Hi, I am trying to install CUDA 11.7 on my computer for OpenPose but I have many problems trying to install the nvidia driver on my ubuntu 20.04 version. I was thinking of using the x86_64 architecture and and the runfile (local) installer type. Altough I don’t think I have the Correct Kernel Headers and Development Packages Installed.
My infos:
OS: Ubuntu 20.04.5 LTS
Laptop: Dell-G15-5515
gcc version: 9.4.0
Kernel version: 5.15.0-50-generic
When I try :
$ sudo apt-get install linux-headers-$(uname -r)
I have this:
Reading package lists… Done
Building dependency tree
Reading state information… Done
linux-headers-5.15.0-50-generic is already the newest version (5.15.0-50.56~20.04.1).
sh: 0: getcwd() failed: No such file or directory
0 upgraded, 0 newly installed, 0 to remove and 79 not upgraded.
12 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] Y
Setting up nvidia-dkms-520 (520.61.05-0ubuntu1) …
update-initramfs: deferring update (trigger activated)
A modprobe blacklist file has been created at /etc/modprobe.d to prevent Nouveau
from loading. This can be reverted by deleting the following file:
/etc/modprobe.d/nvidia-graphics-drivers.conf
A new initrd image has also been created. To revert, please regenerate your
initrd by running the following command after deleting the modprobe.d file:
/usr/sbin/initramfs -u
*** Reboot your computer and verify that the NVIDIA graphics driver can ***
*** be loaded. ***
INFO:Enable nvidia
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/dell_latitude
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/put_your_quirks_here
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/lenovo_thinkpad
Removing old nvidia-520.61.05 DKMS files…
Deleting module version: 520.61.05
completely from the DKMS tree.
Done.
Loading new nvidia-520.61.05 DKMS files…
Building for 5.15.0-50-generic
Building for architecture x86_64
Building initial module for 5.15.0-50-generic
ERROR: Cannot create report: [Errno 17] File exists: ‘/var/crash/nvidia-dkms-520.0.crash’
Error! Application of patch disable_fstack-clash-protection_fcf-protection.patch failed.
Check /var/lib/dkms/nvidia/520.61.05/build/ for more information.
dpkg: error processing package nvidia-dkms-520 (–configure):
installed nvidia-dkms-520 package post-installation script subprocess returned error exit status 6
dpkg: dependency problems prevent configuration of cuda-drivers-520:
cuda-drivers-520 depends on nvidia-dkms-520 (>= 520.61.05); however:
Package nvidia-dkms-520 is not configured yet.
dpkg: error processing package cuda-drivers-520 (–configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of nvidia-fs-dkms:
nvidia-fs-dkms depends on cuda-drivers-grid | nvidia-prebuilt-kernel | nvidia-dkms-kernel | nvidia-kernel-dkms; however:
Package cuda-drivers-grid is not installed.
Package nvidia-prebuilt-kernel is not installed.
Package nvidia-dkms-kernel is not installed.
Package nvidia-dkms-520 which provides nvidia-dkms-kernel is not configured yet.
Package nvidia-kernel-dkms is not installed.
dpkg: error processing package nvidia-fs-dkms (–configure):
No apport report written because the error message indicates its a followup error from a previous failure.
No apport report written because MaxReports is reached already
dpkg: dependency problems prevent configuration of nvidia-fs:
nvidia-fs depends on nvidia-fs-prebuilt (>= 2.13.5) | nvidia-fs-dkms (>= 2.13.5); however:
Package nvidia-fs-prebuilt is not installed.
Package nvidia-fs-dkms is not configured yet.
dpkg: error processing package nvidia-fs (–configure):
dpkg: dependency problems prevent configuration of cuda-drivers:
cuda-drivers depends on cuda-drivers-520 (= 520.61.05-1); however:
Package cuda-drivers-520 is not configured yet.
dpkg: error processing package cuda-drivers (–configure):
dpkg: dependency problems prevent configuration of nvidia-gds-11-8:
nvidia-gds-11-8 depends on nvidia-fs (>= 2.13.5); however:
Package nvidia-fs is not configured yet.
dpkg: error processing package nvidia-gds-11-8 (–configure):
dpkg: dependency problems prevent configuration of nvidia-driver-520:
nvidia-driver-520 No apport report written because MaxReports is reached already
depends on nvidia-dkms-520 (= 520.61.05-0ubuntu1); however:
dpkg: error processing package nvidia-driver-520 (–configure):
dpkg: dependency problems prevent configuration of nvidia-gds:
nvidia-gds depends on nvidia-gds-11-8 (>= 11.8.0); however:
Package nvidia-gds-11-8 is not configured yet.
dpkg: error processing package nvidia-gds (–configure):
dpkg: dependency problems prevent configuration of cuda-runtime-11-8:
cuda-runtime-11-8 depends on cuda-drivers (>= 520.61.05); however:
Package cuda-drivers is not configured yet.
dpkg: error processing package cuda-runtime-11-8 (–configure):
dpkg: dependency problems prevent configuration of cuda-11-8:
cuda-11-8 depends on cuda-runtime-11-8 (>= 11.8.0); however:
Package cuda-runtime-11-8 is not configured yet.
dpkg: error processing package cuda-11-8 No apport report written because MaxReports is reached already
(–configure):
dpkg: dependency problems prevent configuration of cuda-demo-suite-11-8:
cuda-demo-suite-11-8 depends on cuda-runtime-11-8; however:
dpkg: error processing package cuda-demo-suite-11-8 (–configure):
dpkg: dependency problems prevent configuration of cuda:
cuda depends on cuda-11-8 (>= 11.8.0); however:
Package cuda-11-8 is not configured yet.
dpkg: error processing package cuda (–configure):
Processing triggers for initramfs-tools (0.136ubuntu6.7) …
update-initramfs: Generating /boot/initrd.img-5.15.0-50-generic
I: The initramfs will attempt to resume from /dev/nvme0n1p7
I: (UUID=61b08d51-6ea4-4b9a-a2e3-7e6806bcef6b)
I: Set the RESUME variable to override this.
Errors were encountered while processing:
nvidia-dkms-520
cuda-drivers-520
nvidia-fs-dkms
nvidia-fs
cuda-drivers
nvidia-gds-11-8
nvidia-driver-520
nvidia-gds
cuda-runtime-11-8
cuda-11-8
cuda
E: Sub-process /usr/bin/dpkg returned an error code (1)
Sorry for the mess and thank you for your help in advance.
