GB200 vs H200 NVL: cuMemCreate(1 GiB) is ~80–90 ms vs ~0.08–0.13 ms — expected on GB200?
TL;DR
On GB200 (GB200 NVL72), cuMemCreate takes ~88–89 ms for a 1 GiB VMM allocation, while on H200 NVL it’s ~0.08–0.13 ms under similar conditions. Repro code and Nsight Systems excerpts below.
I’d like to confirm whether this is expected on GB200 (e.g., architectural/firmware behavior), a known issue, or if there are recommended props/flags to reduce cuMemCreate latency.
Testbeds
GB200 (part of GB200 NVL72)
Tried multiple driver/CUDA combos; results are similar.
NVIDIA-SMI version  : 570.133.20
NVML version        : 570.133
DRIVER version      : 570.133.20
CUDA Version        : 12.8
NVCC Version        : cuda_12.8.r12.8/compiler.35404655_0
NVIDIA-SMI version  : 570.158.01
NVML version        : 570.158
DRIVER version      : 570.158.01
CUDA Version        : 12.8
NVIDIA-SMI version  : 580.95.05
NVML version        : 580.95
DRIVER version      : 580.95.05
CUDA Version        : 13.0
NVCC Version        : cuda_13.0.r13.0/compiler.36424714_0
H200 NVL
NVIDIA-SMI version  : 575.57.08
NVML version        : 575.57
DRIVER version      : 575.57.08
CUDA Version        : 12.9
NVCC Version        : cuda_12.4.r12.4/compiler.34097967_0
I also test RTX4090, cuMemCreate(1 GiB) is sub-ms (similar to H200) in my tests.
Reproduction
Code
memory_bench.cu
#include <cuda.h>
#include <cuda_profiler_api.h>
#include <cuda_runtime.h>
#include <algorithm>
#include <chrono>
#include <cstring>
#include <iomanip>
#include <iostream>
#include <limits>
#include <memory>
#include <string>
#include <thread>
#include <vector>
// Constants
constexpr size_t GIB_TO_BYTES = 1ULL << 30;
constexpr size_t MIB_TO_BYTES = 1ULL << 20;
constexpr size_t WARMUP_SIZE = 8 * MIB_TO_BYTES;
constexpr int PRECISION = 3;
// Error Handling
[[noreturn]] static void die(const std::string &msg) {
    std::cerr << "FATAL: " << msg << "\n";
    std::exit(1);
#define CHECK_CU(expr) check_cu_error((expr), #expr, __FILE__, __LINE__)
#define CHECK_RT(expr) check_rt_error((expr), #expr, __FILE__, __LINE__)
static void check_cu_error(CUresult result, const char *expr, const char *file, int line) {
    if (result != CUDA_SUCCESS) {
        const char *name = nullptr, *str = nullptr;
        cuGetErrorName(result, &name);
        cuGetErrorString(result, &str);
        std::cerr << "Driver API error at " << file << ":" << line << "\n"
                  << "  Expression: " << expr << "\n"
                  << "  Error: " << (name ? name : "unknown") << " - "
                  << (str ? str : "unknown") << "\n";
        std::exit(1);
static void check_rt_error(cudaError_t result, const char *expr, const char *file, int line) {
    if (result != cudaSuccess) {
        std::cerr << "Runtime API error at " << file << ":" << line << "\n"
                  << "  Error: " << cudaGetErrorString(result) << "\n";
        std::exit(1);
// Timing Utilities
using TimePoint = std::chrono::steady_clock::time_point;
static inline double ms_between(TimePoint a, TimePoint b) {
    return std::chrono::duration<double, std::milli>(b - a).count();
// CLI Configuration
struct CLI {
    std::string mode = "vmm";
    int device = 0;
    bool warmup = true;
    // VMM mode
    size_t gib = 1;
    size_t chunk_mib = 0;
    int repeats = 3;
    // Pool mode
    int pool_iters = 1000;
    size_t pool_block_mib = 8;
    // SetAcc mode
    size_t setacc_total_mib = 4096;
