I’ve upgraded from Ubuntu 17.10 to 18.04 and as part of that the nvidia driver got upgraded at some point.
Running nvidia-driver-390 if I attempt to enter sleep, the laptop appears to go to sleep, lights go off, fan stops etc, but after a few seconds it wakes back up.
I’ve tried a handful of changes but so far uninstalling the 390 driver and using either the nouveau or nvidia-340 seems to be the variable that allows the laptop to sleep correctly.
lspci reports the card as:
01:00.0 VGA compatible controller: NVIDIA Corporation GK107M [GeForce GT 750M Mac Edition] (rev a1)
A failed attempt at suspending (with nvidia-driver-390) logs this in dmesg:
[ 516.968380] PM: suspend entry (deep)
[ 516.968382] PM: Syncing filesystems ... done.
[ 518.796981] Freezing user space processes ... (elapsed 0.001 seconds) done.
[ 518.798587] OOM killer disabled.
[ 518.798587] Freezing remaining freezable tasks ... (elapsed 0.000 seconds) done.
[ 518.799556] Suspending console(s) (use no_console_suspend to debug)
[ 518.806484] ERROR @wl_notify_scan_status :
[ 518.806485] wlp3s0 Scan_results error (-22)
[ 518.851496] sd 1:0:0:0: [sda] Synchronizing SCSI cache
[ 518.852112] sd 1:0:0:0: [sda] Stopping disk
[ 518.864464] thunderbolt 0000:08:00.0: suspending...
[ 518.865782] thunderbolt 0000:08:00.0: suspend finished
[ 518.865785] thunderbolt 0000:08:00.0: stopping RX ring 0
[ 518.865795] thunderbolt 0000:08:00.0: disabling interrupt at register 0x38200 bit 12 (0x1001 -> 0x1)
[ 518.865810] thunderbolt 0000:08:00.0: stopping TX ring 0
[ 518.865819] thunderbolt 0000:08:00.0: disabling interrupt at register 0x38200 bit 0 (0x1 -> 0x0)
[ 518.865833] thunderbolt 0000:08:00.0: control channel stopped
[ 519.817386] ACPI: Preparing to enter system sleep state S3
[ 519.879437] ACPI: EC: event blocked
[ 519.879438] ACPI: EC: EC stopped
[ 519.879439] PM: Saving platform NVS memory
[ 519.879445] Disabling non-boot CPUs ...
[ 519.914047] smpboot: CPU 1 is now offline
[ 519.928683] smpboot: CPU 2 is now offline
[ 519.953802] smpboot: CPU 3 is now offline
[ 519.998174] smpboot: CPU 4 is now offline
[ 520.015573] IRQ 18: no longer affine to CPU5
[ 520.015577] IRQ 28: no longer affine to CPU5
[ 520.016893] smpboot: CPU 5 is now offline
[ 520.039652] IRQ 32: no longer affine to CPU6
[ 520.039655] IRQ 33: no longer affine to CPU6
[ 520.040670] smpboot: CPU 6 is now offline
[ 520.063838] IRQ 26: no longer affine to CPU7
[ 520.063847] IRQ 29: no longer affine to CPU7
[ 520.063863] IRQ 51: no longer affine to CPU7
[ 520.064876] smpboot: CPU 7 is now offline
[ 520.096639] ACPI: Low-level resume complete
[ 520.096709] ACPI: EC: EC started
[ 520.096710] PM: Restoring platform NVS memory
[ 520.104919] Enabling non-boot CPUs ...
[ 520.104983] x86: Booting SMP configuration:
[ 520.104985] smpboot: Booting Node 0 Processor 1 APIC 0x2
[ 520.227925] cache: parent cpu1 should not be sleeping
[ 520.410390] CPU1 is up
[ 520.410441] smpboot: Booting Node 0 Processor 2 APIC 0x4
[ 520.513934] cache: parent cpu2 should not be sleeping
[ 520.685043] CPU2 is up
[ 520.685098] smpboot: Booting Node 0 Processor 3 APIC 0x6
[ 520.779254] cache: parent cpu3 should not be sleeping
[ 520.943954] CPU3 is up
[ 520.944064] smpboot: Booting Node 0 Processor 4 APIC 0x1
[ 520.949092] cache: parent cpu4 should not be sleeping
[ 520.949302] CPU4 is up
[ 520.949335] smpboot: Booting Node 0 Processor 5 APIC 0x3
[ 521.032369] cache: parent cpu5 should not be sleeping
[ 521.228333] CPU5 is up
[ 521.228367] smpboot: Booting Node 0 Processor 6 APIC 0x5
[ 521.313982] cache: parent cpu6 should not be sleeping
[ 521.539392] CPU6 is up
[ 521.539430] smpboot: Booting Node 0 Processor 7 APIC 0x7
[ 521.627670] cache: parent cpu7 should not be sleeping
[ 521.881188] CPU7 is up
[ 521.955200] ACPI: Waking up from system sleep state S3
[ 522.066579] pcieport 0000:07:03.0: quirk: waiting for thunderbolt to reestablish PCI tunnels...
