I am looking to see if there a documentation repro that has everything related to the Jetson AGX developers kit as a one source, single download. Many of the docs I’m seeing are html which requires many downloads instead of just a PDF file. I am doing development in an air gapped environment.
Yeah, I get you, trying to find documentation for the NVIDIA Jetson devices could be daunting at times. However, the platform is composed of so many parts it actually requires layers and layers of documentation so one doesn’t get lost.
I would suggest you go and look around NVIDIA Jetson’s Download Center, where you should be able to get PDF’s on almost everything Jetson related.
Must haves in our experience are:
SOM and Carrier board data-sheet
Pinmux
Development Guides
Surely this will depend on what you are currently working on.
Hope this helps.
Now, out of curiosity, would it be Posible for you to share a bit more details on project? We might be able to suggest some other pieces of documentation that could help you in your journey.
best regards,
Andrew
