Dependency problem when trying to install cuda toolkit 11.8 on Ubuntu 22.4
I am trying to install the cuda toolkit 11.8 which I already successfully installed on an AMD Ryzen 5 5600X 3.7GHz computer. Now I am trying to install it on an 13th Gen Intel i7-13700H (20) @ 4.800GHz.
sudo apt remove --purge nvidia-dkms-520 cuda-drivers-520 cuda-drivers nvidia-driver-520 cuda-runtime-11-8 cuda-11-8 cuda-demo-suite-11-8 cuda
when runnning th command sudo apt-get -y install cuda, I get several message stating that there are dependency problems. I tried to solve the problem by running the following commands wihthout errors. However it did not solve the problem.
sudo apt install -f
sudo dpkg --configure -a
I also saw the following page: https://forums.developer.nvidia.com/t/ubuntu-cuda-11-8-package-wrong-dependency-on-cuda-drivers/238891 and run the
It did not solve the problem
Here is the full output of the command
$ sudo apt-get -y install cuda
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
cuda is already the newest version (11.8.0-1).
The following packages were automatically installed and are no longer required:
  gdal-data gir1.2-gst-plugins-bad-1.0 libaec0 libarmadillo10 libarpack2 libavcodec-dev libavformat-dev libavutil-dev
  libblkid-dev libblosc1 libcfitsio9 libcharls2 libdc1394-dev libdeflate-dev libdw-dev libegl-dev libelf-dev
  libexif-dev libexif-doc libffi-dev libfluidsynth3 libfreeaptx0 libfreexl1 libfyba0 libgbm-dev libgdal30 libgdcm-dev
  libgdcm3.0 libgeos-c1v5 libgeos3.10.2 libgeotiff5 libgl-dev libgl2ps1.4 libgles-dev libgles1 libglew2.2
  libglib2.0-dev libglib2.0-dev-bin libglx-dev libgphoto2-dev libgstreamer-opencv1.0-0 libgudev-1.0-dev
  libgupnp-igd-1.0-4 libhdf4-0-alt libhdf5-103-1 libhdf5-hl-100 libilmbase-dev libinstpatch-1.0-2 libjbig-dev
  libkmlbase1 libkmldom1 libkmlengine1 libldacbt-enc2 liblept5 libltc11 libminizip1 libmjpegutils-2.1-0 libmodplug1
  libmount-dev libmpeg2encpp-2.1-0 libmplex2-2.1-0 libmysqlclient21 libnetcdf19 libnice10 libntfs-3g89 libodbc2
  libodbcinst2 libogdi4.1 libopencv-calib3d-dev libopencv-calib3d4.5d libopencv-contrib-dev libopencv-contrib4.5d
  libopencv-core-dev libopencv-core4.5d libopencv-dev libopencv-dnn-dev libopencv-dnn4.5d libopencv-features2d-dev
  libopencv-features2d4.5d libopencv-flann-dev libopencv-flann4.5d libopencv-highgui-dev libopencv-highgui4.5d
  libopencv-imgcodecs-dev libopencv-imgcodecs4.5d libopencv-imgproc-dev libopencv-imgproc4.5d libopencv-ml-dev
  libopencv-ml4.5d libopencv-objdetect-dev libopencv-objdetect4.5d libopencv-photo-dev libopencv-photo4.5d
  libopencv-shape-dev libopencv-shape4.5d libopencv-stitching-dev libopencv-stitching4.5d libopencv-superres-dev
  libopencv-superres4.5d libopencv-video-dev libopencv-video4.5d libopencv-videoio-dev libopencv-videoio4.5d
  libopencv-videostab-dev libopencv-videostab4.5d libopencv-viz-dev libopencv-viz4.5d libopencv4.5-java
  libopencv4.5d-jni libopenexr-dev libopenh264-6 libopenni2-0 liborc-0.4-dev liborc-0.4-dev-bin libpq5 libproj22
  libqhull-r8.0 libqt5qml5 libqt5qmlmodels5 libqt5quick5 libqt5waylandclient5 libraw1394-dev libraw1394-tools
  librttopo1 libsidplay1v5 libsocket++1 libspandsp2 libspatialite7 libsrtp2-1 libsuperlu5 libswresample-dev
  libswscale-dev libsz2 libtbb-dev libtbb12 libtbb2 libtbbmalloc2 libtesseract4 libtiff-dev libtiffxx5 libudev-dev
  libunwind-dev liburiparser1 libvo-aacenc0 libvtk9.1 libwayland-bin libwayland-dev libwildmidi2 libwpe-1.0-1
  libwpebackend-fdo-1.0-1 libx11-dev libx11-xcb-dev libxerces-c3.2 libzbar0 libzxingcore1 mysql-common
  nvidia-firmware-535-535.154.05 nvidia-firmware-535-535.183.01 opencv-data proj-bin proj-data timgm6mb-soundfont
  unixodbc-common xtrans-dev
Use 'sudo apt autoremove' to remove them.