    size_t setacc_slice_mib = 16;
class CLIParser {
public:
    static CLI parse(int argc, char **argv) {
        CLI result;
        for (int i = 1; i < argc; ++i) {
            std::string arg(argv[i]);
            if (arg == "--help" || arg == "-h") {
                print_help();
                std::exit(0);
            if (i + 1 >= argc && arg.find('=') == std::string::npos) {
                die("Missing value for " + arg);
            parse_arg(result, arg, i, argc, argv);
        return result;
private:
    static void parse_arg(CLI &c, const std::string &arg, int &i, int argc, char **argv) {
        auto get_value = [&]() { return std::string(argv[++i]); };
        if (arg == "--mode")
            c.mode = get_value();
        else if (arg == "--gib")
            c.gib = std::stoull(get_value());
        else if (arg == "--chunk")
            c.chunk_mib = std::stoull(get_value());
        else if (arg == "--repeats")
            c.repeats = std::stoi(get_value());
        else if (arg == "--no-warmup")
            c.warmup = false;
        else if (arg == "--iters")
            c.pool_iters = std::stoi(get_value());
        else if (arg == "--block-mib")
            c.pool_block_mib = std::stoull(get_value());
        else if (arg == "--dev")
            c.device = std::stoi(get_value());
        else
            die("Unknown argument: " + arg);
    static void print_help() {
        std::cout << R"(Usage: ./memory_bench [--mode vmm|pool|setacc] [options]
Modes and options:
  --mode vmm    Virtual Memory Management benchmark
      --gib N        : VA arena size in GiB (default 1)
      --chunk M      : chunk size for map/SetAccess in MiB; 0 = single batch (default 0)
      --repeats R    : number of runs (default 3)
      --no-warmup    : disable pre-test warmup
      --dev D        : device ordinal (default 0)
  --mode pool   Async Memory Pool benchmark
      --iters I      : alloc/free iterations (default 1000)
      --block-mib B  : allocation size per op in MiB (default 8)
Examples:
  ./memory_bench --mode vmm --gib 1 --chunk 0 --repeats 3 --dev 0
  ./memory_bench --mode pool --iters 1000 --block-mib 8 --dev 0
// CUDA Utilities
class CUDAContext {
public:
    CUDAContext(int device_id) : device_id_(device_id), context_(nullptr) {
        CHECK_CU(cuInit(0));
        CUdevice dev;
        CHECK_CU(cuDeviceGet(&dev, device_id));
        CHECK_CU(cuDevicePrimaryCtxRetain(&context_, dev));
        CHECK_CU(cuCtxSetCurrent(context_));
    ~CUDAContext() {
        if (context_) {
            cuCtxSetCurrent(nullptr);
            CUdevice dev;
            cuDeviceGet(&dev, device_id_);
            cuDevicePrimaryCtxRelease(dev);
private:
    int device_id_;
    CUcontext context_;
__global__ void noop_kernel() {}
static void legacy_warmup_driver() {
    CUdeviceptr d = 0;
    CHECK_CU(cuMemAlloc(&d, WARMUP_SIZE));
    CHECK_CU(cuMemsetD8(d, 0, WARMUP_SIZE));
    CHECK_CU(cuMemFree(d));
static void runtime_warmup(cudaStream_t s) {
    void *p = nullptr;
    CHECK_RT(cudaMallocAsync(&p, WARMUP_SIZE, s));
    CHECK_RT(cudaMemsetAsync(p, 0, WARMUP_SIZE, s));
    noop_kernel<<<1, 1, 0, s>>>();
    CHECK_RT(cudaFreeAsync(p, s));
    CHECK_RT(cudaStreamSynchronize(s));
// Size Utilities
static size_t align_up(uint64_t value, uint64_t alignment) {
    const uint64_t aligned = ((value + alignment - 1) / alignment) * alignment;
