Hi
I’m getting the following error while installing Nvidia Direct Storage. This is using Ubuntu 20.04. CUDA 11.1 and Driver 460.80.
Following the steps mentioned here: NVIDIA GPUDirect Storage Installation and Troubleshooting Guide :: NVIDIA GPUDirect Storage Documentation
Picking NVIDIA driver sources from NVIDIA_SRC_DIR=/usr/src/nvidia-460.80/nvidia. If that does not meet your expectation, you might have a stale driver still around and that might cause problems.
Getting symbol versions from /lib/modules/5.8.0-55-generic/updates/dkms/nvidia.ko ...
Created: /home/user1/ds/gds-nvidia-fs/src/nv.symvers
checking if uaccess.h access_ok has 3 parameters... no
checking if uaccess.h access_ok has 2 parameters... yes
Checking if blkdev.h has blk_rq_payload_bytes... yes
Checking if fs.h has call_read_iter and call_write_iter... yes
Checking if fs.h has filemap_range_has_page... yes
Checking if kiocb structue has ki_complete field... yes
Checking if vm_fault_t exist in mm_types.h... yes
Checking if IOCB_HIPRI flag exists in fs.h... yes
Checking if enum PCIE_SPEED_32_0GT exists in pci.h... yes
make[1]: Entering directory '/usr/src/linux-headers-5.8.0-55-generic'
CC [M] /home/user1/ds/gds-nvidia-fs/src//nvfs-core.o
CC [M] /home/user1/ds/gds-nvidia-fs/src//nvfs-dma.o
CC [M] /home/user1/ds/gds-nvidia-fs/src//nvfs-mmap.o
CC [M] /home/user1/ds/gds-nvidia-fs/src//nvfs-pci.o
In file included from ./include/linux/string.h:6,
from ./include/linux/dma-mapping.h:6,
from /home/user1/ds/gds-nvidia-fs/src//nvfs-dma.c:24:
/home/user1/ds/gds-nvidia-fs/src//nvfs-dma.c: In function ‘nvfs_blk_rq_check’:
/home/user1/ds/gds-nvidia-fs/src//nvfs-dma.c:189:73: error: ‘RQF_COPY_USER’ undeclared (first use in this function)
189 | if (unlikely((req->rq_flags & RQF_SPECIAL_PAYLOAD) || (req->rq_flags & RQF_COPY_USER)))
./include/linux/compiler.h:78:42: note: in definition of macro ‘unlikely’
78 | # define unlikely(x) __builtin_expect(!!(x), 0)
/home/user1/ds/gds-nvidia-fs/src//nvfs-dma.c:189:73: note: each undeclared identifier is reported only once for each function it appears in
/home/user1/ds/gds-nvidia-fs/src//nvfs-dma.c: In function ‘nvfs_blk_rq_map_sg_internal’:
/home/user1/ds/gds-nvidia-fs/src//nvfs-dma.c:335:18: error: ‘struct request_queue’ has no member named ‘dma_drain_size’
335 | if (unlikely(q->dma_drain_size && q->dma_drain_needed(req))) {
/home/user1/ds/gds-nvidia-fs/src//nvfs-dma.c:335:39: error: ‘struct request_queue’ has no member named ‘dma_drain_needed’
make[2]: *** [scripts/Makefile.build:286: /home/user1/ds/gds-nvidia-fs/src//nvfs-dma.o] Error 1
make[2]: *** Waiting for unfinished jobs....
make[1]: *** [Makefile:1785: /home/user1/ds/gds-nvidia-fs/src/] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-5.8.0-55-generic'
make: *** [Makefile:109: module] Error 2
Regards,
MJay
