set the Laptop into performance mode, or check that nvidia-persistenced is up and running, which might not be the case, looking at your output of nvidia-smi
@KHTeh sorry for the delay, but I am still missing information.
Does this happen on every boot?
Is it a new occurrence or did it work at some point?
Does it happen if you don’t have external monitors connected to your laptop?
First things to try are the same as what I wrote above. Then make sure you have a working Xorg configuration especially when connecting external displays.
Hi @MarkusHoHo
Happy New Year!! Thanks for the reply and suggestions. I am going to try these out shortly.
Does this happen on every boot? Only when waking up from Suspend mode. Booting works fine.
Is it a new occurrence or did it work at some point? Never worked - seems to be issue on NVIDIA and Ubuntu, purchased another ASUS laptop and it too has same resume-from-suspend issue.
Does it happen if you don’t have external monitors connected to your laptop? Happens either way.
Here is the syslog I see after booting afresh.
2024-01-08T07:07:23.721954+05:30 awesomesystem nvidia-persistenced: Received signal 15
2024-01-08T07:07:23.722239+05:30 awesomesystem systemd[1]: Stopping nvidia-persistenced.service - NVIDIA Persistence Daemon...
2024-01-08T07:07:48.175111+05:30 awesomesystem systemd[1]: Starting nvidia-persistenced.service - NVIDIA Persistence Daemon...
2024-01-08T07:07:48.175113+05:30 awesomesystem nvidia-persistenced: Verbose syslog connection opened
2024-01-08T07:07:48.175116+05:30 awesomesystem nvidia-persistenced: Now running with user ID 133 and group ID 143
2024-01-08T07:07:48.175118+05:30 awesomesystem nvidia-persistenced: Started (1174)
2024-01-08T07:07:48.175131+05:30 awesomesystem nvidia-persistenced: device 0000:01:00.0 - registered
2024-01-08T07:07:48.175134+05:30 awesomesystem nvidia-persistenced: Local RPC services initialized
2024-01-08T07:07:48.175136+05:30 awesomesystem systemd[1]: Started nvidia-persistenced.service - NVIDIA Persistence Daemon.
2024-01-08T07:07:48.174828+05:30 awesomesystem kernel: [ 2.064835] nvidia: loading out-of-tree module taints kernel.
2024-01-08T07:07:48.175483+05:30 awesomesystem kernel: [ 2.064846] nvidia: module license 'NVIDIA' taints kernel.
2024-01-08T07:07:48.175488+05:30 awesomesystem kernel: [ 2.064850] nvidia: module license taints kernel.
2024-01-08T07:07:48.175491+05:30 awesomesystem kernel: [ 2.136827] nvidia-nvlink: Nvlink Core is being initialized, major device number 510
2024-01-08T07:07:48.175492+05:30 awesomesystem kernel: [ 2.137751] nvidia 0000:01:00.0: enabling device (0000 -> 0003)
2024-01-08T07:07:48.175492+05:30 awesomesystem kernel: [ 2.137935] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
2024-01-08T07:07:48.175519+05:30 awesomesystem kernel: [ 2.198306] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 535.129.03 Thu Oct 19 18:42:12 UTC 2023
2024-01-08T07:07:48.175527+05:30 awesomesystem kernel: [ 2.223651] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
2024-01-08T07:07:48.175574+05:30 awesomesystem kernel: [ 3.067535] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 1
2024-01-08T07:07:48.175579+05:30 awesomesystem kernel: [ 3.243530] Modules linked in: binfmt_misc nls_iso8859_1 snd_soc_dmic snd_sof_pci_intel_tgl intel_uncore_frequency snd_sof_intel_hda_common intel_uncore_frequency_common soundwire_intel snd_sof_intel_hda_mlink soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi btusb soundwire_generic_allocation uvcvideo btrtl soundwire_bus videobuf2_vmalloc nvidia_drm(PO) btbcm uvc btintel snd_soc_core videobuf2_memops btmtk x86_pkg_temp_thermal videobuf2_v4l2 snd_compress nvidia_modeset(PO) intel_powerclamp ac97_bus snd_hda_codec_hdmi videodev bluetooth snd_pcm_dmaengine kvm_intel videobuf2_common snd_hda_intel ecdh_generic ecc nvidia(PO) mc usbhid snd_intel_dspcfg snd_intel_sdw_acpi kvm i915(+) snd_hda_codec irqbypass snd_hda_core crct10dif_pclmul mt7921e snd_hwdep polyval_clmulni mt7921_common snd_pcm polyval_generic joydev mt76_connac_lib snd_seq_midi drm_buddy ghash_clmulni_intel cmdlinepart snd_seq_midi_event mt76 ttm
2024-01-08T07:07:48.175659+05:30 awesomesystem kernel: [ 3.298383] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
2024-01-08T07:07:48.175660+05:30 awesomesystem kernel: [ 3.322269] nvidia-uvm: Loaded the UVM driver, major device number 507.
root@awesomesystem:~# nvidia-smi
Mon Jan 8 07:17:07 2024
| | | MIG M. |
| 0 NVIDIA GeForce RTX 3050 ... Off | 00000000:01:00.0 Off | N/A |
| N/A 38C P5 7W / 60W | 546MiB / 4096MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1829 G /usr/lib/xorg/Xorg 201MiB |
| 0 N/A N/A 3054 G /usr/bin/gnome-shell 143MiB |
| 0 N/A N/A 3929 G /usr/bin/nautilus 9MiB |
| 0 N/A N/A 4017 G ...ures=SpareRendererForSitePerProcess 2MiB |
| 0 N/A N/A 4217 G ...47,262144 --variations-seed-version 78MiB |
| 0 N/A N/A 4541 G ...sion,SpareRendererForSitePerProcess 32MiB |
| 0 N/A N/A 4818 G ...ures=SpareRendererForSitePerProcess 63MiB |
@nvidia2647 The questions were rather aimed at the OP, but good information in any case.
the persistence mode still seems configured incorrectly, check out the documentation please and try to (force) enable it.
Did you try prime-select yet? Also disabling integrated graphics in the BIOS might help.
Another option would be to try a newer driver to see if tat makes a difference.
Thanks for the reply.
Yes - I did try prime-selet as the first thing, and again now.
root@awesomesystem:~# prime-select nvidia
Info: selecting the nvidia profile
Deleting /lib/modprobe.d/nvidia-runtimepm.conf
Updating the initramfs. Please wait for the operation to complete:
Done
Wed Jan 10 08:14:27 2024
| | | MIG M. |
| N/A 43C P8 8W / 60W | 414MiB / 4096MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1866 G /usr/lib/xorg/Xorg 176MiB |
| 0 N/A N/A 3124 G /usr/bin/gnome-shell 141MiB |
| 0 N/A N/A 4069 G ...ures=SpareRendererForSitePerProcess 2MiB |
| 0 N/A N/A 4201 G ...79,262144 --variations-seed-version 73MiB |
| 0 N/A N/A 4580 G ...ures=SpareRendererForSitePerProcess 9MiB |
root@awesomesystem
I am reading the documentation and will try to get this working.
Isn’t this the latest driver? I’ll check that too and update.