    if (aligned == 0 || aligned > static_cast<uint64_t>(std::numeric_limits<size_t>::max())) {
        die("Size overflow or alignment error (value=" + std::to_string(value) + ")");
    return static_cast<size_t>(aligned);
// VMM Benchmark
void run_vmm_benchmark(const CLI &c) {
    CUDAContext ctx(c.device);
    // Device info
    CUdevice dev;
    CHECK_CU(cuDeviceGet(&dev, c.device));
    char dev_name[256] = {};
    CHECK_CU(cuDeviceGetName(dev_name, 255, dev));
    int compute_major = 0, compute_minor = 0;
    CHECK_CU(cuDeviceGetAttribute(&compute_major, CU_DEVICE_ATTRIBUTE_COMPUTE_CAPABILITY_MAJOR, dev));
    CHECK_CU(cuDeviceGetAttribute(&compute_minor, CU_DEVICE_ATTRIBUTE_COMPUTE_CAPABILITY_MINOR, dev));
    std::cout << "Device       : " << c.device << " (" << dev_name
              << ", Compute " << compute_major << "." << compute_minor << ")\n"
              << "Arena        : " << c.gib << " GiB\n"
              << "Mapping mode : "
              << (c.chunk_mib == 0 ? "single batch" : "chunks of " + std::to_string(c.chunk_mib) + " MiB") << "\n"
              << "Repeats      : " << c.repeats << "\n"
              << "Warmup       : " << (c.warmup ? "enabled" : "disabled") << "\n\n";
    // Allocation properties
    CUmemAllocationProp prop{};
    prop.type = CU_MEM_ALLOCATION_TYPE_PINNED;
    prop.location.type = CU_MEM_LOCATION_TYPE_DEVICE;
    prop.location.id = c.device;
    prop.requestedHandleTypes = CU_MEM_HANDLE_TYPE_NONE;
    size_t granularity = 0;
    CHECK_CU(cuMemGetAllocationGranularity(&granularity, &prop, CU_MEM_ALLOC_GRANULARITY_MINIMUM));
    const size_t total_bytes = align_up(static_cast<uint64_t>(c.gib) * GIB_TO_BYTES, granularity);
    size_t chunk_bytes = total_bytes;
    if (c.chunk_mib != 0) {
        const uint64_t chunk_u64 = static_cast<uint64_t>(c.chunk_mib) * MIB_TO_BYTES;
        chunk_bytes = align_up(chunk_u64, granularity);
        if (chunk_bytes > total_bytes)
    // Main benchmark loop
    for (int rep = 0; rep < c.repeats; ++rep) {
        if (c.warmup)
            legacy_warmup_driver();
        // Reserve virtual address range
        CUdeviceptr base = 0;
        CHECK_CU(cuMemAddressReserve(&base, total_bytes, granularity, 0, 0));
        // Measure cuMemCreate
        auto t0 = std::chrono::steady_clock::now();
        // describes the properties of the memory to allocate, e.g. physical location
        CUmemGenericAllocationHandle handle;
        // create the chunk of memory according to 'prop' and get a handle to it
        CHECK_CU(cuMemCreate(&handle, total_bytes, &prop, 0));
        auto t1 = std::chrono::steady_clock::now();
        // Measure cuMemMap
        auto t2 = std::chrono::steady_clock::now();
        for (size_t off = 0; off < total_bytes; off += chunk_bytes) {
            const size_t sz = std::min(chunk_bytes, total_bytes - off);
            // Map the virtual address range to the physical location described by 'handle'
            CHECK_CU(cuMemMap(base + off, sz, 0, handle, 0));
        auto t3 = std::chrono::steady_clock::now();
        // Measure cuMemSetAccess
        CUmemAccessDesc acc{};
        acc.location = prop.location;
        acc.flags = CU_MEM_ACCESS_FLAGS_PROT_READWRITE;
        auto t4 = std::chrono::steady_clock::now();
            // To enable access to the mapped region, set the access permissions
            CHECK_CU(cuMemSetAccess(base + off, sz, &acc, 1));
        auto t5 = std::chrono::steady_clock::now();