[ 522.066584] pcieport 0000:07:06.0: quirk: waiting for thunderbolt to reestablish PCI tunnels...
[ 522.066587] pcieport 0000:07:04.0: quirk: waiting for thunderbolt to reestablish PCI tunnels...
[ 522.066588] pcieport 0000:07:05.0: quirk: waiting for thunderbolt to reestablish PCI tunnels...
[ 522.086049] thunderbolt 0000:08:00.0: control channel starting...
[ 522.086052] thunderbolt 0000:08:00.0: starting TX ring 0
[ 522.086074] thunderbolt 0000:08:00.0: enabling interrupt at register 0x38200 bit 0 (0x0 -> 0x1)
[ 522.086075] thunderbolt 0000:08:00.0: starting RX ring 0
[ 522.086095] thunderbolt 0000:08:00.0: enabling interrupt at register 0x38200 bit 12 (0x1 -> 0x1001)
[ 522.086099] thunderbolt 0000:08:00.0: resuming...
[ 522.086101] thunderbolt 0000:08:00.0: resetting switch at 0
[ 522.094326] thunderbolt 0000:08:00.0: 0: resuming switch
[ 522.095148] thunderbolt 0000:08:00.0: resume finished
[ 522.146573] ACPI: EC: event unblocked
[ 522.156867] sd 1:0:0:0: [sda] Starting disk
[ 522.187542] thunderbolt 0000:08:00.0: resetting error on 0:b.
[ 522.187562] thunderbolt 0000:08:00.0: 0:b: hotplug: scanning
[ 522.187563] thunderbolt 0000:08:00.0: 0:b: hotplug: no switch found
[ 522.187670] thunderbolt 0000:08:00.0: resetting error on 0:c.
[ 522.187687] thunderbolt 0000:08:00.0: 0:c: hotplug: scanning
[ 522.187688] thunderbolt 0000:08:00.0: 0:c: hotplug: no switch found
[ 522.473159] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 522.473445] ata1.00: unexpected _GTF length (8)
[ 522.473869] ata1.00: unexpected _GTF length (8)
[ 522.473961] ata1.00: configured for UDMA/133
[ 525.653231] pciehp 0000:00:1c.0:pcie004: link training error: status 0x1001
[ 525.653234] pciehp 0000:00:1c.0:pcie004: Failed to check link status
[ 525.654073] OOM killer enabled.
[ 525.654074] Restarting tasks ... done.
[ 525.725513] video LNXVIDEO:00: Restoring backlight state
[ 525.725547] PM: suspend exit
A working attempt logs (using nvidia-340):
[ 305.193844] PM: suspend entry (deep)
[ 305.193846] PM: Syncing filesystems ... done.
[ 306.372254] Freezing user space processes ... (elapsed 0.001 seconds) done.
[ 306.373868] OOM killer disabled.
[ 306.373869] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[ 306.375076] Suspending console(s) (use no_console_suspend to debug)
[ 306.382722] ERROR @wl_notify_scan_status :
[ 306.382724] wlp3s0 Scan_results error (-22)
[ 306.451873] sd 1:0:0:0: [sda] Synchronizing SCSI cache
[ 306.452535] sd 1:0:0:0: [sda] Stopping disk
[ 306.455906] thunderbolt 0000:08:00.0: suspending...
[ 306.458025] thunderbolt 0000:08:00.0: suspend finished
[ 306.458027] thunderbolt 0000:08:00.0: stopping RX ring 0
[ 306.458031] thunderbolt 0000:08:00.0: disabling interrupt at register 0x38200 bit 12 (0x1001 -> 0x1)
[ 306.458038] thunderbolt 0000:08:00.0: stopping TX ring 0
[ 306.458042] thunderbolt 0000:08:00.0: disabling interrupt at register 0x38200 bit 0 (0x1 -> 0x0)
[ 306.458049] thunderbolt 0000:08:00.0: control channel stopped
[ 307.404274] ACPI: Preparing to enter system sleep state S3
[ 307.468334] ACPI: EC: event blocked
[ 307.468335] ACPI: EC: EC stopped
[ 307.468336] PM: Saving platform NVS memory
[ 307.468340] Disabling non-boot CPUs ...
