I am trying your 5.2 product on my opteron (redhat ES3.0-U1 X86_64) on my 100K lines
of C++ code. The Pathscale compiler bombed horribly :-), I thought I should try yours.
I have gcc 3.4.0 as my default Opteron compiler. I downloaded and installed the compiler into
/usr/local/pgi, but I cannot compiler anything. I get…
pgCC -o common/blist.o common/blist.cxx -c -D_REENTRANT -O2 -DOUTLINE -I/usr/X11R6/include -I./ -I./common/ -I./search/ -I./search/parser/ -I./lzma/ -I./support/ -I./clientserver/ -I./search/gui/
pgCC -o common/butilities.o common/butilities.cxx -c -D_REENTRANT -O2 -DOUTLINE -I/usr/X11R6/include -I./ -I./common/ -I./search/ -I./search/parser/ -I./lzma/ -I./support/ -I./clientserver/ -I./search/gui/
“”/usr/local/pgi/linux86-64/5.2/include/CC/config/stl_mycomp.h", line 58: catastrophic error:
could not open source file “float.h” #include <float.h>
1 catastrophic error detected in the compilation of “common/butilities.cxx”.
Compilation terminated.
/usr/local/pgi/linux86-64/5.2/include/CCmake[1]: *** [common/butilities.o] Error 2
make[1]: *** Waiting for unfinished jobs…
1 catastrophic error detected in the compilation of “common/blist.cxx”.
make[1]: *** [common/blist.o] Error 2
make[1]: Leaving directory `/raid0/berkley/sources’
make: *** [optim] Error 2
This is probably an installation issue. If you still have the unpacked tarfile
on your hard drive, find the directory linux86-64/5.2/include-gcc33 and
copy the float.h and limit.h files into $PGI/linux86-64/5.2/include , where
$PGI is your installation directory.
If that works, please let us know ASAP so we can get the installer fixed
for everyone else. Thanks.
dirname: too few arguments
Try dirname --help' for more information. basename: too few arguments Try basename --help’ for more information.
Try dirname --help' for more information. dirname: too few arguments Try dirname --help’ for more information.
Try basename --help' for more information. dirname: too few arguments Try dirname --help’ for more information.
If you don’t already have permanent keys for this product/release, a
fifteen-day evaluation license can be created now.
“/usr/pgi/linux86-64/5.2/include/float.h”, line 55: catastrophic error: could
#include_next<float.h>
What’s your locarc file look like? localrc file is in $PGI/linux86-64/5.2/bin for 64-bit or $PGI/linux86/5.2/bin for 32-bit. It looks to me that the localrc contained incorrect information. If I am not wrong, in 3.4.0 the include files are in /usr/lib/… while in 3.3.3 (or other versions) include files are under /usr/lib64/… I have similar error but the problem disappears after editing the localrc to make sure it points to the correct directory.
From the information you gave:
Your localrc should at least have:
set GCCDIR=/usr/lib/gcc/x86_64-unknown-linux-gnu/3.4.0;
set GCCINC=/usr/lib/gcc/x86_64-unknown-linux-gnu/3.4.0/include;
set G77DIR=/usr/lib/gcc/x86_64-unknown-linux-gnu/3.4.0;
“common/DiskPipe.cxx”, line 352: error: incomplete type is not allowed
struct stat64 FileStatus;
“common/DiskPipe.cxx”, line 353: error: the global scope has no “fstat64”
int ret = ::fstat64(readFD_, &FileStatus);
“common/DiskPipe.cxx”, line 366: error: identifier “off64_t” is undefined
off64_t FileSize = FileStatus.st_size;
after lots of hunting for #ifdef I see that your compiler just gets
completely lost going through the /usr/include files.
“/usr/include/asm-x86_64/fcntl.h”, line 18: warning: incompatible redefinition
of macro “FASYNC” (declared at line 170 of
“/usr/include/bits/fcntl.h”) #define FASYNC 020000 /* fcntl, for BSD compatibility */
“/usr/include/asm-x86_64/fcntl.h”, line 66: error: invalid redeclaration of
type name “flock” (declared at line 140 of
struct flock {
“/usr/include/sys/wait.h”, line 112: error: identifier “__WAIT_STATUS” is
undefined
extern __pid_t wait (__WAIT_STATUS __stat_loc);
This just isn’t worth my time to get the #defines right in every file just to use
common things like ::open or O_DIRECT. Even SlowLaris 8.0 was a faster port than this.
Is there a #if defined(pgCC) or something similar your compiler gives me?