        // Measure cleanup
        auto t6 = std::chrono::steady_clock::now();
            CHECK_CU(cuMemUnmap(base + off, sz));
        CHECK_CU(cuMemRelease(handle));
        CHECK_CU(cuMemAddressFree(base, total_bytes));
        auto t7 = std::chrono::steady_clock::now();
        std::cout << std::fixed << std::setprecision(PRECISION)
                  << "Run " << (rep + 1) << "/" << c.repeats << ":\n"
                  << "  cuMemCreate          : " << ms_between(t0, t1) << " ms\n"
                  << "  cuMemMap             : " << ms_between(t2, t3) << " ms\n"
                  << "  cuMemSetAccess       : " << ms_between(t4, t5) << " ms\n"
                  << "  Unmap + AddressFree  : " << ms_between(t6, t7) << " ms\n\n";
// Pool Benchmark
void run_pool_benchmark(const CLI &c) {
    CHECK_RT(cudaSetDevice(c.device));
    cudaDeviceProp prop{};
    CHECK_RT(cudaGetDeviceProperties(&prop, c.device));
    std::cout << "Device : " << c.device << " (" << prop.name << ")\n";
    cudaMemPool_t pool;
    CHECK_RT(cudaDeviceGetDefaultMemPool(&pool, c.device));
    // Configure pool to never trim and allow reuse
    unsigned long long threshold = ~0ULL;
    CHECK_RT(cudaMemPoolSetAttribute(pool, cudaMemPoolAttrReleaseThreshold, &threshold));
    int one = 1;
    CHECK_RT(cudaMemPoolSetAttribute(pool, cudaMemPoolReuseAllowOpportunistic, &one));
    CHECK_RT(cudaMemPoolSetAttribute(pool, cudaMemPoolReuseAllowInternalDependencies, &one));
    CHECK_RT(cudaMemPoolTrimTo(pool, 0));
    cudaStream_t stream;
    CHECK_RT(cudaStreamCreateWithFlags(&stream, cudaStreamNonBlocking));
    runtime_warmup(stream);
    const size_t block_bytes = c.pool_block_mib * MIB_TO_BYTES;
    std::vector<void *> ptrs;
    ptrs.reserve(c.pool_iters);
    // Allocate
    for (int i = 0; i < c.pool_iters; ++i) {
        void *p = nullptr;
        CHECK_RT(cudaMallocAsync(&p, block_bytes, stream));
        ptrs.push_back(p);
    CHECK_RT(cudaStreamSynchronize(stream));
    // Free
    for (void *p : ptrs)
        CHECK_RT(cudaFreeAsync(p, stream));
              << "Allocated  " << c.pool_iters << " x " << c.pool_block_mib
              << " MiB blocks : " << ms_between(t0, t1) << " ms\n"
              << "Freed      " << c.pool_iters << " blocks        : "
              << ms_between(t1, t2) << " ms\n";
    // Simulate idle time
    std::this_thread::sleep_for(std::chrono::milliseconds(500));
    // Post-idle alloc+free
        void *p = nullptr;
    std::cout << "Post-sleep alloc+free (" << c.pool_iters << " ops) : "
              << ms_between(t3, t4) << " ms\n";
    CHECK_RT(cudaStreamDestroy(stream));
// Main
int main(int argc, char **argv) {
    CLI cli = CLIParser::parse(argc, argv);
    cudaProfilerStart();
    try {
        if (cli.mode == "vmm") {
            run_vmm_benchmark(cli);
        } else if (cli.mode == "pool") {
            run_pool_benchmark(cli);
        } else {
            die("Unknown benchmark mode: " + cli.mode);
    } catch (const std::exception &e) {
        std::cerr << "Exception: " << e.what() << "\n";
        cudaProfilerStop();
        return 1;
    cudaProfilerStop();
    return 0;
Notes
  • VMM path does cuMemAddressReservecuMemCreate(total_bytes)cuMemMapcuMemSetAccessunmap+free.
  • No peer access, single GPU (–dev 0), single thread.
  • Warmup clears driver/runtime cold-start effects for basic ops; cuMemCreate remains dominant on GB200.