0 to upgrade, 0 to newly install, 0 to remove and 34 not to upgrade.
8 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up nvidia-dkms-520 (520.61.05-0ubuntu1) ...
update-initramfs: deferring update (trigger activated)
A modprobe blacklist file has been created at /etc/modprobe.d to prevent Nouveau
from loading. This can be reverted by deleting the following file:
/etc/modprobe.d/nvidia-graphics-drivers.conf
A new initrd image has also been created. To revert, please regenerate your
initrd by running the following command after deleting the modprobe.d file:
`/usr/sbin/initramfs -u`
*** Reboot your computer and verify that the NVIDIA graphics driver can   ***
*** be loaded.                                                            ***
INFO:Enable nvidia
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/put_your_quirks_here
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/lenovo_thinkpad
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/dell_latitude
Removing old nvidia-520.61.05 DKMS files...
Deleting module nvidia-520.61.05 completely from the DKMS tree.
Loading new nvidia-520.61.05 DKMS files...
Building for 6.5.0-1025-oem
Building for architecture x86_64
Building initial module for 6.5.0-1025-oem
ERROR: Cannot create report: [Errno 17] File exists: '/var/crash/nvidia-dkms-520.0.crash'
Error! Bad return status for module build on kernel: 6.5.0-1025-oem (x86_64)
Consult /var/lib/dkms/nvidia/520.61.05/build/make.log for more information.
dpkg: error processing package nvidia-dkms-520 (--configure):
 installed nvidia-dkms-520 package post-installation script subprocess returned error exit status 10
dpkg: dependency problems prevent configuration of cuda-drivers-520:
 cuda-drivers-520 depends on nvidia-dkms-520 (>= 520.61.05); however:
  Package nvidia-dkms-520 is not configured yet.
dpkg: error processing package cuda-drivers-520 (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of cuda-drivers:
 cuda-drivers depends on cuda-drivers-520 (= 520.61.05-1); however:
  Package cuda-drivers-520 is not configured yet.
dpkg: error processing package cuda-drivers (--configure):
dpkg: dependency problems prevent configuration of nvidia-driver-520:
 nvidia-driver-520 depends on nvidia-dkms-520 (= 520.61.05-0ubuntu1); however:
dpkg: error processing package nvidia-driver-520 (--configure):
dpkg: dependency problems prevent configuration of cuda-runtime-11-8:
 cuda-runtime-11-8 depends on cuda-drivers (>No apport report written because the error message indicates it's a follow-up error from a previous failure.
No apport report written because MaxReports has already been reached
  Package cuda-drivers is not configured yet.
dpkg: error processing package cuda-runtime-11-8 (--configure):
dpkg: dependency problems prevent configuration of cuda-11-8:
 cuda-11-8 depends on cuda-runtime-11-8 (>= 11.8.0); however:
  Package cuda-runtime-11-8 is not configured yet.
dpkg: error processing package cuda-11-8 (--configure):
dpkg: dependency problems prevent configuration of cuda-demo-suite-11-8:
 cuda-demo-suite-11-8 depends on cuda-runtime-11-8; however:
dpkg: error processing package cuda-demo-suite-11-8 (--configure):
dpkg: dependency problems prevent configuration of cuda:
 cuda depends on cuda-11-8 (>= 11.8.0); however:
  Package cuda-11-8 is not configured yet.
dpkg: error processing package cuda (--configure):
Processing triggers for initramfs-tools (0.140ubuntu13.4) ...
update-initramfs: Generating /boot/initrd.img-6.5.0-1025-oem
Errors were encountered while processing:
 nvidia-dkms-520
 cuda-drivers-520
 cuda-drivers
 nvidia-driver-520
 cuda-runtime-11-8
 cuda-11-8
 cuda
E: Sub-process /usr/bin/dpkg returned an error code (1)
Seems that it is a topic which is related to CUDA. Please create a topic in CUDA forum CUDA Setup and Installation - NVIDIA Developer Forums. Thanks.
Thank you for your answer: I just posted the question there:
https://forums.developer.nvidia.com/t/dependency-problem-when-trying-to-install-cuda-toolkit-11-8-on-ubuntu-22-04/300329