[ 307.486402] smpboot: CPU 1 is now offline
[ 307.510612] smpboot: CPU 2 is now offline
[ 307.551089] smpboot: CPU 3 is now offline
[ 307.575401] smpboot: CPU 4 is now offline
[ 307.594596] smpboot: CPU 5 is now offline
[ 307.618809] smpboot: CPU 6 is now offline
[ 307.649968] smpboot: CPU 7 is now offline
[ 307.684138] ACPI: Low-level resume complete
[ 307.684205] ACPI: EC: EC started
[ 307.684206] PM: Restoring platform NVS memory
[ 307.692402] Enabling non-boot CPUs ...
[ 307.692520] x86: Booting SMP configuration:
[ 307.692522] smpboot: Booting Node 0 Processor 1 APIC 0x2
[ 307.812138] cache: parent cpu1 should not be sleeping
[ 307.993154] CPU1 is up
[ 307.993202] smpboot: Booting Node 0 Processor 2 APIC 0x4
[ 308.096938] cache: parent cpu2 should not be sleeping
[ 308.268205] CPU2 is up
[ 308.268267] smpboot: Booting Node 0 Processor 3 APIC 0x6
[ 308.362847] cache: parent cpu3 should not be sleeping
[ 308.526992] CPU3 is up
[ 308.527049] smpboot: Booting Node 0 Processor 4 APIC 0x1
[ 308.532160] cache: parent cpu4 should not be sleeping
[ 308.532371] CPU4 is up
[ 308.532405] smpboot: Booting Node 0 Processor 5 APIC 0x3
[ 308.616315] cache: parent cpu5 should not be sleeping
[ 308.811871] CPU5 is up
[ 308.811906] smpboot: Booting Node 0 Processor 6 APIC 0x5
[ 308.894973] cache: parent cpu6 should not be sleeping
[ 309.115809] CPU6 is up
[ 309.115845] smpboot: Booting Node 0 Processor 7 APIC 0x7
[ 309.203587] cache: parent cpu7 should not be sleeping
[ 309.456945] CPU7 is up
[ 309.530960] ACPI: Waking up from system sleep state S3
[ 309.643015] pcieport 0000:07:03.0: quirk: waiting for thunderbolt to reestablish PCI tunnels...
[ 309.643017] pcieport 0000:07:06.0: quirk: waiting for thunderbolt to reestablish PCI tunnels...
[ 309.643019] pcieport 0000:07:04.0: quirk: waiting for thunderbolt to reestablish PCI tunnels...
[ 309.643020] pcieport 0000:07:05.0: quirk: waiting for thunderbolt to reestablish PCI tunnels...
[ 309.662424] thunderbolt 0000:08:00.0: control channel starting...
[ 309.662430] thunderbolt 0000:08:00.0: starting TX ring 0
[ 309.662448] thunderbolt 0000:08:00.0: enabling interrupt at register 0x38200 bit 0 (0x0 -> 0x1)
[ 309.662450] thunderbolt 0000:08:00.0: starting RX ring 0
[ 309.662470] thunderbolt 0000:08:00.0: enabling interrupt at register 0x38200 bit 12 (0x1 -> 0x1001)
[ 309.662473] thunderbolt 0000:08:00.0: resuming...
[ 309.662474] thunderbolt 0000:08:00.0: resetting switch at 0
[ 309.669950] thunderbolt 0000:08:00.0: 0: resuming switch
[ 309.670773] thunderbolt 0000:08:00.0: resume finished
[ 309.723086] ACPI: EC: event unblocked
[ 309.736281] sd 1:0:0:0: [sda] Starting disk
[ 309.772535] thunderbolt 0000:08:00.0: resetting error on 0:b.
[ 309.772546] thunderbolt 0000:08:00.0: resetting error on 0:c.
[ 309.772867] thunderbolt 0000:08:00.0: 0:b: hotplug: scanning
[ 309.772937] thunderbolt 0000:08:00.0: 0:b: hotplug: no switch found
[ 309.772939] thunderbolt 0000:08:00.0: 0:c: hotplug: scanning
[ 309.772940] thunderbolt 0000:08:00.0: 0:c: hotplug: no switch found
[ 310.054313] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 310.054704] ata1.00: unexpected _GTF length (8)
[ 310.055293] ata1.00: unexpected _GTF length (8)
[ 310.055442] ata1.00: configured for UDMA/133
[ 313.235957] pciehp 0000:00:1c.0:pcie004: link training error: status 0x1001
[ 313.235961] pciehp 0000:00:1c.0:pcie004: Failed to check link status
[ 313.240422] OOM killer enabled.
[ 313.240423] Restarting tasks ... done.
[ 313.300538] PM: suspend exit
The “no longer affline” lines are the only thing that jumps out to me:
but I don’t know what they mean.
Any suggestions on how I can get a newer nvidia driver running would be appreciated as it seemed to run cooler with 390 than 340.