Reproduction steps
# GB200 (Blackwell, sm_100)
nvcc -O3 -std=c++17 -gencode arch=compute_100,code=sm_100 memory_bench.cu -o memory_bench -lcuda
# H200 NVL (Hopper, sm_90)
nvcc -O3 -std=c++17 -gencode arch=compute_90,code=sm_90 memory_bench.cu -o memory_bench -lcuda
# RTX 4090 (Ada, sm_89)
# nvcc -O3 -std=c++17 -gencode arch=compute_89,code=sm_89 memory_bench.cu -o memory_bench -lcuda
# run vmm benchmark
./memory_bench --mode vmm --gib 1 --chunk 0 --dev 0 --repeats 3
# run async pool benchmark
Results
Full output logs
GB200
Device       : 0 (NVIDIA GB200, Compute 10.0)
Arena        : 1 GiB
Mapping mode : single batch
Repeats      : 3
Warmup       : enabled
Run 1/3:
  cuMemCreate          : 87.823 ms
  cuMemMap             : 0.009 ms
  cuMemSetAccess       : 0.152 ms
  Unmap + AddressFree  : 1.008 ms
Run 2/3:
  cuMemCreate          : 87.784 ms
  cuMemMap             : 0.008 ms
  cuMemSetAccess       : 0.139 ms
  Unmap + AddressFree  : 0.985 ms
Run 3/3:
  cuMemCreate          : 89.189 ms
  cuMemMap             : 0.009 ms
  cuMemSetAccess       : 1.277 ms
  Unmap + AddressFree  : 1.438 ms
Device : 0 (NVIDIA GB200)
Allocated  1000 x 8 MiB blocks : 690.458 ms
Freed      1000 blocks        : 0.512 ms
Post-sleep alloc+free (1000 ops) : 0.494 ms
H200 NVL
Device       : 0 (NVIDIA H200 NVL, Compute 9.0)
Arena        : 1 GiB
Repeats      : 3
Warmup       : enabled
Run 1/3:
  cuMemCreate          : 0.132 ms
  cuMemMap             : 0.003 ms
  cuMemSetAccess       : 0.085 ms
  Unmap + AddressFree  : 0.449 ms
Run 2/3:
  cuMemCreate          : 0.089 ms
  cuMemMap             : 0.001 ms
  cuMemSetAccess       : 0.078 ms
  Unmap + AddressFree  : 0.430 ms
Run 3/3:
  cuMemCreate          : 0.081 ms
  cuMemMap             : 0.001 ms
  cuMemSetAccess       : 0.077 ms
  Unmap + AddressFree  : 0.429 ms
Device : 0 (NVIDIA H200 NVL)
Allocated  1000 x 8 MiB blocks : 62.640 ms
Freed      1000 blocks        : 0.279 ms
Post-sleep alloc+free (1000 ops) : 0.478 ms
VMM (1 GiB, single batch)
GPU cuMemCreate (ms) cuMemMap (ms) cuMemSetAccess (ms) Unmap+Free (ms)
GB200 87.8 / 87.8 / 89.2 0.009 / 0.008 / 0.009 0.152 / 0.139 / 1.277 1.008 / 0.985 / 1.438
H200 NVL 0.132 / 0.089 / 0.081 0.003 / 0.001 / 0.001 0.085 / 0.078 / 0.077 0.449 / 0.430 / 0.429
cuMemCreate on GB200 is ~10^3x slower than on H200 for the same size.
Async pool sanity check (1000 × 8 MiB)
GPU Alloc batch (ms) Free batch (ms) Post-sleep alloc+free (ms, 1000 ops)
GB200 690.458 0.512 0.494
H200 NVL 62.640 0.279 0.478
Nsight Systems (CUDA API Summary excerpts)
GB200
 ** CUDA API Summary (cuda_api_sum):
 Time (%)  Total Time (ns)  Num Calls    Avg (ns)       Med (ns)      Min (ns)     Max (ns)    StdDev (ns)                 Name
     59.1      710,954,720      2,002      355,122.2          576.0          224    5,634,112    944,383.8  cudaMallocAsync_v11020
*     22.2      266,906,592          3   88,968,864.0   89,051,552.0   88,327,744   89,527,296    604,035.8  cuMemCreate
     17.7      213,328,960          1  213,328,960.0  213,328,960.0  213,328,960  213,328,960          0.0  cudaProfilerStart
      0.2        2,883,488          3      961,162.7      959,968.0      950,080      973,440     11,725.7  cuMemRelease
      0.2        2,605,920          3      868,640.0      826,944.0      810,176      968,800     87,145.3  cuMemAlloc_v2
      0.2        2,154,368          3      718,122.7      192,832.0      167,968    1,793,568    931,445.9  cuMemSetAccess
      0.1        1,146,560          1    1,146,560.0    1,146,560.0    1,146,560    1,146,560          0.0  cudaGetDeviceProperties_v2_v12000
      0.1          964,896      2,002          482.0          448.0          320        6,176        237.6  cudaFreeAsync_v11020
      0.0          330,464          3      110,154.7      103,232.0       90,560      136,672     23,822.7  cuMemFree_v2
      0.0          192,960          3       64,320.0       64,064.0       59,904       68,992      4,549.4  cuMemUnmap
      0.0          116,480          3       38,826.7       37,056.0       36,384       43,040      3,664.3  cuMemsetD8_v2
      0.0           79,712          1       79,712.0       79,712.0       79,712       79,712          0.0  cudaDeviceGetDefaultMemPool_v11020
      0.0           79,072          2       39,536.0       39,536.0        9,312       69,760     42,743.2  cudaLaunchKernel
      0.0           58,240          3       19,413.3       19,776.0       17,440       21,024      1,819.3  cuMemAddressReserve
      0.0           55,168          3       18,389.3       18,688.0       17,568       18,912        720.1  cuMemAddressFree
      0.0           52,768          2       26,384.0       26,384.0       23,104       29,664      4,638.6  cudaMemsetAsync
      0.0           32,576          5        6,515.2        6,624.0        3,296        8,640      2,169.0  cudaStreamSynchronize
      0.0           31,008          3       10,336.0       10,112.0        9,344       11,552      1,120.9  cuMemMap
      0.0           14,240          1       14,240.0       14,240.0       14,240       14,240          0.0  cudaStreamDestroy
      0.0            9,664          1        9,664.0        9,664.0        9,664        9,664          0.0  cudaStreamCreateWithFlags
      0.0            4,384          3        1,461.3          352.0          288        3,744      1,977.1  cudaMemPoolSetAttribute_v11020
      0.0            2,656          2        1,328.0        1,328.0        1,024        1,632        429.9  cuCtxSetCurrent
      0.0            2,304          1        2,304.0        2,304.0        2,304        2,304          0.0  cuProfilerStart
      0.0            2,080          1        2,080.0        2,080.0        2,080        2,080          0.0  cuMemGetAllocationGranularity
      0.0            1,952          1        1,952.0        1,952.0        1,952        1,952          0.0  cuInit
      0.0            1,184          1        1,184.0        1,184.0        1,184        1,184          0.0  cudaProfilerStop
      0.0            1,120          1        1,120.0        1,120.0        1,120        1,120          0.0  cudaMemPoolTrimTo_v11020
      0.0            1,056          1        1,056.0        1,056.0        1,056        1,056          0.0  cuModuleGetLoadingMode
 ** CUDA GPU MemOps Summary (by Size) (cuda_gpu_mem_size_sum):
  Time (%)  Total Time (ns)  Count  Avg (ns)  Med (ns)  Min (ns)  Max (ns)  StdDev (ns)    Operation
    100.0           26,016      5   5,203.2   5,248.0     4,640     5,568        347.3  [CUDA memset]
H200
     88.7      319,144,097          1  319,144,097.0  319,144,097.0  319,144,097  319,144,097          0.0  cudaProfilerStart
      7.2       25,932,255      2,002       12,953.2          400.0          320    2,981,070     76,505.2  cudaMallocAsync_v11020
      1.1        3,904,773          5      780,954.6        3,760.0        1,980    2,410,288  1,114,488.0  cudaStreamSynchronize
      1.0        3,578,870          3    1,192,956.7    1,104,783.0      516,521    1,957,566    724,557.5  cuMemFree_v2
      0.6        2,017,217          2    1,008,608.5    1,008,608.5        9,490    2,007,727  1,412,966.9  cudaLaunchKernel
      0.4        1,430,184          3      476,728.0      386,811.0      382,601      660,772    159,400.7  cuMemRelease
      0.4        1,418,725          1    1,418,725.0    1,418,725.0    1,418,725    1,418,725          0.0  cudaGetDeviceProperties_v2_v12000
      0.2          748,504      2,002          373.9          340.0          300        4,190        121.2  cudaFreeAsync_v11020
      0.1          455,111          3      151,703.7       93,470.0       76,250      285,391    116,096.3  cuMemAlloc_v2
*      0.1          389,271          3      129,757.0       97,891.0       83,690      207,690     67,864.4  cuMemCreate
      0.1          281,992          3       93,997.3       80,440.0       79,941      121,611     23,915.4  cuMemSetAccess
      0.0          148,620          3       49,540.0       45,830.0       44,800       57,990      7,336.0  cuMemUnmap
      0.0          130,720          1      130,720.0      130,720.0      130,720      130,720          0.0  cudaDeviceGetDefaultMemPool_v11020
      0.0           91,543          3       30,514.3        9,561.0        5,881       76,101     39,522.1  cuMemsetD8_v2
      0.0           67,050          2       33,525.0       33,525.0       24,190       42,860     13,201.7  cudaMemsetAsync
      0.0           25,850          3        8,616.7        3,610.0        2,640       19,600      9,524.2  cuMemAddressReserve
      0.0           16,610          3        5,536.7        2,900.0        2,390       11,320      5,015.0  cuMemAddressFree
      0.0           11,470          1       11,470.0       11,470.0       11,470       11,470          0.0  cudaStreamDestroy
      0.0           10,700          1       10,700.0       10,700.0       10,700       10,700          0.0  cudaStreamCreateWithFlags
      0.0           10,690          3        3,563.3          330.0          110       10,250      5,791.9  cudaMemPoolSetAttribute_v11020
      0.0            8,250          1        8,250.0        8,250.0        8,250        8,250          0.0  cudaProfilerStop
      0.0            6,800          1        6,800.0        6,800.0        6,800        6,800          0.0  cuMemGetAllocationGranularity
      0.0            6,440          3        2,146.7        1,290.0        1,050        4,100      1,695.9  cuMemMap
      0.0            4,850          1        4,850.0        4,850.0        4,850        4,850          0.0  cuProfilerStart
      0.0            4,030          1        4,030.0        4,030.0        4,030        4,030          0.0  cuInit
      0.0            1,560          1        1,560.0        1,560.0        1,560        1,560          0.0  cuModuleGetLoadingMode
      0.0            1,540          2          770.0          770.0          400        1,140        523.3  cuCtxSetCurrent
      0.0            1,460          1        1,460.0        1,460.0        1,460        1,460          0.0  cudaMemPoolTrimTo_v11020
 Total (MB)  Count  Avg (MB)  Med (MB)  Min (MB)  Max (MB)  StdDev (MB)    Operation
     41.943      5     8.389     8.389     8.389     8.389        0.000  [CUDA memset]
Question
Is the ~80–90 ms cuMemCreate(1 GiB) on GB200 expected?
If not, are there GB200-specific CUmemAllocationProp settings, handle types, or platform knobs recommended to reduce cuMemCreate latency?
Any insights or pointers to documentation/known issues would be greatly appreciated. Thanks!
Is IMEX running? I think its possible it could be affected by imex activity on GB200 NVL72.
Thanks for the pointer!
I tested with the IMEX service both running and stopped, and cuMemCreate(1 GiB) on GB200 still measures ~88–89 ms in my repro.
Does cuMemCreate on GB200 NVL72 interact with IMEX even when prop.requestedHandleTypes = CU_MEM_HANDLE_TYPE_NONE?
